Η Oppo στην Ελλάδα
BDP-80
Αν και η επισημη πρωτη ειναι για τη Δευτερα 25/1 , παρτε το νεο bluray απο την oppo : BDP-80
Τι ΔΕΝ εχει σε σχεση με το BDP-83 :
- ABT2010 VRS by Anchor Bay ( "System-on-Chip" with Custom Firmware)
- DVD 24p Conversion
- Dedicated Stereo Output
- SACD output over Analog : PCM only
- Front Panel : Plastic with black brushed metal appearance
- IR In/Out Ports
- RS-232 Remote Control
- Remote Control : Glow-in-the-dark
- DLNA : not yet
Περισσοτερα απο Δευτερα, ημ/νια αφιξης και τιμες οταν ερθει η ωρα.
Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Oppo Unveils Sub-$300 Blu-ray Player
OPPO On Monday, January 25, Oppo Digital is launching the BDP-80, the "lower-cost" Blu-ray player model the company recently hinted at (see blu-ray.com, December 22). It is a BD-Live (profile 2.0) player, based on the same decoder chipset and firmware as the acclaimed BDP-83. It also supports DVD-Audio and SACD playback, and multichannel analog audio output. It is priced at $289 and will soon be available for purchase on the Oppo website.
Overview
The BDP-80 is a full-featured universal Blu-ray Disc player that supports BD Profile 2.0 (BD-Live and BonusView), DVD-Video, DVD-Audio, Super Audio CD (SACD), HDCD, CD and other popular media formats such as AVCHD, MKV video files, digital photos and music.
For video, the BDP-80 features an HDMI 1.3 port that supports 1080p Full HD, 1080p 24Hz, Deep Color (30-bit and 36-bit) and Source Direct modes. Component video, S-Video and Composite video connections are also available for legacy analog displays. The player can upconvert DVD from standard definition up to 1080p. Unique features such as subtitle shift and vertical stretch zoom mode makes the player an ideal source component for home theaters with 2.35:1 CIH (Constant Image Height) displays.
For audio, the BDP-80 supports internal decoding and bitstream output of the latest sound formats including Dolby TrueHD and DTS-HD Master audio. The BDP-80 also features a configurable 7.1-channel analog output that can be set as 7.1-channel, 5.1-channel, or stereo. When playing SACD, the BDP-80 can output DSD (Direct Stream Digital) over HDMI in its native format or convert it into high-resolution PCM. For compatibility with many legacy A/V receivers and DACs, the BDP-80 also provides an optical and coaxial digital audio output.
The initial setup features an Easy Setup Wizard. Setup menus on the player can be accessed without interruption to disc playback. The front and back USB 2.0 ports enable easy access to music, photo and video files. The BDP-80 comes standard with 1GB of internal storage built-in so that no additional memory card or flash drive is needed to use BD-Live and BonusView features.
The BDP-80 supports NTSC and PAL, and NTSC/PAL conversion. Like the BDP-83, it as a universal power supply, and HDMI CEC.
BDP-80 and BDP-83 compared
The main differences between the two models can be found on a product comparison page:
Video:
* Video processor: the BDP-80 doesn't have the ABT2010 video processing, and handles all video processing tasks using its main decoder chip.
* DVD upconversion: the BDP-80 doesn't support 24p upconversion of DVD material.
Audio:
* Analog audio:
o Digital-to-analog converters and analog driving stage: the BDP-80 uses the same components as on the (now discontinued) DV-983H up-converting DVD player; on the BDP-83 and BDP-83SE, the DACs and analog driving stage are more "sophisticated."
o Outputs: the BDP-80 features a configurable 7.1-channel output that can be set as 7.1-channel, 5.1-channel or stereo; the BDP-83 has a dedicated stereo output in addition to the 7.1-channel output.
o SACD output over analog: the BDP-80 outputs PCM over analog for SACD playback, while the BDP-83 supports PCM and DSD.
* Digital audio: over digital connections, the BDP-80 and BDP-83 have "very similar capabilities and performances."
Other features:
* Front panel appearance: the BDP-80 is plastic with black brushed metal appearance; the BDP-83 is heavy-gauge black brushed aluminum.
* IR in/out ports: featured only on the BDP-83.
* RS-232 remote control: featured only (as an option) on the BDP-83.
* Remote control: glow-in-the-dark on the BDP-80; backlit on the BDP-83.
* Dimensions: the BDP-80 loses 55mm (2.2in) in depth and 24mm (0.9in) in height versus the BDP-83.
