Mytek Digital Brooklyn
m1ts0s
News poster
The New Brooklyn • DAC • Headphone • Preamplifier •
Brooklyn DAC was just introduced on Oct 1 at the Rocky Mountain Audio Fest in Denver. Brooklyn is a highly anticipated DAC Preamplifier and the first stand alone DAC to incorporate future MQA streaming decoder. Brooklyn will be shipping starting in early December 2015 and will be available on first come, first served basis.
Inputs
Built-in Analog Preamp: Line level input or Phono M/M, M/C input, relay controlled.
Available digital inputs: USB2 Class2 (OSX driverless, all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), SDIF3 DSD up to DSD256.
All digital inputs can be routed into computer via USB2. Allows connection of external digital sources such as CD Players and digitizing ADCs.
Outputs
Analog outputs: RCA, balanced XLR, simultaneous
Headphone outputs: Reference High Current, High transient Headphone Amp, 500mA, 6 Watts, dual headphone jacks, designed to drive hard to drive headphones.
Built-in Attenuator: Choice of 1dB step analog attenuator, separate for main out and headphones, 1dB step digital 32 bit attenuator and purist relay bypass.
Mytek M-Clock™
0.82ps internal jitter, Wordclock Input and Output (allows stacking multiple units for multichannel operation, includes mch DSD)
Formats
Conversion: up to 384k, 32bit PCM, native DSD up to DSD256, DXD, 130dB Dynamic Range
Built in certified hardware Hi-Res MQA decoder
Other
Apple remote included, universal remote capable.
Worldwide power supply, optional DC/Battery Power input; 7-14VDC
Two year warranty.
Firmware: Upgradable via USB Control panel
$1995
http://preorder.mytekdigital.com/
Φαίνεται πολλά υποσχόμενο μηχάνημα. Το 2016 θα δούμε πολλά σαν κι αυτό εξοπλοσμένα σαν αστακούς. Αναμένεται και το ifi audio pro. Θα ήθελα πολύ να το ακούσω μιας και και έχω πολύ καλή εμπειρία από το mytek 192. Ακόμα δεν υπάρχουν πληροφορίες και φωτογραφίες από το εσωτερικό του.
Ευκαρία να αγοράσουμε εμείς το Mytek 192 σε καλή τιμή. Αλήθεια, θα είναι σε θέση να ακούσει οποιοσδήποτε αισθητές διαφορές σε σχέση με το παλιό, πολύ περισσότερο τόσο αισθητές που να αξίζει η αναβάθμιση; Πολύ αμφιβάλλω.
Διαφορές θα υπάρχουν σίγουρα. Το θέμα είναι πόσο αισθητές θα είναι. Σίγουρα όμως είναι πιο καλά εξοπλισμένο και με περισσότερα features.
Διαφορές σίγουρα θα υπάρχουν. Το πόσο θα ακούγονται και θα μπορούν να εκτιμηθούν θα εξαρτάται απο το υπόλοιπο σύστημα και φυσικά τα γουστα και την εμπειρία του ιδιοκτήτη.
Ο αρχισχεδιαστής και Ιδρυτής της Mytek Michal Jurewitz δήλωσε οτι "The Brooklyn DAC has been redesigned from the ground up. The results are sonically superior but that’s only the beginning."
Αυτή η δήλωση αν την συνδυάσει κανείς με τις νέες πατενταρισμένες τεχνολογίες που ενσωματώνει το νέο ντάκ όπως το νέο πατενταρισμένο ρολόι "Mytek Femtoclock Generator (tm)” και την δυνατότητα υποστήριξης DSD απο όλες τις ψηφιακές εισόδους καθώς και την πιστοποιημένη ενσωματωμένη υποστήριξη του MQA της Meridian μέσω υλισμικού η οποία μπορεί να υποννοεί και την ενσωμάτωση άλλων τεχνολογιών απο της Meridian όπως τα περίφημα Apodising ψηφιακά της φίλτρα, μπορεί λοιπόν να υποθέσει κανείς οτι το Brooklyn δεν είναι απλά μια αναβάθμιση του 192 που ακόμα και τώρα πoυ μιλάμε είναι ένα απο τα καλύτερα ντάκ στην κατηγορία του..
Η Meridian φαινεται να σοβαρεύει το παιχνιδι με το MQA προοθώντας το πλέον επιθετικά με τις στρατηγικές συνεργασίες με το TIDAL και την 7digital μέσω των οποίων θα προσφέρεται τέτοιο υλικό φαντάζομαι σύντομα ενώ παράλληλα κάνουν την εμφάνιση τους οι πρώτες συσκευές συμβατές με ΜQA άπο άλλους κατασκευαστές όπως το νέο λαχταριστό Dap της Pioneer και φυσικά το Brooklyn της Μytek.
H Mytek φαίνεται να επενδύει σοβαρά στο νέο αυτό format σαν selling point και σαν μελλοντική λειτουργία που σταδιακά θα καταστεί απαραίτητη. Για όσους θυμούνται όταν πρωτο εμφανίστηκε ο πρόγονος του Brooklyn το 192 DSD Dac και πάλι τότε είχε επενδύσει στο DSD κάτι πρωτοποριακό για την εποχή και με αμφίβολο μέλλον. Η τότε απόφαση τους αποδείχτηκε σωστή όπως γνωρίζουμε όλοι πια.
Στην RFMAF που έλαβε χώρα λίγες μέρες πρίν Παρουσιάστηκε το Μytek Brooklyn σε συνδυασμό με το MQA μέσω ΤIDAL streaming. Μία γεύση απο το μέλλον τουλάχιστον σύμφωνα με τις δύο εταιρίες.
