Sharp AQUOS LC-57GE2 1920X1080 LCD TV
Χρήστος Ακρατόπουλος
Sharp Corporation announces the introduction into the Japanese market of the LC-57GE2 AQUOS 57V-Inch*1 Full-Spec High-Definition LCD TV that achieves a contrast ratio (1500:1), response rate (4 msec) and viewing angle (176°) at the world’s highest levels*2. This new model features a newly developed 57V-inch black Advanced Super View full-spec high-definition LCD panel with resolution of 1,920 H x 1,080 V pixels that brings out all the stunning image quality and detail of digital HDTV broadcasts.
The newly developed 57V-inch black Advanced Super View full-spec high-definition LCD panel uses newly developed color filters to achieve a high contrast ratio (1500:1). By increasing the tonality of black hues, it reproduces true-to-life, velvety blacks in darkened rooms, while allowing users to enjoy sharp, clear pictures even in bright rooms. Moreover, the world’s fastest*3 response rate of 4 msec enables the LC-57GE2 to reproduce sharp, crisp images even of high-speed full-motion video such as sports scenes or fast-moving on-screen subtitles or scrolling text (“crawls”). Plus, the wide viewing angle of 176° side-to-side and top-to-bottom minimizes changes in color and reduces “white washout” when the screen is viewed from a skewed angle. Users will experience impressively beautiful, high-quality images on a big screen.
Further, the LC-57GE2 utilizes a newly developed Hybrid Backlight System based on a combination of red LEDs and fluorescent tubes to expand the reproducible color gamut to 95%*4 of the NTSC color space*5. This means superb rendering of a diverse range of intermediate tones such as the bright color of healthy skin.
The evolved LCD panel technologies and imaging technologies brought together in this model enable Sharp to offer the LC-57GE2 as a large-screen, full-spec high-definition TV that delivers the utmost in high-end video reproduction based on the dramatically improved contrast, video response, viewing angle and color reproduction naturally demanded in a big screen.
Major Features
1. Newly developed 57V-inch black Advanced Super View full-spec high-definition LCD panel with resolution of 1,920 H x 1,080 V pixels
1) Contrast ratio of 1500:1, with increased tonality of black hues (800:1 on Sharp’s previous LC-45GD1 model)
2) Quick 4-msec response rate, the world’s fastest*3, reproduces fast-moving images crisply and clearly
3) Wide viewing angle of 176° side-to-side and top-to-bottom means beautiful images no matter where the screen is viewed from, minimizing color changes on the screen even when viewed from a skewed angle
2. Newly developed Hybrid Backlight System based on a combination of red LEDs and fluorescent tubes
*1 “V-inch” is a measure of the true size of the flat TV screen, standardizing on the length of the diagonal dimension of the actual viewing area.
*2 As of September 20, 2005, for LCD televisions with screen sizes 50V inches and larger.
*3 As of September 20, 2005, for LCD televisions.
*4 Based on the 1976 CIE Chromaticity Diagram.
*5 Compared to the color gamut that can be reproduced when the range of reproducible colors under the NTSC color space is regarded as 100%. NTSC refers to the existing TV video standard used for terrestrial analog broadcasts formulated by the National Television System Committee.
Product name Full-Spec High-Definition LCD TV
Nickname AQUOS
Model name LC-57GE2
Design type Side-speaker design
Suggested retail price
(before-tax price) 1,522,500 yen (1,450,000 yen)
Date of introduction in Japan December 1, 2005
Monthly production 1,000 units
Specifications
Product name LCD color TV
Model name LC-57GE2
LCD panel Screen size 57V-inch
(125.1 H x 70.4 V cm; 143.5 cm on the diagonal)
Drive system TFT (thin-film transistor) active-matrix drive
Dot count 1,920 H x 1,080 V pixels
Screen brightness 450 cd/m2
Viewing angle Vertical: 176°, horizontal 176° (CR=10)
Backlight source Internal (built-in fluorescent tube and red LEDs)
Speakers 8.0-cm diameter x 2, 2.5-cm diameter x 2
Max. audio output (JEITA) Total 20.0 W (10.0 W + 10.0 W)
AC power supply voltage 100 V AC, 50/60 Hz
Power consumption 585 W
Standby power consumption 0.5 W
Main unit dimen-sions
Display section only 140.8 W x 15.3 D x 83.1 H cm
With speakers 165.2 W x 15.3 D x 83.1 H cm
With speakers and table stand 165.2 W x 43.5 D x 94.1 H cm
Main unit weights
Display section only Approx. 60.5 kg
With speakers Approx. 68.0 kg
With speakers and table stand Approx. 75.0 kg
TV reception channels
VHF channels 1 to 12
UHF channels 13 to 62
Cable TV channels 13 to 63
Digital BS channels 000 to 999
Digital CS110° channels 000 to 999
Digital terrestrial channels 000 to 999
(with cable TV pass-thru)
Input/output jacks
Composite video input (4 sets)
S2 video input (2 sets)
D4 video input (2 sets)
HDMI input
DVI-I input (with audio input jack)
Center speaker input
Monitor output (combined with S2 jack, doubles as video input 4 and recording output jack)
Headphone output
Digital audio output (optical)
External speaker
i.LINK (TS) S400 (2 sets)
PC card slot
B-CAS card slot
Terrestrial analog antenna input
Terrestrial analog antenna output
Terrestrial digital antenna input
BS/CS110° antenna input
Telephone line (56 kbps)
LAN (10Base-T/100Base-TX)
Video controller
AC power input
Accessories
Table stand (assembled with main unit)
Speakers (1 set)
Speaker bracket cover (1 set)
Wireless remote controller
AAA dry cell battery
Stand opening cover
AC power cord
Antenna cable
BS/CS110° antenna cable
Telephone cable
B-CAS card
Modular splitter
Video controller
Tipover-prevention hardware (1 set)
Cable clamp set (1 set)
Operation manual
Warranty card
Ioanniss
