Καλησπέρα παιδιά πωλειται ο ενισχυτής του τιτλου σε ΥΠΕΡΑΡΙΣΤΗ κατάσταση, γνωστή η ποιότητα ήχου του... Τιμη 500ευρω (αγορασμενος 1.050ευρω)
Χαρακτηριστικά:
Power and processing:
Χαρακτηριστικά:
- 7-channel amplifier
- 110 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
- individual image adjustments for each video source
- dual PLL anti-jitter circuit for cleaner picture from all sources
- Dolby® TrueHD, DTS-HD™ Master Audio, Dolby® Digital Plus, DTS-HD™ High Resolution Audio, Dolby® Digital EX, DTS-ES™, Pro Logic® IIx, Pro Logic® IIz, SRS Circle Surround II, and DTS Neo:6 decoding
- Audyssey Laboratories' MultEQ® XT Pro enables eight-point user auto setup and room calibration and professional sixteen point calibration (microphone included)
- Audyssey Dynamic Volume mode to keep listening levels steady
- Audyssey Dynamic EQ™ for fuller sound at lower listening levels
- M-DAX (Marantz Dynamic Audio eXpander) for better sound with compressed music sources
- three-room/three-source output
- powered and line-level stereo audio output for 2nd room
- line-level stereo audio output for 3rd room
- only analog sources can be played in the 2nd and 3rd rooms
- listen to music from iPod®, iPhone®, or other portable music player through the front-panel USB input
- DLNA certified to ensure optimal compatibility with other network-enabled equipment
- Internet streaming capabilities for Internet radio, PANDORA® Internet radio, Rhapsody® and more (may require registration and subscription fees)
- Bluetooth-ready with added Marantz RX101 adapter
- high-current amplifier design
- Pure Direct mode switches off all unused circuitry for the cleanest possible sound
- back surround speaker channels re-assignable for bi-amping front left and right speakers
- 192kHz/24-bit digital-to-analog converters for all channels
- 1080p-compatible HDMI digital video switching (7 in, 2 out)
- second HDMI output will run identical program to first to connect to two HDTVs or a TV and a projector
- analog-to-HDMI video upconversion (up to 1080p)
- HDMI version 1.4a with support for 3D video, Audio Return Channel, Deep Color, x.v.Color, SACD, auto lip-sync, and HDMI-CEC
- component video switching (2 in, 1 out)
- digital audio inputs: 2 optical, 2 coaxial
- 8 audio/video inputs, including:
- 1 front-panel input with composite
- 4 rear-panel inputs with composite video
- 2 audio-only inputs including a phono input for a turntable
- dual line-level outputs for powered subwoofers
- phono input to connect turntable
- 7.1-channel analog audio preamp input
- 7.2-channel analog audio preamp output for connecting an amplifier
- front-panel USB port for audio playback from compatible iPods, USB flash drives, hard disk drives, and portable MP3 music players
- RS-232C port for automated control systems
- detachable power cord
- direct IR flasher input, and 12V DC trigger out
- 2 sets of main speaker outputs
- free Marantz remote app lets you use your iPod touch®, iPhone® or Android™ device as a Wi-F remote
- on-screen display for easier system setup and operation
- graphic user interface via HDMI
- first-time setup wizard
- multibrand remote
- 17-3/8"W x 6-5/16H" x 15-5/16"D
- weight: 26 lbs.
