Gearbest - Universal Multi-functional Wrench
xfader
Universal Multi-functional House Used Socket Wrenches
Τιμή: $13.78
Καστάνια με καρυδάκι universal. Δείτε το video για να καταλάβετε τη λειτουργία της. Κατάλληλη για όλες σχεδόν τις οικιακές εργασίες.
1. Grip does the work of many tools, sets of sockets, standard and locking pliers, and an entire range of open end wrenches. The ingenious Grip makes half of your toolbox obsolete! It fits virtually anything. The one socket fits fasteners of almost any shape - square, hex, wing nuts, cup hooks, eye screws and even broken, stripped and rusted nuts other wrenches can't move.
2. No more reaching into your tool box, grabbing socket after socket until you find one that fits. The Grip instantly conforms and locks onto any shape nut, bolt or fastener.It won't slip off nuts or strip them. With Grip, you get the job done fast with no hassle and little effort.
3. The revolutionary socket design automatically adjusts to fit any nut or bolt from 1 / 4 inches to 3 / 4 inches , 7-19 mm! Works great on metric, standard, wing nuts, broken nuts, stripped nuts, eye bolts, square nuts, hexes and more! Save Time! Save Work!
JGmag
