ΤΗΧ-Διαφωνίες
Απάντηση: THX.Τί είναι και πόσο χρήσιμο είναι?
παρε να εχεις
απο αμερικη αυτη τη φορα
για να δεις πως πουλα ενα δανεζικο προιον στην μεκα του σινεμα
Having lived in Denmark for a couple of years as a kid, I guess I've learned a little about the Danish mindset. Many Danes display a self-effacing modesty, to the extent that Carlsberg will only say that theirs is "probably the best beer in the world." Yet, in their typically understated way, this little country (with a population about equal to that of Missouri) has made deeper inroads into the lives of Americans than most people think. Just don't blame them the next time you step on one of your kid's Lego blocks.
Although most Americans have probably never heard of Jamo, they are Europe's largest speaker company, producing a huge range of models. The D 7PEX is their version of an all-out THX Ultra 2 design (PEX stands for Package for Surround EX), incorporating five D 7LCR satellites for the three front channels and the rear surrounds, a pair of D 7SURs for the side surrounds, and a D 7SUB subwoofer to handle bass. I decided to go all out and try the system with two subwoofers. Knowing that a nine-speaker setup was coming, I prepared my room for an onslaught of speakers that I envisioned might make my room resemble the Grateful Dead's famous Wall of Sound. Imagine my joy when the UPS guy strolled up with a stack of seven smallish boxes on his hand truck. Naturally, I'd forgotten that, with a THX speaker system like this one, the subwoofers handle everything below 80 hertz. It generally takes big speakers to make big bass. In this case, because the dual subwoofers (which the UPS guy delivered on a second hand truck) handle the deep bass, the other speakers could be much smaller.
When Jamo designed this setup, they realized that home theater buffs are fundamentally different from traditional audiophiles: If you're going to try to stuff as many as nine speaker boxes into someone's room, they'd better not get in the way. To this end, Jamo developed speakers that will deliver the best results when you hang them on the wall like pictures. The D 7LCR is a three-way, five-driver design with two small midrange drivers flanked vertically around an unusual dual-concentric-dome tweeter. By centering the crossover at 2.5 kilohertz, Jamo satisfies the THX vertical-directivity requirement while allowing for an impressive 200-watt continuous-power-handling rating. To get the bass to extend deep enough to cover the 80-Hz THX cutoff, this midrange/tweeter array is flanked laterally by a pair of 5.5-inch metal cone woofers, which also adds to the mix the impressive dynamic abilities that metal cones are best known for. All of this is housed in a package that's less than 7 inches deep, and it even comes complete with hangers so that you can attach it directly to the wall. On the back, there are two pairs of binding posts. At first, I thought that the designers must have been in an audiophile mood, giving us the ability to biwire the speaker. It turns out that, by connecting the second pair of binding posts using a set of jumpers, you can boost the lower frequencies to achieve a flatter response, should you decide to use the speakers on stands rather than on the wall.
Another requirement of the THX Ultra 2 specification is that the surround speakers should generate a diffuse soundfield so that the sound wraps around to the back of the seating area without drawing the listener's attention specifically to the speaker's location. To achieve this, each D 7SUR uses no less than seven drivers, with two midranges and a tweeter firing to each side, along with a woofer firing straight into the room. On each side, the two midranges are set close together, with a tweeter placed just above them. This arrangement widens the vertical dispersion and provides a smoother response from the listening position when you place the speakers at the recommended height of about 6 feet. To ensure accurate timbre matching among the channels, the D 7SUR uses the same drivers that are in the D 7LCR.
To extend the sound around to the back of the room, the full-blown D 7PEX setup employs another pair of D 7LCRs mounted high up on the back wall. Even though there still aren't a lot of DVDs with an encoded rear surround signal, if your room layout allows for it, there's no denying the extra dimensionality that rear surround channels can add when used correctly. As Jamo designed all of these speakers to be used with a pre/pro that sends any bass below 80 Hz to the subwoofer outputs along with the LFE channel, it was clear that I was going to need some serious low-frequency air-moving ability. Luckily, the D 7SUB proved well up to the task. To push the envelope just a little further, I went ahead and used two of them. Now, this might seem like overkill, but there are benefits beyond ultimate output ability when you spread the bass-handling duties around a little. Due to the standing waves that room boundaries create, subwoofers often produce a fairly lumpy response. If you spread the bass to more than one subwoofer, you can often even out the response to get better overall results.
