Η Oppo στην Ελλάδα
Απάντηση: Re: Η Oppo στην Ελλάδα, νέα αρχή
Τα καλα νεα....αλλα λιγο υπομονη.
Νεο firmware, πολλα υποσχομενο.
Διαβαστε μονο, αμα το βρειτε καπου μην το βαλετε πριν το ποσταρει η Oppo και πριν μαθουμε οτι ειναι σταθερο.
Παρακαλω μη βαλετε το link αν το δειτε καπου.
Το firmware αυτο ειναι και για το 83 και για το 83SE.
Release Information:
Release date: December 22, 2009.
Category: Public Beta Version
Main Version: BDP83-48-1218B
Loader Version: BE2650 or BT0350
Sub Version: MCU83-25-0811
Release Notes:
Comparing to the previous official release version BDP83-40-0925, the major changes included in this version are:
    1. Blu-ray Disc compatibility improvement, especially for certain titles such as the European version of "Terminator Salvation", Indican's "The Wonder of It All", and "(500) Days of Summer" from Fox.
    2. Subtitle shift feature. During playback, press and hold the "SUBTITLE" button to activate the function and then use up/down arrow buttons to move the subtitle. The shift position is saved in the "Video Setup" - "Display Options" section of the setup menu. This feature is useful for customers with 2.35:1 projection screens.
    3. OSD position feature. The OSD (On-Screen Display) can be moved to work together with the subtitle shift feature. There is a new setup menu item in the "Video Setup" - "Display Options" section for this.
    4. Auto mode for HDMI Audio format. The new "Auto" mode enables the player to use bitstream audio output for audio formats that are supported by the A/V receiver, and LPCM for formats that cannot be decoded by the A/V receiver.
    5. Setup menu changes. Some items are re-grouped into the "Display Options" sub-menu under "Video Setup". Some items are re-ordered in the menu structure to improve the ease of use.
    6. Experimental feature - home network streaming. This feature can be accessed from the "My Network" icon in the "Home Menu" screen. It requires a DLNA-capable media server running on your computer. The supported media types are the common set of what the player can decode and what the media server can stream.
    7. Experimental Feature - BluTV. This is an interactive television service that will initially feature channels such as casual games, widgets and movie art. To use this feature, the "BD-Live Network Access" item in the "Network Setup" section and the "Secondary Audio" item in the "Audio Format Setup" section of the player's setup menu must be turned on.
All features and improvements of the previous firmware are also included in this version.
Special!!!
gor
Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Α ρε oppoστόλη, μου έφτιαξες τη μέρα!
Re: Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Θα σου τη φιαξω ακομα πιο καλα σε σενα και σε ολους.
ΔΟΥΛΕΥΕΙ......:615:
Public Beta Release
Category: Public Beta Release
Installation Instructions and Download Link: Click Here
Firmware Upgrade via a USB Thumb Drive
  1. Click here to download the firmware file BDP-83-48-1218B.zip
Επαναλαμβανω :
  1. πριν την αναβαθμιση, κρατηστε σημειωμα με τις ρυθμισεις που εχετε κανει, αν εχετε κανει.
  2. μετα την αναβαθμιση, παντα κανουμε reset to factory defaults
  3. στο video setup----> TV System ---> Multi System
Το αρχικο μενου εχει αλλαξει, μη σας φανει περιεργο.
Αν κατι απο τα νεα experimental δεν δουλευει καλα, θα το δουμε.
Εγω στο δικο μου το περασα και ολα καλα. Δεν το ξετιναξα λογω φορτου εργασιας σημερα αλλα τα βασικα τα παιζει.
Προσεχτε, με ηρεμια και ολα θα πανε γρηγορα και καλα.
Καλου κακου εδω ειναι οι Ελληνικες οδηγιες
Οποιος δε θελει να το κανει μονος του, απο Δευτερα με ενα τηλ. να το φερει να το κανουμε και να φυγει.
