Klipsch Reference RF-83 Speaker System
Κώστας Φ.
Bigger Is Better
Sure, using small satellites with a powerful subwoofer can sound great, but it's not the same as using a large system. The big ones sound more of one piece, complete, and therefore more "correct." It was an easy enough theory to check; I just went into my Sunfire pre/pro's bass management and switched back and forth between the Large and Small speaker settings—and Large sounded more together. Klipsch's director of product planning, Jim Garrett, summed up the appeal of big with this: "There's no replacement for displacement." It's true—big systems really do possess huge performance advantages over even the better small ones. If you've got the space to accommodate the Klipsch Reference RF-83 speaker system, by all means, check it out for yourself.
Highlights
  • Knock-your-socks-off sound
  • Room-correcting subwoofer really lets you feel the shake and quake
Ratings:
Build Quality: 93 Good
•The RF-83 towers have a hefty weight of 100 pounds each
•The triangular RT-12d sub exudes strength
Value: 94 Good
•Towers and center are made in the United States
•Furniture-grade real-wood veneers
Features: 94 Good
•These high-efficiency speakers bring out the best from even moderately powered receivers
•Horn-loaded tweeters' controlled dispersion minimizes floor and ceiling reflections
Performance: 97 Excellent
•Equally spectacular with music and movies
•High-resolution sound is effortless
•References convey full-on, feel-it-in-your-guts dynamics
Ergonomics: 90 Good
•The system is big and heavy, definitely a two-person unboxing and setup job
•The RT-12d's auto room-correction system makes subwoofer setup a breeze
Overall Rating: 95 Excellent
The top-of-the-line Reference system from Klipsch not only delivers full throttle home theater Sturm und Drang, it sounds sweet with music.
Full Review: hometheatermag.com
παληκαρι μαλλον δεν ειδες καλα
υπερηχητικο και σταματα στους 20 χιλιαδες κυκλους
τοτε τι να πουν αλλα ηχεια που ανεβαινουν στους 40
οσο για το υποηχητικο κατεβαινει κατω απο τους 20
παλι οχι
μαλλον εντυπωσιαζεσαι απο την εμφανιση
για την ανομοιογενια της μπροστινης 3αδας ουτε λογος
δεν εχει σημασια η σχολη αλλα αυτο που λες
οτι και αν υποστηριζεις καλο ειναι να παραδεχεσαι οτι κατι μπορει να ειναι καλυτερο απο αυτο που σου αρεσει
επισεις καλο θα ειναι να ακουσεις και αλλα ηχεια
ανοιγεις οριζοντες-πλουτιζεις την εμπειρια σου
αυτο το τελαυταιο ισχυει για καθε τι. Οχι για να μην δινεις δικαιωμα να σε κρινουν αλλα για να γεμιζεις εμπειριες και γνωσεις
ισως ετσι μια μερα δεις ΚΑΙ ΕΣΥ τα κλιπσ και τα καθε κλιπσ με αλλο ματι
Ειμαι της σχολης του το ψαχνω:cool_4:
συμφωνω κατα το ενα σκελος του πειραματισμου και επισης εννοειται οτι υπαρχουν καλυτερα ηχεια και εννοειται οτι θα υπαρχουν παντα αναλογα τα βαλαντια
στην εκθεση θα κατεβεις
αν ναι θα δεις ωραια πραματα
δεν λεω τι μην θεωρηθει διαφημηση
αλλα μιλαμε για τρελλα ηχεια
αν νομιζεις οτι επειδη λεω τη γνωμη αυτη ειναι κακολογηση δικαιωμα σου
οπως δικαιωμα μου να τα θεωρω λιγα μπροστα σε αλλα ηχεια
and another thing
μη βρεθεις καμμια φορα μπροστα σε αλλα καλυτερα ηχεια απο τα κλιπσ
γιατι τοτε θα καταλαβεις οτι υπαρχουν και καλυτερα ηχεια απο τα κλιπσ και
οσο πιο πολλα καλυτερα ηχεια ακους τοσο πισω θα μενουν τα κλιπσ
teufel, jamo ,revel, mirage, sunfire, phase technology και αλλα επιδεικνυουν τεχνολογια αποδωση προσεγγυση τοση που αν πανε οι παλιομοδιτικες κορνες να πρασουν το ποταμι και να δουν τι γινεται απο την αλλη μερια απλα θα πνιγουν
με μεγαλη ευαισθησια κινεζικες μοναδες (ασχετα αν παιζουν καλα φτιαχνονται στην κινα ) δεν γινεται να πλησιασεις αυτο που οι αλλοι κανουν
    Shalom
    Chauncey Gardiner * tl;dr *
MORPH
