Led προβολέας, 20.000 ώρες λειτουργίας, DarkChip3 και τιμή κάτω από 1.500€!
http://www.perfectimage.gr/2014/07/17/viewsonic-pro9000/
- 0.65″ Digital Micromirror Device (DLP™), 1080p DarkChip3™
- Resolution
- 1920 x 1080 (native)
- Lens
- 1.2x manual optical zoom / manual optical focus
- Zoom Factor
- N/A
- Keystone
- Vertical digital keystone correction (+/- 15º)
- Display Size
- 38″–150″ / 0.97m–3.8m (diagonal)
- Throw Distance
- 4.9ft–16.4ft / 1.5m–5.0m
- Throw Ratio
- 1.5:1 ~ 1.8:1
- Lamp Type
- LED/Laser Hybrid
- Lamp Life (normal/eco-mode)
- >20,000 hrs
- Brightness
- 1600 Lumens
- Contrast Ratio
- 4000:1 (dynamic)
- Aspect Ratio
- 16:9 (native), 4:3, Auto
- Color Wheel
- N/A
- Color Depth
- 30 bits, 1.07B Color (10+10+10)
- Color Gamut
- 85% NTSC 1931 CIE
INPUT SIGNAL
- Computer and Video
- NTSC M (3.58 MHz), 4.43MHz, PAL (B, D, G, H, I, M, N, 60), SECAM (B, D, G, K, K1, L), 480i and 576i, 480p and 576p, 720p, 1080i, 1080p
- Frequency
- Fh: 15–100KHz, Fv: 24–85Hz Video:24-85 Hz
COMPATIBILITY
- PC
- VGA to 1080p
- Mac®
- Up to 1080p (requires MAC adaptor)
CONNECTOR
- Audio Input
- 3.5mm mini jack
- Audio Out
- 3.5mm mini jack
- RGB Input
- 15-pin mini D-sub (x2) / 15-pin mini D-sub
- Composite Input
- RCA jack
- S-Video Input
- 4-pin mini-DIN
- Component
- N/A
- RGB Output
- 15-pin mini D-sub
- Control
- RS-232 (DB-9)
- Digital
- HDMI 1.3 (x2)
- Network
- N/A
- USB
- N/A
- Mic-In
- N/A
- Screen Trigger
- N/A
- Card Reader
- N/A
AUDIO
- Speakers
- 2W (x2)
- Amplifier
- N/A
POWER
- Voltage
- 100~240VAC (Auto Switching), 50/60Hz (universal)
- Consumption
- <186W ±10% / <0.5W (stand-by mode)
CONTROLS
- Basic
- Power, keystone, arrow, blank, menu, exit, mode, enter, auto, source, volume, info
- OSD
- picture, video/audio, setting, options (See user guide for full OSD functionality)
OPERATING CONDITIONS
- Temperature
- 32ºF–104ºF (0ºC–40ºC)
- Humidity
- 10%–90% (non-condensing)
- Altitude
- Altitude 0~6,000 ft (1,800m), operational up to 10,000 ft (3048m)
NOISE LEVEL
- Normal
- 28dB
- Eco-Mode
- 22dB
DIMENSIONS (WxHxD)
- Physical
- 12.6 x 5.3 x 10.2 in. / 321 x 133 x 260 mm
- Packaging
- 17.6 x 15.7 x 9.6 in. / 447 x 398 x 243 mm
WEIGHT
- Net
- 9.4 lb. / 4.3 kg
- Gross
- 15 lb. / 6.8 kg