Re: Απάντηση: Re: THX.Τί είναι και πόσο χρήσιμο είναι?
οταν σταματησεις να λες βλακειες μας το λες
Μηπώς θες να κάνουμε κανένα poll για το ποιος λέει βλακείες?
Αφησέ το καλύτερα γιατί θα πάρεις το χρυσό.
Ρε Αργύρη ειλικρινά απάντησε μου IQ έχεις στο κεφάλι σου ή το πουλήσες για να πάρεις καλώδια?:135:
Δεν διαβάζεις τι σου γράφουν?
Απάντάς σαν άσχετος καταναλωτής με τη κάθε παραπλανητική αρλούπμπα των εταιρειών που σου αραδιάζουν?
Μπορώ να ξεσκίσω έυκολα ΟΤΙ ΚΑΙ ΝΑ ΓΡΑΨΕΙΣ γιατί για το καθένα έχω 10 επιχειρήματα.
Jamo - ?? Καλά είναι αλλα όχι και πανάκριβα και χαλάρωσε δεν κανούν και ουρές για να τα πάρουν.
Λιστα με εταιρείες ηχείων?
Εισαι σοβαρός ή μας δουλεύεις με τα Θέατρα -Περίπτερα που ασχολείσαι? Και δεν εννοώ τις σοβαρές που έχουν πλέον τη στάμπα για να μην κλαίει ο Λουκας.
Ε μόνο που μιλάμε για ΤΗΧ και Creative με Razor στην ίδια πρόταση ας κρίνει ο καθένας μόνος του.
Χωνεψε το Δεν Πείθεις όπως και δεν πείθει και ο Λουκάς και φαίνεται από τα Μαυρά χάλια των πωλήσεων της THX.
Και σταμάτα αυτή την κακόγουστη αναδημοσίευση από Marketing Press Releases και πληρωμένα άρθρα της πλάκας.
Αρκετά νομίζω με το θέμα όποιος διαβάζει μπορεί να καταλάβει τι εννοώ και να έχει τα μάτια του και τα αυτιά του ανοιχτά πριν ψωνίσει.
Δεν έχει νόημα να επαναλλαμβανόμαστε...
Νομίζω δέν έχει νόημα να μαλώνετε.Όποιος έχει μυαλό κρίνει και καταλαβαίνει.
Τα ίδια που συμβαίνουν στο home cinema συμβαίνουν και στα pc,στα αμάξια...παντού.Το πάν είναι το καλό marketing.:138:
Re: Απάντηση: THX.Τί είναι και πόσο χρήσιμο είναι?
αν δεις το σαιτ του λουκα πολλες εταιριες σφραγιζαν και σφραγιζουν ηχεια
μεταξυ αυτων και η b&w
λοιπον τι συμβαινει?
την πιασανε κοροιδο
ή τα ηχεια της ηταν φολα.
Δεν ξερεις τι λες για ακομα μια φορα
Το είπες σωστα ΣΦΡΑΓΙΖΕ! Πλεόν δεν ασχολείται όπως σε λίγο δεν θα ασχολείται κανείς.
Είπαμε σταμάτα την παραπληροφόρηση.
Όσο για τα Jamo της Klipsch είναι όποτε δεν μετράνε ξεχωριστά. Έχουν πάρει τη στάμπα με το κιλο οπότε την βάζουν κι εκεί για κάτι τύπους σαν κι εσένα.:602:
Μα δεν μαλώνουμε εδώ επιτελούμε κοινωνικό έργο δείχνωντας στον Αργύρη πως να ξεχωρίζει το καλό από το κακό γιατί είναι μικρός ακόμα και δεν ξέρει.:143::143:
Α και κάτι ακόμα Αργύρη:143:
:143:
Μα είπαμε ότι το THX είναι διαφορετικό για τα ηχεία desktop και διαφορετικό για τα υπόλοιπα ηχεία. Άλλες προδιαγραφές σε κάθε περίπτωση.
Τελικά αυτό που προσθέτει το THX είναι καλό για την περίπτωση που χρησιμοποιείται ή κάνει κακό;
Ναι ρε συ το ξέρουμε ότι είναι διαφορετικό αλλά πως να το κάνουμε Hermes με Πορδες δεν γίνεται και ρώτα τι γυναίκα σου να σου πει αν δε με πιστεύεις.
