vlasis
Φωτογράφος!
Paradisea+ Vacuum Tube USB DAC
590 Δολλαριααααααααααα???????????????????????????????
Legendary Paradisea DAC now comes to version 3.
Non-Oversampling DAC,
Same circuit as older Paradisea with a little different in PCB trace layout.
CS8414 digital input with non-oversampling structure.
This is traditional DAC, cannot decode HDCD signal.
The digital signal accepted is based on the capability of CS8414 digital receiver, which means the max: 96KHz in Spdif format.
Utilize legendary Philips TDA1545A multi-bits (16 bits) DAC chip.
OP Amp: LM4562 (LF453CN also recommended)
1 x USB input, 1 x Coaxial input, 1 x Toslink optic input.
Tube buffered output, tube instocked GE5670
Tubes can be used: 5670, 2C51, 396A, 6385, 6CC42, 6386, 6N3,
6854, CV2575, CV4013, CV5894, CV8247, CV2381
115/230V power supply selectable from internal PCB jump pins setting
Output 2.0V, < 800 ohms,
Dimension: 28cm(L) x 15cm (W), 7.5cm (H)
Weight: 1.6Kg (3.4lb)
Ε ρε γλεντιααααααααααααααααααααα
http://www.positive-feedback.com/Issue38/mhdt_paradisea.htm
Διαβαστε .......και τα λεμε.....
