gkontoletas
trouble in my brain
Ένα Hi-End καλώδιο ρεύματος παρουσίασε η TEAC, το 7N-PC9100 MEXEL
Χαρακτηριστικά: (από μετάφραση στο babelfish)
- Conductor: Stressfree 7N class Cu MEXCE×2 (core line: 0.32 Main twist of the φ ×50 it adjusts), Stressfree 4.5N class Cu×1 (the core line: 0.32 Main twist of the φ ×50 it adjusts)
the insulator: Polyolefine resin
- seal: Braided polyurethane tunic copper wire (4N) + copper Mylar tape
- structure: 3 core twist structures
- internal sheath: The polyolefine resin (the tungsten powder body + amorphous powder body + carbon it kneads and is packed)
- the external sheath: ULTRAVIOLET RADIATION polyurethane
- power plug: Special phosphorus bronze double buff (mirror surface) processing (wall thickness 24K gold direct plating + palladium plating)
- IEC connector: Special phosphorus bronze (wall thickness 24K gold direct plating + palladium plating)
- cable major diameter: Approximately 15.5mm
Τιμή: 2500 euros 1.5m, 650 euros ανά 0.5m επέκτασης.