Δεν έχει THX η Hermes; Πως και ξέφυγε; :138:
Το θέμα είναι, προσφέρει κάτι επιπλέον ή όχι. Γιατί αν προσφέρει, τότε έχει νόημα. Αν δεν προσφέρει όμως... .
Sorry σας εχασα και τους δυο .... τι εννοείτε?Ποιά η ποιός είναι ο η hermes? τι είναι?
Τι κάνει?
Τι κάνει?
Τσ Τσ Τσ... πρόκειται για fashionphile τροπή της συζήτησης στην οποία θέλει ο ποιητής να πει ότι το THX είναι (ή ήταν) μόδα.
Κάνε ένα reset και ξαναέλα. :137:
http://uk.hermes.com/webapp/wcs/sto...oryId=130037&parentCategoryId=130037&nbItem=0
το thx ειναι απατη χρονια τωρα το υποστηριζω , δεν εχει μονο ο lukas το προνομιο του καλου ηχου , αν κρινω τις υπερπαραγωγες του οι περισσοτερες εχουν μετριο ηχο
Απλα εχει επαναπαυτει στης δαφνες του και στο marketing του hollywood που εξακολουθει να τον στηριζει
και εγω αλλα κανενας δεν με ακουει, εχει τρελλαθει στην σφραγιδα
οχι βεβαια , αλλα δεν εχει και το προνομιο του κακου ηχου, αποκλειστικα παντα
το μαρκετινγκ στηριζει οποιον το στηριζει .Η αλλιως το ενα χερι τριβει το αλλο και τα δυο το προσωπο.
Και ξερεις εκει εξω υπαρχουν πολλα χερια που θα ηθελαν να γινουν χαλιφης στην θεση του χαλιφη.
Αυτα
Αμαν?
Τι βρήκα εδώ?
Διάφορες πηγές που λένε ότι το 2002 ο Lucas πούλησε το 60% της THX στην Creative Labs και μετά είδαμε τη στάμπα στους πάγκους της λαϊκης.
Εδώ ένα άρθρο κι εδώ ένα νήμα σε forum κι εδώ η συνέχεια!
Τελικά το "μασκάρανε" λιγο μαζι με άλλου μετόχους αλλά ευτυχώς η Creative ως PLC είναι υποχρεωμένη να δημοσιεύει τέτοια πράγματα στον ισολογισμό της οπότε καρφωθηκαν
Και μετά λέμε γιατί έφυγε ο Holman. Γιατί βρώμησε πολύ εκει μέσε. Πολύ μιλάμε.
Αργύρη τι έχεις να πεις γι'αυτό εκτός από τα γνωστά αβάσιμα και χωρίς επιχειρήματα σχόλια σου?
Και για να μαθαίνεις Αργύρη ο ΛΟΥΚΑΣ στη Skywalker Sound χρησιμοποιεί 5 B&W 802D! Ούτε Jamo ούτε Teufel!
Ακούς Αργύρη?
Να
Αμαν?
Τι βρήκα εδώ?
κοντα στο σπιτι μου εχει κατι πηγες μαυρου χρυσου
εισαι ?
, να αλλαξεις και ονομα σε τερης χρυσος:142:
Ακούς Αργύρη?
Να
cut the drugs
και αποφασισε εισαι με τον λουκα
ή οχι
εχω και αλλες φωτο με ιδια ηχεια-ενισχυτικα αλλα ηχεια-αλλα ενισχυτικα
τι θες να μας πεις οτι μπορουν σε ενα νορμαλ σπιτι να χωρεσουν 7 τετοια ηχεια
σε ποια ταινια γινεται κατι τετοιο?
απο ενισχυτικα δε πρεπει να πουλησεις πολλα πραματα για να τα τρεξεις καλα
Και απο χωρο μονο στο σκυλοσπιτο χωρανε , οχι το δικο μου
του σοφερ (το επιασες το υπονουμενο )
ετσι
Και τα αλεξαντρια της γουιλσον ειναι ακομα καλυτερα ηχεια
και ο κλασε ομεγκα τρελλο ενισχυτικο .
Αλλα ειναι παρα πολλα τα λεφτα αρη
ειδικα σε ενα μετριο ελληνα που του λειπουν τα 14 ευρω για να μαζεψει 15.
Πες αλλου , χολιγουντ μερια
εδω ειναι η χωρα της πεινας
Να φυγετε κυριε να πατε αλλου:142:
Θάνος Γαλάνης
