Most visitors online was 7182 , on 21 Nov 2025
ΚΑΛΗΜΕΡΑ ΣΑΣ. ΕΝΔΙΑΦΕΡΟΜΑΙ ΝΑ ΑΓΟΡΑΣΩ ΕΝΑ ΡΑΔΙΟCD H DVD ΑΥΤΟΚΙΝΗΤΟΥ ΤΑ ΧΡΗΜΑΤΑ ΠΟΥ ΔΙΑΘΕΤΩ ΕΙΝΑΙ ΜΕΧΡΙ 400 ΕΥΡΩ. ΠΟΙΑ ΘΕΩΡΕΙΤΑΙ ΟΤΙ ΕΙΝΑΙ Η ΚΑΛΥΤΕΡΗ ΑΓΟΡΑ ΣΕ ΑΥΤΑ ΤΑ ΧΡΗΜΑΤΑ; ΠΟΙΑ ΜΑΡΚΑ ΚΑΙ ΜΟΝΤΕΛΟ ΠΡΟΤΕΙΝΕΤΑΙ; ΤΟ ΠΡΟΗΓΟΥΜΕΝΟ ΠΟΥ ΕΙΧΑ ΗΤΑΝ ΕΝΑ JVC KD-SHX701
...[KEY FEATURES]
[GENERAL FEATURES]
- 4 x 50 Watt
- Flip-down detachable faceplate
- 14 Segment FL Display
- RDS Tuner
- DVD Video/MPG/JPG/MP3/WMA
- 2 RCA Preout
- Disc Changer Control Capability
- iPod /Bluetooth/DAB Ready
- OEM/IR Remote In
- Remote Control Unit Supplied
[AUDIO FEATURES]
- Flip-down Detachable Faceplate
- Security Code Function & DSI
- Rotary Encoder & Control Knob
- OSD (On Screen Display) Operation
- Installer & Backup Memory
- Amplifier Control System with PS Amplifiers
- EQ (Bass/Treble/Q Factor/Gain Control)
- Voltage/Current/Temperature/Fan Speed- Advanced B.M.S. with '02 PS Amplifiers
- B.M.S. with '99-'01 PS Amplifiers
- Digital Clock (24H)
- Selectable Key Illumination (Green/Red)
- IR-Remote Control Unit Supplied
[TUNER FEATURES]
- 4 x 50W max output power (MOSFET IC)
- 2 Preouts with 2.5V output level
- 1 RCA Video Output
- 1 Auxiliary RCA Line Input
- System E's+ (Built-in HPF/LPF)
- System Q-Ex (Preset & Full Manual Sound Control)
- Dual Zone Source & Volume Control
- Separate Bass/Mid/Treble Controt
- Source Tone Memory
- Fader & Loudness Control
- Attenuator with Smooth Volume Return
- Rear/Subwoofer/Audio Fixed Output (1.2V)
Switchable Preout- Subwoofer Reference Level Adjustable
- Built In Amp Mute
[DVD/CD FEATURES]
- 24 Presets: 18 FM, 6 LW/MW
- RDS Tuner with Radio Text
- K3I Clear Reception Tuner Circuit
- Auto Memory Entry (AME)
- Up/Down Seek Tuning
- Auto1/Auto2/Manual Tuning Mode
- FM Stereo/Mono Selector
[CONNECTIVITY]
- DVD Video Playback
- DVD±R/RW Compatible (Video Format Only)
- VCD Compatible
- WMA (Windows Media Audio)
- MP3 Decoder with ID-3 Tag Display
- MPEG 1/2 Video File (.mpg)
- JPEG File (.jpg) Playback
- 24-Bit D/A Converter
- CD Text Ready
- CD-R/CD-RW Compatible
- Direct Access with Remote
- Random/Repeat/Scan Play
- Dual changer control capability (CH1,CH2 & AUX)
- iPod ready (optional unit KCA-iP500)
- Bluetooth ready (optional unit KCA-BT100)
- DAB ready (optional unit KTC-9090DAB)
- 2-way Telephone/Navigation Mute
- OEM Wired Remote Output
- OEM Display Out