* Weight: the BDP-80 is 1.6kg (3.5lbs) lighter than the BDP-83.
Oppo Digital recommends the BDP-83 for users with very large projection screen or having a large DVD collection that needs the best up-conversion. On the other hand, it states that the BDP-80 is "incredibly well suited as a digital transport to feed into an external video processor, a high-end A/V receiver or display device with built-in video processing," and is also recommended "as a stand-alone Blu-ray/DVD/CD-player that offers higher video and audio quality than many mass-market players," and " for smaller home theaters as a standalone player where universal media support and speedy operations are the most ideal." The BDP-83 is Oppo's recommendation for home theaters with large screens.
Re: Απάντηση: Oppo BDP-80
Αντε σε λιγο θα βγαλει και η Lexicon και δευτερο player :142:
To BDP-80 ειναι ηδη μεσα σε ενα αλλο player που θα πουλιεται περιπου 3 φορες πιο ακριβα στην Αμερικη για την ακριβεια $800.
Oppo BDP-80
Και οι πρωτες εντυπωσεις :
REVIEWS
gonk's BDP-80 Review
winston9332 Mini-Review
Τα εντος....
Οπως θα δειτε στο review του gonk, το μενου ειναι ιδιο με αυτο του 83.
Τρεις οι χρησεις και χρηστες του :
- απλο player που τα κανει ολα και καλα, μονο του
- συνδεση με εναν ενισχυτη που εχει επεξεργαστη εικονας
- συνδεση με εξωτερικο επεξεργαστη εικονας, σε λειτουργια Source Direct.
Τα 80/83 παιζουν mkv?Υποστηριζουν ntfs?
Αν ναι με ποιον επεξεργαστη?
Re: Απάντηση: Η Oppo στην Ελλάδα, νέα αρχή
Το NTFS το εχει μπλοκαρει η bluray association και δεν προκειται να το δουμε ποτε. Αντι αυτου, οπως εχω πει, επεξεργαζονται την ενσωματωση των νεων exFAT των win7, αλλα δεν ειναι στα αμεσα σχεδια τους, γιαυτο και η δικτυωση.
MKV αρχεια παιζει απο δισκακι αν ειναι μικρα και απο DLNA κανονικα και πανω απο 4GB.
Τελος, εχουν ξεκαθαρισει στην Αμερικη οτι τα bluray players θα ειναι bluray players και οχι media players και ματροσκο-players.
Το οτι υποστηριζει αρχεια mkv, το εχω ξαναπει πολλες φορες, ειναι για το επερχομενο pay-per-view, pay-per-download.
To format αυτων των pay-per-ταδε ειναι το mkv.
Ελληνικους υποτιτλους σε αρχεια avi,mkv δεν βλεπει σε μορφη srt. Μονο αν ειναι μεσα στην ταινια.
Επεξεργαστης :
Decoder Chipset : Mediatek MT8521G, ειδικη εκδοση του 8520 για τα Oppo.
Video Processor:
BDP-83/83SE : ειναι ο κορυφαιος VRS της Anchor Bay με το ABT2010.
BDP-80 : ο ενσωματομενος Mediatek MTK8575.
Audio boards ( DACs ) :
BDP-83
  • stereo : Cirrus Logic CS4398 1 DAC per channel
  • multichannel : Cirrus Logic CS4382A
BDP-83SE
  • stereo : ESS Technology ES9016 4 DACs per channel
  • multichannel : ESS Technology ES9006
BDP-80
  • Cirrus Logic CS4361 ( ιδιος με αυτον του DV-983H )
Καλημερα,
Ειχαμε ενα μικρο προβλημα γιατι η κουτα με τα κιτ και τα λοιπα αξεσουαρ πηγε αλλου....αλλα τωρα πια ειναι στο δρομο για Αθηνα.
Παρασκευη-Σαββατο θα τα εχω, αλλα υπαρχουν ακομα δυο προβληματα. Το ενα ειναι οτι την επομενη εβδομαδα θα παω στο Αμστερνταμ για την εκθεση ISE2010 και το δευτερο και κυριοτερο ειναι οτι δυο μερες τωρα πεφτει το ρευμα και δεν τολμω να κανω αναβαθμισεις.
Ψαχνω ενα UPS που θα μου κανει με ασφαλεια και σιγουρια τη δουλεια για να εχουμε το κεφαλι μας ησυχο.
Οποτε μας βλεπω απο Δευτερα 8 Φεβ να ξεκιναμε.
