Klipsch KL-7800-THX Ultra2 Certified In-Wall LCR
Πωλείται 3άδα Klipsch KL-7800-THX Ultra2 Certified In-Wall LCR σε άριστη κατάσταση, 1200 ευρώ
(τιμή Amazon $800/τεμαχιο)
http://images.klipsch.com/KL7800THX_635042118261740000.pdf
FREQUENCY RESPONSE 80Hz-20kHz ± 3dB
SENSITIVITY 91dB @ 2.83 volts / 1 meter
NOMINAL IMPEDANCE 8 ohms
CROSSOVER FREQUENCY 2300Hz
POWER HANDLING 150 w max continuous (600 w peak)
ENCLOSURE MATERIAL/TYPE DRIVE COMPONENTS
Sealed Enclosure
Two-way system using one 1" (2.5cm) Titanium dome compression driver in a 5" 80 ̊ x 80 ̊ Tractrix horn and an 8" Aluminum Cone Woofer
WEIGHT 17.5 lbs. (7.9kg)
HEIGHT 20.8" (52.7cm)
WIDTH 11.8" (29.8cm)
MOUNTING DEPTH 3.7" (9.4cm)
CUT OUT DIMENSIONS 19" (48.3cm) x 10" (25.4cm)
FINISH White with Brushed Aluminum Facia
Τηλ. 6981109380
και προτάσεις για ανταλλαγές δεκτές...
  • n_olympios
    Μαντιναδόρος!
    Chauncey Gardiner * tl;dr *
geo kok
