ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
eatures:
24 bit/192kHz suspended CD Player
FREQUENCY RESPONSE: 20Hz - 25KHz @ +/- 0,3dB
THD (Total Harmonic Distortion): 0,08% Max.
SIGNAL/NOISE RATIO: 80dB
DYNAMIC RESPONSE: 125dB
OUTPUT LEVEL: 2,5V
OUTPUT IMPEDANCE: 800ohm
ANALOG OUTPUT: STEREO RCA and XLR balanced outputs
DIGITAL OUTPUT: 75 ohms RCA connector
SPEED FLUCTUATION: 0,0001% Max.
CONTROL DIGITAL SYSTEM: Zero-Clock™
POWER SUPPLY: Electro-Power™ 100 to 260Volt 50/60Hz super linear triple transfomer
DIMENSIONS: 480mm L x 250mm H x 450mm D
WEIGHT: 13,00 Kilos
http://www.goldenote.it//product.php/idp=34/id=124 bit/192kHz suspended CD Player
OUTPUT LEVEL: 2,5V
WEIGHT: 13,00 Kilos
