Sony MV-700HR Portable DVD Station
Extra slim design => New concept with screen facing outwards for ease of use
7 inch TFT screen => Superb image quality and extra wide viewing angle
Built in CD / DVD player => Plays back all regular Audio CDs and Video DVDs
MP3 / DivX Playback => To listen to or to watch compressed files
AC adaptor supplied => For use at home
Theft secured car cradle => One button attach/detachability
IR transmission to headphone=> For use with optional MV-02HP headphone
Battery operation (approx. 3H) => Together with optional MV-100BAT (optional)
Available in 2 colours: Silver and Black (MV-700HRS, MV-700HRB)
Sony Europe has announced the launch of a new portable DVD player for 2005 – The Sony MV-700HR (MV700HR) is a completely new DVD station concept. As opposed to existing laptop designs the Sony screen faces out, allowing it to fold neatly, taking up less space and provides a new way to enjoy movies. It comes in 2 colours, silver and black (MV-700HRS, MV-700HR).
The Sony MV-700HR Portable DVD Station
The Sony MV-700HR does not only read regular DVDs but is also compatible with DivX so that you can enjoy compressed video. It also reads traditional CD-R and MP3 files, meaning you can also listen to music, making this a truly compatible product that won’t let you down.
In addition to the CD/DVD drive, the Memory Stick slot enables you to listen to MP3 files or to display the jpeg pictures you have just shot with your Sony Cyber-shot digital camera or Sony Handycam while on the go.
The Sony MV-700HR is supplied with an AC adaptor for in-home use as well as a cigar adaptor for in-car use. With the optional battery MV-100BAT, you can add up to 3 hours battery life, offering true mobility, so you can take it wherever you go.
To make in-car use even more convenient, an in-car kit is supplied. This consists of one easy to install cradle that can be fixed to the passenger’s headrest. The DVD station connects to this cradle in one simple click. It also comes with an additional AV input, allowing you to watch any other source on the DVD station monitor.
Wherever you are, the Sony MV-700HR is the solution to keep everybody entertained. This portable, fully compatible, theft secured and fully equipped portable DVD station will bring even more fun to your life.
Η SONY έρχεται να αλλάξει κάποια δεδομένα στον χώρο του φορητού DVDp.....
Ξεκινώντας απ' την σχεδίαση, σε αντίθεση με τα υπόλοιπα, το νέο SONY διπλώνει, καταλαμβάνοντας πολύ λιγότερο χώρο, αφού η οθόνη του βρίσκεται στην εξωτερική μεριά της συσκευής.
Απ' την άλλη, η ίδια η εταιρεία παρέχει ένα αξεσουάρ ιδανικό για την χρήση στο αυτοκίνητο.
Είναι μία βάση που μπαίνει στις πλάτες των μπροστινών καθισμάτων. Η σύνδεση είανι απλή, ενώ μέσα απ' την είσοδο σήματος AV μπορούμε να πάρουμε εικόνα και ήχο από άλλη πηγή (όπως πχ ένα TV tuner που μπορεί να υπάρχει μπροστά....)
Έτσι λοιπόν, μπορείτε να κρατήσετε το ενδιαφέρον των παιδιών σε μία ταινία στο πίσω κάθισμα κατά την διάρκεια ενός ταξιδίου, αφού η οθόνη TFT των 7" έχει το κατάλληλο μέγεθος για χρήση στο αυτοκίνητο, αλλά βέβαια θα μπορούσαν απλά να ακούσουν μουσική ή ακόμα και να δουν τις φωτογραφίες από την ψηφιακή φωτογραφική μηχανή που τραβήξατε στην εκδρομή (μέσα από το Memory Stick slot)
Τα πλεονεκτήματα δεν σταματούν εδώ, αφού η συσκευή μπορεί πολύ χαλαρά να χρησιμοποιηθεί και στο σπίτι με την χρήση του ειδικού μετασχηματιστή (που συνοδεύει το μηχάνημα....) (στο αυτοκίνητο τα πράγματα είναι απλά, χρησιμοποιόντας την θέση του αναπτήρα σας....)
Τέλος, μπορεί κανείς σαν έξτρα, να αγοράσει την μπαταρία MV-100BAT που προσφέρει 3 ώρες αυτονομία ώστε να έχετε την οθόνη μαζί σας ακόμα και κατά την διάρκεια του......πικ-νικ!!!
Οι δε χρωματικές επιλογές είναι δύο (όπως είδατε στις φωτογραφίες.....) Μαύρο και ασημί!!
Πληροφορίες:
Κόστος: περίπου 450 ευρώ
Οθόνη: TFT 7"
Υποστηρίζει: CD,DVD, MP3/DivX, JPG
Μπαταρία: MV-100 BAT (3 ώρες διάρκεια)
Έξτρα λειτουργίες: Μετάδοση IR στα ακουστικά, αντικλεπτική βάση αυτοκινήτου, υποδοχή MEMORY STICK, 2 χρώματα!!
  • rose.athens
intergrale