Καλα Χριστουγεννα.....:605:
Ωραία νέα, ιδιαίτερα αυτά για το network streaming.
Βάλτε το, δουλέψτε το και μετά την πρωτοχρονιά που θα επιστρέψω, αν όλα σας έχουν πάει καλά, θα το βάλω κι εγώ στο δικό μου :)
gor
Το έβαλα και το έτρεξα! Πραγματικά πολύ ωραίο το καινούριο menu με τα εικονίδια! To DLNA το χρησιμοποίησα, αλλά όχι αρκετή ώρα και με αρκετή αφοσίωση ώστε να τα καταφέρω να βγάλω ασφαλή συμπεράσματα. Πολύ καλύτερο όσον αφορά το χειρισμό (έχει FF, RW, Pause, Play) των video από το Home Media Center του DLNA της Kuro 5090H, αλλά και πάρα πολύ καλή εκτέλεση 720p video, χωρίς το παραμικρό σπάσιμο ή artifact. Επίσης, το menu του Home Media Center του OPPO ζουμάρει σε άσχετες στιγμές κόβωντας το περίγραμα και μεγενθύνοντας το menu (bug). Περιέργως, δεν μπόρεσα να εντοπίσω τον εξωτερικό σκληρό (συνδεδεμένο μέσω USB με το PC) και δεν μπόρεσα να δώ MKV αρχεία. Θα ξαναδοκιμάσω όμως, γιατί ήταν πολύ βιαστική η ματιά που έριξα. Η Oppo αποδεικνύει πάντως ότι δεν κάθεται στα αβγά της και συνεχώς βελτιώνει ένα προϊόν που έτσι και αλλιώς δεν έχει αντίπαλο.
NP: ORFF - Carmina Burana, Atlanta Symphony Orchestra and Chorus, Telarc SACD
Κι εγώ μόλις τελείωσα την αναβάθμιση/ρυθμίσεις/ψάξιμο. Με λίγα λόγια το νέο firmware "τα σπάει"!!! Χίλια μπράβο στην Oppo που συνεχώς εξελίσσεται.
Ρε παιδια εχει συγκρινει κανεις το SE με καποιο καλο cd player εγω εχω το pd s06 pionneer (2000) τροποποιημενο που μου ειχε στοιχισει με σημερινα λεφτα περιπου 1500 € ελεγα ομως με τα νεα dac θα υπηρχε διαφορα προς το καλυτερο - τελικα το βαρυ και καλυτερο σαν transport κανει τη διαφορα με πιο πλουσιο ηχο- επισης και στα dvd δεν ειδα διαφορα σε συγκριση με το toshiba E1 hd-dvd σε προβολεα 720 ομως
σαν SACD παιζει καλυτερα απο cd
βεβαια σε σχεση με την τιμη του κανει πολλα απλως περιμενα την υπερβαση
Με μπέρδεψες. Τελικά τι δοκίμασες και τι έπαιξε καλύτερα; Βάλε και καμιά τελεία.
Καλησπερα και Χρονια Πολλα.
Μολις τελειωσα τη διαδικασια .Ολα ΟΚ εκτος της αναβαθμισης του loader version(!!). Aποστολε να προσπαθησω παλι ή δεν ειναι κατι σημαντικο?
Το δοκιμασα σαν CD , SACD , DVD-A , DVD-V ,BLU RAY απλως σαν CD & DVD-V ειχα και μετρο συγκρισης
Τι εκανε το loader ? μηνυμα ?
Το player παιζει ?
Δες στο setup / firmware info : loader version.
loader versions :
fw v.0430 : BE23F3 857523F3
fw v.0620 : BE2403 85752403
fw v.0905 : BE2600 or BT0300
fw v.0925 : BE2600 or BT0300
fw v.1218B : BE2650 or BT0350
Πιο firmware ειχες πριν κανεις αναβαθμιση ?
Tip : κατα την αναβαθμιση του loader φτανει στο 62% και μετα τελειωνει αστραπιαια.