Ανεβάζω και μια φωτό απο το event στην οποία φαίνεται και το Brooklyn Dac δίπλα σε ένα MacBook Pro 15". Έχω την εντύπωση οτι το νέο ντάκ είναι μεγαλύτερο σε διαστάσεις απ οτο 192. Μακάρι να είχαμε και μία εικόνα το εσωτερικού. Περισσότερα στην σελίδα του MQA sto facebook. https://www.facebook.com/mqasound?fref=ts
Μίλησα με τον εδώ εισαγωγέα τον Κυριο Χατζηστάμου της Athens Pro Audio καιμου είπε οτι το πρόγραμα προπαραγγελιών θα τρέξει κανονικά στην Ελλάδα. Σε δύο εβδομάδες περίπου θα έχουν οριστικοποιηθεί και οι λεπτομέρειες μαζί με την τιμή η οποία αναμένεται να είναι ιδιαίτερα ανταγωνιστική.
Για όποιον ενδιαφέρεται..
Οι απαντήσεις απο το support της Μytek που έλαβα σήμερα ρίχνουν φώς σε πολλά ερωτηματικά και το κυριότερο επιβεβαιώνουν στην πράξη το οτι το Brooklyn είναι όντως ολοκαινουρια σχεδίαση απο το μηδέν και όχι μια απλή βελτιωση του 192. Διαβάστε παρακάτω.
Dear Petros,
Please find all answers below.
(...) Is the ESS silicon still being used and if yes what chip?
Yes we still use ESS chip.
(...) Have you opted for an XMOS based USB receiver, something that driverless OS X support suggests?
The USB2 port (designed by us) will be driverless (OSX & Linux).
We use XMOS for MQA.
(...) Have you replaced the TC electronic based dsp and antilitter signal processing with something made In house part of which is the trade marked “Mytek Femtoclock Generator (tm)" you have announced ?
Yes, there is M-Clock based on Femto Clock technology.
(...) Even though I believe you have already answered to that question is USB OTG supported? (Thanks for the MQA by the way, a very promising feature!!)
It will be supported.
(...) Is any wireless connection feature even as a future retrofitted upgrade? Bluetooth APTX might not be all about Sound Quality but IS very handy!!
For now wireless connection is not supported.
(...) Does the optional outboard power supply suggest a future in house upgrade ?
It is for external power source. There will not be any upgrade of power section.
(...) Is the Inboard power supply Linear like that of the 192?
There is efficient switching power supply.
(...) And finally is the phono option of analog or digital function? I wish for the latter since the best real world phono stages I have heard so far are digital (Metric halo any Devialet)
There is analog input - I am not shure what you mean?
Best regards,
Slawomir Rybarczyk
Ενα τελευταιο update. Το τσιπ εσωτερικα θα ειναι το 9018 η θυρα usb δεν θα ειναι γαλβανικα απομονωμενη.
Επισης θα αλλαξουν λιγο την οθονη απο τα πρωτοτυπα που παρουσιασαν.
[...] η θυρα usb δεν θα ειναι γαλβανικα απομονωμενη.[...]
Γνωρίζεις το λόγο; Είναι απλά θέμα κόστους; Ρωτάω γιατί θεωρώ ότι η συγκεκριμένη απόφαση "αφαιρεί πόντους" από το μηχάνημα (με άλλα λόγια, πιστεύω ότι θα ήταν καλύτερα εάν η θύρα USB ήταν γαλβανικά απομονωμένη). Εάν κάνω λάθος, διορθώστε με.
Δεν τον γνωρίζω φίλε μου αλλα επειδή ούτε το προηγουμενο το οποίο είχα για τρία χρόνια είχε.Αυτό δεν ακύρωνε το οτι ήταν ένα απο τα κορυφαία ντάκ της κατηγορίας του. Δεν υπάρχει λόγος φυσικά να επεκταθώ όποιος γνωρίζει για τί μιλάμε και έχει εικόνα για τα προιόντα τη Μytek δεν θα θεωρουσε το θέμα σημαντικο. Φυσικά κανείς δεν εμποδίζει κανέναν να έχει τις όποιες εντυπώσεις. Έχε υπόψην σου πάντως οτι πολλά γαλβανικά απομονωμένα ντάκ είναι σαφώς κατώτερα αλλων στην ίδια κατηγορία και δεν ανταπεξέρχονται στο Hype που τα συνοδεύει.
gonis
Luger
Γιατί το παίρνεις προσωπικά;
Μιλάμε για μια συσκευή που θα χρησιμοποιηθεί από επαγγελματίες αλλά και από χομπιστες.
Και γνωρίζουμε ότι το προηγούμενο είχε θέματα θορύβων που ένας επαγγελματίας μπορεί να το διαχειριστεί ενώ ένας χομπιστας πιθανόν να πανικοβληθει...
Δεν πήρα κάτι προσωπικά, απλά απάντησα σε μια ερώτηση που μου έγινε προσωπικά. Αν αναφέρεσαι στο dc που βγάζει το 192 όταν ανάβει και σβήνει αυτό δεν έχει καμία σχέση με την γαλβανική απομόνωση της USB θύρας.
Παιδιά να μήν παρεξηγηθώ το οτι μου αρέσει εμένα δεν σημαίνει οτι δεν υπάρχουν και άλλες επιλογές. Όποιον τον χαλάει κάτι σαφως και μπορεί να προτιμήσει κάτι άλλο. Δεν έχω κανέναν λόγο να λάβω θέση υπέρ ή κατά του προιόντος.
    Chauncey Gardiner * tl;dr *
geo kok
