Sony VPL-VW1000ES 4k για σπιτι
Απάντηση: Sony VPL-VW1000ES 4k για σπιτι
Ετοιμαστείτε για Blu ray players + ταινιες που να υποστηριζει το μηχανακι :114:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Και εδω οι πρωτες ενυπωσεις.
Εντυπωσιαστικες, εκτος του πρωτου κλιπ που ηταν upconversion
At yesterday's Sony press conference, the company didn't demonstrate the new VPL-VW1000ES 4K projector—that had to wait until this morning at Sony's booth on a Stewart Ultramatte 150 screen measuring 180 inches diagonally. As with most Sony presentations, this one was mostly talking and not much demo material, but that material was worth the wait—except for the first clip, which was from Resident Evil at 1080p upconverted to 4K. The clip exhibited severe banding and solarization, which I learned was due to sourcing and processing issues, not the projector. (The original file was 16-bit, which was truncated to 10-bit in the server and then 8-bit for HDMI to the projector.) Also, this clip was projected using Motionflow frame interpolation, which I don't mind, but Tom Norton objected to that more than the banding.
By contrast, the trailer for The Amazing Spider-Man due next year was in native 4K from the server, and it looked, well, amazing. Detail was stunning, and the blacks were better than yesterday's showing of the same clip from the Sony 4K digital-cinema projector. After the formal presentation, I confirmed that the VW1000ES can indeed accept a 4K signal over a single HDMI 1.4 connection. Of course, that won't help most consumers see native 4K content, which will be nonexistent for at least a couple of years to come.
http://www.hometheater.com/content/sony-vpl-vw1000es-demo
"Of course, that won't help most consumers see native 4K content, which will be nonexistent for at least a couple of years to come."
Ουφ, τη γλυτώσαμε προς το παρόν.......
Nelsy
Ιεράπετρα
Τότε ποιος ο λόγος που θα κυκλοφορήσει στις αρχές του 2012;;;
επειδή θα βγάλει η JVC ;;;:116:
Γιατί, κάτι αντίστοιχο δεν έγινε με τις τηλεοράσεις? Είχες 3D τηλεόραση, αλλά έψαχνες υλικό (όχι εγώ, άλλοι)........:116:
ελατε ρε παιδια
δεν εχουμε πει
απο μπριζα σε μπριζα
το χρημα να γυρναει γυρω γυρω
τι 4Κ
σε ποσες ιντσες ειναι οφελειμο ?
ποσοι μπορουν αυτες τις ιντσες .......
αλλο, αλλο πειτε τωρα παμε στο 8Λ .....
ελατε ρε παιδια
δεν εχουμε πει
τι 4Κ
Η διαφορα Αναργυρε θα ειναι εμφανες σε ολους.....
...δεν μιλαμε για ηχο που αλλος τακουει και αλλος οχι.... μιλαμε για εικονα που θα βλεπουν ολοι την οποια διαφορα......
.....ποιο πολλες λοιπον διαβαθμισεις-χρωμα-πυκνοτητα.....
θεωρω οτι τωρα θα δουμε ωραια......δλδ σε 2 χρονια....:116:
....καπου διαβασα οτι ηδη υπαρχουν πανω απο 50 ταινιες ετοιμες......:116:
Λοιπον.......
καδρο 239:1 = 4096 x 1714
καδρο 185:1 = 3996 x 2160
Εδω ειναι το χρωματικο τριγωνο μιας μηχανης 4k και του film
..το μικρο τριγωνο ειναι το γνωστο μας rec 709
Oπως βλεπετε θα δουμε αλλα πραγματα......
[/IMG]
καπου εκει στο sw3 της δευτερης τριλογιας ο θειος ειπε στον ανακιν
: μην αφουγκραζεσαι το μελλον εις βαρος του παροντος.
Λοιπον να μιλαμε για προιοντα του τοτε ισως ειναι λιγο ατοπο.
Περι αναλυσης θες ιντσες για να δεις το 4Κ
αλλα οπως ξαν ειπα αυτο ερχεται πακετο με απιστευτη φωτεινοτητα, και τρελλο κοντραστ (πως αλλιως να δειξεις αξιποπρεπη εικονα σε καδρο ανω των 200 ιντσων)
Στον κοσμο μας τωρα
ακομα δεν εξορηιστηκε το dvd απο τα ραφια των βιντεο κλαμπ , μιλαμε για 4Κ
εκτος βεβαια (πολυ πιθανο) να υπαρξει ενα hyper super scaler που να κανει το απλο μπλε 4Κ.
και εννοηται αλλες πηγες ...αλλα....αλλα......
ας περιοριστουμε στα ονειρα και στις σκεψεις για τωρα ...μετα βλεπουμε
Οσο αφορα την αναλυση ενα htm εγραφε πριν πολλα χρονια οτι απο καποια αναλυση και πανω θες πολλες ιντσες .
Αλλιως δεν βλεπεις τιποτα.Αν σκεφτουμε οτι βια να βλεπουμε 150 ιντσες.
Τα αλλα καλουδια ομως τα θελουμε εδω και τωρα.
Μιλαμε για περισσοτερη πληροφορια Αναργυρε........η ιντσες δεν εχουν σχεση καρδια μου....
Οταν θα δεις 4κ και 2κ διπλα -διπλα σε 110" να θυμασε αυτο που λες τωρα....:116:
Ειναι γεγονος πως το 4κ ειναι δυσκολο γιατι πρεπει να αλλαξουν πολλα......ομως η αρχη εγινε....
....λες η sony να εβγαλε 4κ σπιτικο ετσι για πλακα...!!!!!!
οταν δεις διπλα διπλα σε 110 ιντσες 2 προβολια (ενα χρεπι -ενα καλο ) βλεπεις αλλα πραματα
για να δεις 4Κ καλο θα ηταν να βλεπεις κατι ισοδυναμο στα υπολοιπα (πλην αναλυσης) χαρακτηριστικα
αλλιως βλεπεις ενα απειρο κοντραστ και μια εκτυφλωτικη φωτεινοτητα , στοιχεια που μονα τους λενε τοσα
θα δουμε/.....
πανα δουμε το γαυρακο σε λιγο και μετα τους νεους πειρατες σε μπλε , μετα κανουμε τις σκεψεις μας
την συζητηση αυτη (οχι για 4Κ ) την ειχα κανει με τον μανωλη εδω και χρονια.
Σημαντικοτερο θεωρει το δισκακι να ειναι 4Κ απο οτι ο προβολεας.Περισοτερα στον ιδιο.
Το link δεν αναφέρεται ακριβώς στο προκείμενο.
Όπως γράφει ο Κώστας, αφού το πουλάνε, θα βγάλουν και υλικό τελικά.
Ελπίζω σύντομα να μπορέσουμε να δούμε ένα, να μας λυθούν οι απορίες γιά το αν είναι μούφα. :126::126:
roberto_portale
