Integra AV Gear
INTEGRA DRX-8.4
11.4-Channel Network AV Receiver
Indianapolis, Ind. (February 28, 2023) — Integra® is pleased to introduce a flagship audio video receiver (AVR) to its line up of advanced electronics that will allow integrators maximum flexilbity and control, while saving them time and money. Packed with the most advanced technology, the all-new Integra DRX-8.4 11.4 150 watt-per-channel network receiver is the integrator-approved solution for the world’s finest home theaters.
Exhaustively tested and built through close working relationships with professional installers, this superior AVR exceeds high expectations with a full suite of integration software tools and XLR connectivity for long cable runs common in high-end home theater spaces. The Integra DRX-8.4 is compatible with remote monitoring platforms to help manage, configure and troubleshoot devices on the network, saving countless hours and expenses from truck rolls.
Included wireless Dirac Live® room calibration Full Version and an optional upgrade for Dirac Live Bass Control Multi Subwoofer, which uses machine learning and AI to quickly determine ideal settings for any layout. The Intergra DRX-8.4 AVR includes advanced music streaming and connectivity, built-in smart home assistants like Josh, Alexa, and Google. Roon Ready certification puts entire high resolution music libraries at your fingertips.
The whole home entertainment experience can be aligned with this state-of-the-art technology and fueled by studio-grade processing capability, including the industry’s highest performance 32-bit audio DAC to provide unprecedented dynamic range with ultra-low distortion. Extruded anti-resonant aluminum heat sinks and high-grade capacitors perfectly balance consumption and output requirements for optimal amplifier performance while IP control, web setup from your preferred browser, and onboard HDMI diagnostics make installing and managing the Integra DRX-8.4 AVR a breeze.
The Integra DRX-8.4 (US MAP $3,200) will be available Spring 2023 through authorized Integra integration partners.
The Integra DRX-8.4 joins the award-winning DRX series of Integra AVRs that was introduced in 2021, featuring Advanced CI tools such as remote monitoring, Dirac Live digital room correction, HDMI 2.1 and 8K for much higher bandwith, better audio, and faster gameplay, consistency and performance, Bluetooth transmitters with aptX for sharing audio to Bluetooth headphones, and so much more.
Integra DRX-8.4
Spec Sheet
Manual
More...
Τερατάκι :showingbiceps:
Εξαιρετικό αν λειτουργεί χωρίς bugs και εάν έχει αξιοπρεπείς μετρήσεις. Και η τιμή είναι κάτω από το 50% από τον ανταγωνισμό.
Μακάρι να λειτουργεί, θα σώσει το 99% των ενδιαφερομένων, μόνο οι πολύ πυροβολημένοι που είναι για trinnov περισσεύουν.
βγαινει και με XLR? Ναχαμε να λεμε δηλαδη. Μαλλον ακομη μονοδρομος ειναι ο ARCAM 41.
Έχει XLR για τα L/R/C/Sub1/Sub2.
Καλύπτει τους περισσότερους, τα υπόλοιπα κανάλια απο τα ενισχυτικά στάδια και αρκεί, μόνο κατι ανώμαλοι θέλουν τελικούς για όλα τα κανάλια. Ή ενεργά...
Εχει Dirac, Auro, Roon. Και ειναι απίστευτα φτηνό. Αν λειτουργεί κανονικά χωρίς bugs είναι σούπερ.
Εντελώς διαφορετικά μηχανήματα ο Integra με τον Arcam 41. Όπως τα είπε ο Dimi. Συν ότι ο Arcam έχει σχεδόν 6500€.
Ωχ!
o integra drx 3.4 πιστευετε οτι θα κρατά καλύτερα τα ρευματα σε πολυ καναλο σε σχεση πχ με τον denon 3800? στην μουσικη ο integra εχει αραγε την ιδια"κλινικη" χροια που είχαν οι ονκυο ?
o pioneer lx 505 Που έχει και αυτός ετοιμο το dirac και περισσοτερα βατ μήπως είναι πιο vfm απο τον 3.4?
George195
