Sharp XV-Z2000
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Sharp to Introduce New Home Theater Projector
Thanks to its DLP™ System, the XV-Z2000 Realizes Hi-Vision (High Definition) Quality
Sharp Corporation has introduced the XV-Z2000 Hi-Vision Home Theater Projector based on the DLP™ system*1 to deliver high-quality, high-definition images into the Japanese market.
As the DMD™ projection device*2, the heart of DLP™ systems*1, the XV-Z2000 uses the latest DMD™ HD2+ chip set, the same device incorporated into our high-end projector model*3, featuring significantly improved light utilization efficiency. The XV-Z2000 delivers Hi-Vision (high definition) image resolution (1280 x 720 pixels) combined with a high contrast ratio of 2500:1. Viewers will enjoy rich, vivid video images with outstanding color depth, a wide dynamic range and superb image quality.
Plus, combining this optical technology with a powerful 275W lamp, the XV-Z2000 yields a brightness of 1,200 lumens, approximately 70% brighter than our previous model*4, and realizes superb image quality with rich, vivid and life-like color tones. In addition to reproducing natural colors even more vividly, viewers can enjoy impressive 100-inch big-screen pictures even in rooms as small as 3.5 meters square thanks to the 1:1.5 short focal length lens. Moreover, even when the XV-Z2000 is mounted on the ceiling, the motorized zoom lens makes it possible to adjust the screen size and focus using the remote control unit.
The XV-Z2000 is being offered as a Hi-Vision Home Theater Projector combining high image quality with high image resolution, plus a diverse range of installation options and adjustment features.
Product name Home Theater Projector
Model name XV-Z2000
Suggested retail price 522,900 yen
(498,000 yen before tax)
Date of introduction December 10, 2004
Monthly production 1,000 units (total worldwide)
Major Features
1. Hi-Vision (high definition) compatibility plus high contrast (2500:1) based on the DMD™ HD2+ chip set.
2. Combines a powerful 275W lamp with the optical system and realizes a brightness of 1,200 ANSI lumens.
3. 1:1.5 Short Focal Length Motorized Zoom Lens makes it possible to project big-screen, 100-inch pictures even rooms as small as 3.5 meters square
XV-Z2000 Specifications
Model XV-Z2000
Projection device Size 0.8-inch DMD™ (Digital Micromirror Device™) x 1 (HD2+)
Drive system DLP™ system
Number of pixels 1280 x 720 pixels
Lens 1:1.5 motorized zoom and focus; F2.0 to 2.5;
f=21.3 to 31.6 mm
Projection lamp 275 W
Brightness 1,200 ANSI lumens (High Brightness mode)
Contrast ratio 2500:1 (High Contrast mode)
Center-to-corner uniformity ratio (CCR) Greater than 85%
Horizontal resolution 720 TV lines (with 750p DTV input)
500 TV lines (with NTSC input)
Projected image size 40 to 200 inches
Projection distances 40-inch image (1.0 to 1.5 m)
100-inch image (2.6 to 3.9 m)
200-inch image (5.3 to 7.9 m)
Rated supply voltage 100 to 240V AC (multi-voltage)
Rated line frequency 50/60 Hz
Power consumption (max.) 360 W (standby: 6 W at 100 V AC)
Operating temperature range 5° to 35°C
Storage temperature range –20° to 60°C
Video system compatibility Compatible with BS digital Hi-Vision broadcasts (1125i/750p/525p/525i)
NTSC/PAL/PAL-M/PAL-N/SECAM
Computer RGB input XGA, SVGA, VGA
Input jacks Component inputs 3 jacks:
RCA (3-pin) x 2
DVI-I x 1 (doubles as computer input)
Composite inputs 2 jacks:
S-video x 1; RCA x 1
Computer input 1 jack (doubles as component video input)
Other connectors RS-232C serial port
(9-pin D-Sub x 1)
Remote control IR receiver ports Front panel x 1; rear panel x 1
Main body dimensions 310 W x 89 H x 282 D mm (not including
protruding parts)
Weight 4.3 kg
Supplied accessories Remote control (“glow-in-the-dark” type), power cord, lens cap, etc.
daemon76