Αν εγινε αυτο ολα καλα.
Επισης οταν ολοκληρωθει η αναβαθμιση το player σβηνει μονο του. Εγινε κατι τετοιο ?
Ευτυχως το πλευερ παιζει.
Πριν την αναβαθμιση ειχα τα εξης
main version BDP83-38-0905
Loader version BE2600 85752600
Sub version MCU83-24-0630
Chip version OB.00.01.00
Mετα την αναβαθμιση εχω:
main version BDP83-48-1218Β
Sub version MCU83-25-0811
Το μηνυμα δεν το συγκρατησα.Ηταν κατι σαν update could not complete successfully.
Πραγματι, μετα την αναβαθμιση το πλευερ εσβησε μονο του , αφαιρεσα το στικακι και το εθεσα σε λειτουργια.
Θα κανω ζημια αν το ξαναπερασω?
ΥΓ Σορυ φορ δε τραμπλ.
Τελος συναγερμου!
Εκανα την ιδια ΑΚΡΙΒΩΣ διαδικασια και αυτη τη φορα αξιωθηκα να δω:
Loader version BE2650 85752650.
Merry Christmas and Happy New Year to all!
Τελος συναγερμου!
Ολα καλα λοιπον...:615:.
Μια ερωτηση : μηπως τη πρωτη φορα που απετυχε, ειχες δισκακι μεσα ? Ειναι ο μονος λογος για τον οποιο μπορει να μη δουλεψει η αναβαθμιση του loader, οπου loader για οποιον δεν γνωριζει ειναι το drive.
Να υπενθυμισω για μια ακομα φορα οτι κατα την αναβαθμιση δεν πρεπει να υπαρχει δισκος μεσα στο player και κανενα USB συνδεδεμενο.
Και κατι νεοτερο. Απο το v.925 και μετα, το firmware ελεγχει τη γνησιοτητα του player και του λογισμικου. Δεν γνωριζω το λογο αλλα ξερω οτι εμφανιστηκαν στην Αγγλια player αγορασμενα απο ε-παραλια, που ηταν κρασαρισμενα, δυο τον αριθμο μεχρι στιγμης. Επισης κυκλοφορει ενα firmware απο κινεζικο site, που υποσχεται το region-free. Το συγκεκριμενο αν μπει, δεν δεχεται καμια αναβαθμιση μπρος η πισω και κλειδωνει τη περιοχη 2.
Απάντηση: Re: Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Nope.
Eιναι μεν παραξενο αλλα εκανα ακριβως τα ιδια βηματα και δουλεψε 100% με τη δευτερη προσπαθεια. Αλλωστε η διαδικασια ειναι πολυ απλη για να κανεις καποιο λαθος - απλα ακολουθεις τις οδηγιες που εμφανιζονται.
gor
Εμείς που έχουμε μη εγκεκριμμένο hardware εγκατεστημένο (region free kit) θα έπρεπε να ανησυχούμε για αυτο;
Re: Απάντηση: Re: Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Οχι, εφ οσον προκειται για το κιτ που βαζουμε εμεις.
Για κατι αλλα, δεν εχω ιδεα.
:111: Τι μη εγκεκριμενο αφου η ιδια η ΟΡΡΟ το διαθετει στον Απόστολο..??
Εννοεις οτι υπαρχει και αλλο κιτ αγορασμενο απο αλλη πηγη εκτος ΟΡΡΟ ..??
Το κιτ δεν το στελνει η Oppo Digital, αλλα ερχεται απο την Αγγλια.
Για το συγκεκριμενο και εφ οσον τοποθετηθει απο εμας, καλυπτεται απο την εγγυηση και αυτο και το μηχανημα.
οκ... εληφθη ... σημασια εχει η εγγυηση του μηχανηματος και η σωστη αντιμετωπιση απο την twin digital
κατι που ειναι δεδομενο και μεχρι τωρα λειτουργει αψογα.
intergrale
