DUNE HD QWERTY MINI WIRELESS KEYBOARD WITH TOUCHPAD
μπορεί να με ενδιαφέρει , εφ όσον μπορεί να αντικαταστήσει το remote, έχω ένα dune duo.
ναι μπορει.
Miniature wireless keyboard Dune HD Querty with embedded Touchpad is designed to control Dune HD media players (based on Sigma Designs SMP864x/SMP865x processors and higher), and also can be used with PC or Apple computers. Being used with Dune HD media players, this keyboard can completely replace a stock remote control and, of course, fully unleash the features of your Dune HD player, allowing to control it in even more easy and pleasant way. With the help of this keyboard you can enjoy various services, fully use the built-in Web browser, communicate with friends over the Internet. A clear advantage of Dune HD Querty is working on the 2.4 GHz frequency. This means that you won't need to point a remote control directly to the player - Dune HD Querty will be able to easily control your player even if it is located outside of a direct view or in a closed shelf.
hatzopou
