ΦΑΝΤΑΣΤΙΚΗ ΤΗΛΕΟΡΑΣΗ TOSHIBA REGZA 32R3500PG!!!
ΟΛΟΚΑΙΝΟΥΡΓΙΑ ΣΦΡΑΓΙΣΜΕΝΗ ΣΤΟ ΚΟΥΤΙ ΤΗΣ ΑΓΟΡΑΣΜΕΝΗ 31/8/2009!!! ΜΕ ΤΑ ΧΑΡΤΙΑ ΤΗΣ ΚΑΙ ΤΗΝ ΕΓΓΥΗΣΗ!!!
ΜΟΝΟ 500€
Από κατάστημα αγορός-πώλησης καινούργιων και μεταχειρισμένων ειδών
Επικοινωνία στο 210 8829651
ΧΑΡΑΚΤΗΡΙΣΤΙΚΑ:
Product Type 32" LCD TV
Series REGZA R Series
Digital Television Certification HD ready
TV Tuner 1x analogue
Video Interface Component, composite, HDMI, SCART
PC Interface VGA (HD-15)
HDCP Compatible Yes
Dimensions With stand
Width 80 cm
Depth 28.9 cm
Height 59.2 cm
Weight 16.7 kg
Enclosure Colour Black, silver
Display
Diagonal Size 32" - widescreen
Technology TFT active matrix
LCD Display Technology AMVA
Resolution 1366 x 768
Display Format 720p
Image Aspect Ratio 16:9
100Hz Yes
Dynamic Contrast Ratio 9000:1
Brightness 500 cd/m2
Progressive Scan Progressive scanning (line doubling)
Viewing Angle 178 degrees
Pixel Response Time 8 ms
Features Dynamic Contrast, DCDi (Directional Correlational Deinterlacing), Active Vision M100, Real Digital Picture, Pixel PROcessing IV, REGZA LINK, 3D Color Management
TV Tuner
Analogue TV Tuner NTSC, PAL, SECAM
Reception System SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
Video Features
HD Ready Yes
Analogue Video Input Signals PAL, SECAM, NTSC4.43
Input Video Formats 1080p, 480p (via Component sockets), 1080i (via Component sockets), 480i (via Component sockets), 720p (via Component sockets), 576i (via Component sockets), 576p (via Component sockets)
Teletext Yes
Teletext Memory 500 pages
Remote Control
Type Universal remote control - infrared
Audio System
Sound Output Mode Stereo
Surround Mode Built-in
Sound Effects SRS WOW
Speakers Included 2 speakers
Output Power / Total 50 Watt
Speaker(s) 2 x right/left channel speaker - built-in - 25 Watt
Connections
Connector Type 1 x SCART (AV in/out / RGB) ( 21 PIN SCART )
1 x SCART (AV in/out / S-Video) ( 21 PIN SCART )
1 x composite video input ( RCA phono )
1 x component video input ( RCA phono x 3 )
2 x HDMI ( 19 pin HDMI Type A )
1 x VGA input ( 15 PIN HD D-Sub (HD-15) )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x subwoofer output ( RCA phono )
1 x audio line-in ( RCA phono x 2 )
1 x fixed audio output ( RCA phono )
1 x audio line-out ( RCA phono x 2 )
Stands & Mounts
Stand Included Built-in
Stand Design Tabletop
Flat Panel Mount Interface 200 x 200 mm
Power
Power Device Power supply - internal
Power Consumption Stand by / Sleep 0.9 Watt
ΜΟΝΟ 500€
ΧΑΡΑΚΤΗΡΙΣΤΙΚΑ:
HDCP Compatible Yes
Width 80 cm
Depth 28.9 cm
Height 59.2 cm
Weight 16.7 kg
Display
Display Format 720p
100Hz Yes
TV Tuner
Video Features
HD Ready Yes
Teletext Yes
Remote Control
Audio System
Connections
Stands & Mounts
Power
