KEF Muo
m1ts0s
News poster
Thanks to a clever new compact version of KEF’s legendary Uni-Q ‘point source’ driver array and a powerful new bass radiator, the MUO fills the room with stunningly accurate sound whose HF definition and LF extension far exceed the limits of ordinary portable speakers.
Along with the sophisticated digital-to-analogue converter and other high order internal components, these innovative drivers are mounted within an immensely rigid inner moulding encased in an acoustically inert aluminium shell. Streaming your tracks via Bluetooth aptX, you’ll be astonished by the sweet, natural treble, fluid midrange and clean, tightly controlled bass.
Synchronise a pair of MUO speakers for superb CD-like quality stereo reproduction or select ‘dual-connect’ party mode for large gatherings, so that everybody experiences the same superlative full-range response. Smarter still, MUO automatically optimises its output to suit upright or horizontal positioning, so you always enjoy the same remarkable acoustic depth and definition.
With most Android mobile devices, you can also benefit from the NFC ‘tap-to-pair’ function - just hold the device against MUO and they’re paired ready to stream your music in seconds. When not streaming your music wirelessly, connecting to any computer or mobile device via the 3.5mm Aux input is equally simple. MUO has a rechargeable battery with up to 12 hours of play time, and switches itself off automatically when not in use to prolong battery life.
MUO features an ingenious miniature version of KEF’s greatest innovation - the Uni-Q driver array. Continuously refined over nearly three decades, this acclaimed technology delivers an astonishingly wide soundstage that fills a room with full-bodied, stunningly clear sound, and reproduces the higher registers with pinpoint accuracy.
You can synchronise a pair of MUO speakers to stream superb CD-like quality stereo sound wirelessly via Bluetooth aptX.
For larger gatherings and parties, you simply select the ‘dual-connect’ mode that allows both speakers to replicate the same full-range response, so that everybody gets the full benefit of the music you’re playing.
http://www.kef.com/html/en/showroom/digital_music_solutions/muo/overview/index.html
Sugah
Ζαχαρούλης
Ωραία ντηζαινια και οι οπές στο σχήμα του Μουον.
Το επόμενο ηχείο θα λέγεται σκέτο Μου :p
m1ts0s
News poster
Ο λόγος που πόσταρα το Muo δεν είναι τόσο το ίδιο το προιόν. Μετά τα KEF X300A και τα EGG, η KEF παράγει ακόμη ένα ψηφιακό ενεργό ηχείο. Πιθανολογώ ότι ίσως δούμε και μεγαλύτερα ενεργά ηχεία από την KEF. Φανταστείτε τι θα γινόταν στην αγορά με μια ενεργή έκδοση τού LS50 (ή του Blade 2).
[...] Πιθανολογώ ότι ίσως δούμε και μεγαλύτερα ενεργά ηχεία από την KEF. Φανταστείτε τι θα γινόταν στην αγορά με μια ενεργή έκδοση τού LS50 (ή του Blade 2).
Αυτό θα ήταν μια πολύ ενδιαφέρουσα εξέλιξη την γκάμα προϊόντων της KEF! Ειδικά, εάν αναλογιστούμε το γεγονός ότι το LS50 έκανε τρομερή αίσθηση όταν κυκλοφόρησε, η - πιθανή - ενεργή έκδοσή του, ίσως να ήταν αρκετή για να "ταρακουνήσει" κραταιές/παραδοσιακές εταιρίες στην αγορά των ενεργών ηχείων.
Θάνος Γαλάνης