Το παρακατω, κανονικα θα επρεπε να το βαλω στις αγγελιες, αλλα δεν προκειται για προσφορα αλλα για λυση-εξυπηρετηση, αν μπορω να το πω ετσι.
Οπως ειπα πιο πανω, εγινε λαθος στην αποστολη των κιτ και σε μενα ερχεται ενα BDP-83 που ειχε παει για αλλαγη drive. Απο την Αγγλια με παρακαλεσαν αν μπορω να το διαθεσω σε καποιον στην Ελλαδα, για να γλυτωσουν το χρονο και το χρημα της επιστροφης.
Η τιμη που μου ειπαν ειναι 400 ευρω. ( εχει και region kit ).
Το player θα ακολουθησει τη νορμαλ εγγυηση και υποστηριξη κανονικα.
Αυτο ισχυει μεχρι και αυριο. Αν δεν πουληθει μεσα σε αυτο το συντομο διαστημα, το Σαββατο θα φυγει πισω στην Αγγλια.
Ευχαριστω.
Καλημερα,
Ευχαριστω.
Αποστολη συνοδευεται και απτα μανουαλ , hdmi δισκακια κλπ???
Sorry guys, το player κλειστηκε.
Αν υπαρξει ακυρωση θα σας ενημερωσω.
Μου φαινεται οτι πρεπει να κανει τετοια λαθη πιο συχνα....:137:
Αποστόλη,σε ευχαριστώ για όλα.....να φανταστείς ότι απο τη στιγμή που γύρισα σπίτι και το σύνδεσα.............παιζει non stop στο μέγιστο των εντάσεων.....τέλειο,μπράβο στα παιδιά που το έλεγαν για το ess,ΙΣΧΥΟΥΝ ΟΛΑ..........τρομερή εικόνα σε bd,dvd.......αλλά στον ήχο,ειναι καταπληκτικό.......άπαιχτο.......το S.E.,ΑΞΙΖΕΙ ΤΑ ΠΑΝΤΑ ΟΛΑ.........
Αποστολη,σαν s.e.,ειναι τρομερό στον ήχο.......τι να λέμε τώρα........μπράβοοοοοο.....και σε ευχαριστώ..........
Ουαου! Αυτό θα πει ενθουσιασμός!!! Μεγιά το νέο μηχάνημα!!!
Αποστολη,σαν s.e.,ειναι τρομερό στον ήχο.......τι να λέμε τώρα........μπράβοοοοοο.....και σε ευχαριστώ..........[/QUOTE
απ οτι φαινεται μαλλον ... λεω μαλλον... φαινεται πως σε εχει εντυπωσιασει το μηχανακι ε????:143::143::143:
αντε καλες θεασεις και ακομα καλυτερες ακροασεις!!!!:144:
........όπως είπα και στον Αποστολη,το player,συνδέθηκε με hdmi στην tv, και με τις στέρεο αναλογικές στον προενισχυτή.....ρυθμισμένο,σε pure audio,ειναι καταπληκτικό για cd - είναι τρομερό στο δικάναλο sacd , και στο dvd audio.......οντως το ESS DAC κάνει θαύματα.............και για όσους διαφώνουν,ΣΙΓΟΥΡΑ,υπάρχουν καλύτερα audio player......αλλά κάνουν πολλές χιλ. ευρώ παραπάνω.....
Σαν dvd- bd,τα ξέρετε........μερσί.......
καλα καπετανιο απο μια μερια θα θελα να μου εκει κοντα οταν γινονταν οι συνδεσεις!!! μιλαμε τετοια ευτυχια ουτε οταν εβαλε το γκολακι ο χαριστεας στους πορτογαλλους :142::142::142::142:
καλοριζικο και παλι !!!!
Απ οτι καταλαβατε, ο καπταν-Στεφανος ειναι ο διπλος τυχερος.
Γιατι διπλος : γιατι πρωτον πηρε το player που λεγαμε, με καινουργιο κουτι αξεσουαρ και με τα δυο δισκακια και δευτερον εβαλε και το μοναδικο SE kit που ειχα καταφερει να εχω παραπανω.
Χαιρομαι που η χαρα σου απο το μαγαζι μεταφερθηκε και στο σπιτι, αλλα μεγαλωσε κιολας.
Αν θελεις πες μας με τι μηχανηματα συνδεθηκε το player.
Και κατι ακομα, αν θελεις για πες και τι αλλο ακουσες...μικρο στο ματι...μεγαλο στον ηχο.
Να ζωντανεψει και λιγο αυτο το τοπικ...
intergrale
