Τα νέα ενισχυτάκια Itube με ασύρματο Ipod/Iphone Dock:
Wi-Tube Hybrid Valve Amplifier with FatDock
Main Features
* Vacuum Tube Amplifier with FatDock for Apple iPod or iPhone
* 28 watts of pure listening pleasure
* Valve processing gives warm, rich, audio characteristics
Specifications
* Power Output: 28Wx2
* Frequency Response: 20Hz - 20KHz (±1.0Db)
* Distortion: ≤0.5%
* Signal-To-Noise Ratio: ≥86Db
* Input Sensitivity: 400mV
* Input Impedance: 100KΩ
* Output Impedance: 4Ω, 8Ω
* Source Inputs: 2xRCA Pair, 1x3.5mm Aux
* Tubes Used: 6N1 x 1, 6N2 x 1
* Power Supply: AC100~120V/50~60Hz, AC220~240V/50~60Hz
* Dimensions: Amp (WxHxD) 230x178x118mm, Dock (WxHxD) 155x130x123mm
* Weight 4.5KGs
* Amp Type Hybrid
http://www.fat-man.co.uk/docs/product_07/Wi-Tube_Hybrid_Valve_Amplifier_with_FatDock.shtml
iTube 202 Valve Amplifier
Main Features
* 20 watts of Single-ended Class A amplification
Specifications
* Power Output: 20Wx2
* Distortion: ≤0.1%
* Signal-To-Noise Ratio: ≥87Db
* Input Sensitivity: 210mV
* Sub Out: Yes
* Source Inputs: 3xRCA Pair, 1x3.5mm Aux
* Tubes Used: 6N3 x 3, KT88 x 2
* Dimensions: Amp (WxHxD) 370x162x285mm
* Dock (WxHxD) 155x130x123mm
* Weight 12.5KGs
* Amp Type Class A Single Ended
http://www.fat-man.co.uk/docs/product_07/iTube_202_Valve_Amplifier.shtml
iTube 302 Valve Amplifier
Main Features
* 30 watts of superlative sonic quality
Specifications
* Power Output: 30Wx2
* Distortion: ≤0.1%
* Signal-To-Noise Ratio: ≥90Db
* Input Sensitivity: 250mV
* Sub Out: Yes
* Tubes Used: 12AX7 x 1, 6L6G x 4
* Weight 13KGs
* Amp Type Class AB Push Pull
http://www.fat-man.co.uk/docs/product_07/iTube_302_Valve_Amplifier.shtml
Και μία φωτό με το Dock:
Main Features
Specifications
* Distortion: ≤0.5%
* Weight 4.5KGs
* Amp Type Hybrid
Main Features
Specifications
* Distortion: ≤0.1%
* Sub Out: Yes
* Weight 12.5KGs
Main Features
Specifications
* Distortion: ≤0.1%
* Sub Out: Yes
* Weight 13KGs
