Κώστας Φ.
I gotta give it to Marantz, this combo looks sexy as hell. The AV8003 Networking AV Preamp/Processor on top is compatible with nearly anything you want to send it and has v1.3a HDMI inputs. The preamp also features built-in video processing that provides de-interlacing and up-conversion to 1080p. A full copper plated chassis and extensive internal shielding make this unit nuclear detonation proof so you'll be able to watch movies in your post-apocalyptic bungalow.
The MM8003 8-Channel Power Amplifier on the bottom has a rated output of 140 watts per channel and can handle low impedances. The amp offers both balanced XLR as well as unbalanced RCA jacks for input, and offers the same nuclear fallout resistance as the preamp so you can watch Blast from the Past over and over and eat radioactive popcorn. Both the amp and preamp are expected to be available later this Summer.
What Hi-Fi is also reporting that the highly anticipated Marantz BD8002 Blu-ray player has been pushed back to a September release and will be priced at less than $3,000.
* Digital Media Player for Ethernet
- Audio, Video and Photo (supporting DLNA)
* Video Scaler Up to 1080p
* HDMI V1.3a: 4-in/2-out
* Dolby TrueHD, dts HD, Deep Color
* DSD (SA-CD), Auto Lip Sync
* XLR Pre Output Terminals
* XLR Audio Inputs for SA-CD
* Multi Room Component Video Out
* RC2001 Main Remote(PC Programmable, Learning)
* RC101 Sub Remote(for Multi Room Control, Learning)
* HD Radio / XM Ready / Sirius Ready
* THX Certified
* Copper Plated Chassis
* Toroidal Power Transformer
* New Clean Front Panel
* Price: $2599.99
MM8003 8 Channel Power Amplifier
* 140W x 8ch (8 ohms) Power Amplifiers
* Low Impedance Continuous Drive Capability
* Current Feedback Amplifier Circuit
* Massive Toroidal Power Transformer
* Slow Start to Power On
* 8ch XLR Input Terminals
* DC Trigger Control Inputs, DC Power Status
Outputs, IR Flasher Input Terminals
* Output Channel Relay On/Off Control
by Remote Signal (to Multi Zone Use)
* Gold Plated Speaker Terminals
* Marantz Designed Storage Capacitors for Quick
Response to Rapidly Varying Sources
* New Clean Design Front Panel
* Price: $2399.99
Πηγή: audiojunkies.com
