Review: Audyssey MultEQ XT Pro Sound Equalizer
Απάντηση: Review: Audyssey MultEQ XT Pro Sound Equalizer
There are maybe a half dozen products over the last 15-20 years that have changed the industry because of what they’ve done. The Audyssey Sound Equalizer Pro is on that list. It’s one of those products that I’d be lost without.
– Frank Filipetti, Grammy Award Winning Music Producer
The Audyssey Sound Equalizer with MultEQ Pro genuinely enhanced the sound of my system…Once it was installed, I could simply leave it alone and enjoy a more transparent and coherent soundstage . . .
—Kalman Rubinson, Stereophile
Don't even consider buying another piece of equipment until you hear this unit, this will be the biggest and most cost effective upgrade you will ever make to your system . . . period.
—Phil Hinton, Editor, AVForums.com
I consider Audyssey Laboratories' new Sound Equalizer component to be the most comprehensive and accurate audio calibration tool ever . . . The realization of powerful, tight and articulated bass, seamless and completely cohesive sound from all channels and crystal-clear dialogue is unbelievable.
—Patrick Hart, CE Pro Magazine
Absolutely amazing! Balance, delays, image, stage—all perfect. Response curves, resonance management, all that impossible stuff—apparently possible after all.
—Stephen St. Croix, Mix Magazine
Απάντηση: Re: Review: Audyssey MultEQ XT Pro Sound Equalizer
Σιγουρα δεν τον χαλανε .............τον ΠΗΔΑΝΕ !!!
και για να μη ξεχνάμε, οι δυό A/D & D/A εν σειρά μετατροπείς, τον "πηδάνε" τον ήχο...
αχ....
και τι ειναι ο καρλ λιουις στα νιατα του ?
και οπως ειχε πει ο τσακιριδης ας μαζεψουμε πρωτα ολα τα αλλα και μετα βλεπουμε
ακου εκει αλα εις υψος
ο #1 αλτης ειναι ο χωρος , .........................
Manosmathiou
