Western Digital TV HD LIVE
Re: Western Digital TV HD2
Ωρε! Τι'ν τουτο?
Prerelease 1.02.14
· Added Windows 7 Support.
· Added larger subtitle font size options.
· Added European language input for keyboard.
· Added serial and part number to About page.
· Added support for embedded subtitles in mpg files.
· Added new category in Photo/Video to view by date.
· Added a field in network settings for changing the workgroup name.
· Added ability to play a video from the preview window without restarting.
· Added username/password feature for SAMBA security.
· Added Wireless LAN strength bar in Network info page.
· Changed default browsing by date to start with the latest files first.
· Changed video browse default to "Preview Mode" instead of thumbnail mode.
· Corrected several language translations issues.
· Resolved issues with subtitle sync adjustment.
· Resolved abnormal display of BMP photos through a media server.
· Resolved Audio channel information shows up in AutoPlay mode.
· Resolved Blu-ray ISO subtitle not displaying throughout VIDEO playback.
· Resolved Blu-ray slow playback across SAMBA.
· Resolved camera files not enumerating correctly in mass storage.
· Resolved login issue with SAMBA after exiting screen saver.
· Resolved DVR-MS black screen problem on resume after forward and rewind.
· Resolved external sub/idx subtitles flashbacking issue.
· Resolved playback across media server failures.
· Resolved hard drive icon from disappearing in the video list under preview mode.
· Resolved issue of HDMI becoming jittery after long time play.
· Resolved M4V files not supporting fast forward and rewind.
· Resolved manual network addressing issue.
· Resolved missing shuffle & repeat icon for slideshow within Flickr.
· Resolved music search not displaying playlist names.
· Resolved network devices (SAMBA) disappearing without warning.
· Resolved PTP issue of unsupported video file formats DX6490,DIMAGE Z2 & X1, Optio
555 and DMC-FX2.
· Resolved Sony Walkman not showing photos within directory.
· Resolved unsupported file formats not showing an error message.
· Resolved video playback overscan issue for CRT TVs.
· Resolved WIFI Belkin F6D4050 with RAlink 3070 chip and Linksys WUSUB100 Ver 2.
· Resolved WIFI ZyXel NWD-270N dongle not enumerating.
Επιτέλους, τρομαξανε να μεγαλώσουνε τους υποτιτλους, μέχρι και 68 μέγεθος.
Μόλις το έβαλα, κανένα πρόβλημα με την εγκατάσταση,θυμάστε τι είχε γίνει.
Απάντηση: Western Digital TV HD2
Polakis έχουμε είδη το νέο επίσημο fw τους υποστηρίζει κανονικά είτε σε m2ts αρχείο είτε se .iso αρχείο.
Για ακόμα μια φορά είχε δίκιο ο furious99.
Προσοχή!! Έχουν διαπιστωθεί προβλήματα αναπαραγωγής αρχείων βίντεο (κυρίως MKV) είτε από δίκτυο είτε από usb με το prerelease firmware. Μερικοί τα έλυσαν με Factory Reset μερικοί πάλι δεν κατάφεραν να κάνουν κάτι...
Απάντηση: Re: Western Digital TV HD2
Τι σημαίνει αυτό; ότι το παραπάνω firmware δεν είναι ακόμα το κανονικό και ότι θα ακολουθήσει άλλο;
Re: Απάντηση: Re: Western Digital TV HD2
Φυσικά και δεν ειναι "ΚΑΝΟΝΙΚΟ". Prerelease σημαίνει ότι είναι δοκιμαστικό και σιγουρα θα ακολουθήσει άλλο.
Οπότε όποιος θέλει να έχει το κεφάλι του ήσυχο περιμένει την κλασική αναβάθμιση ΟΧΙ την prerelease.
Αν και προσωπικά δεν εχω κανένα πρόβλημα με τα mkv αρχεία παρόλο που εχω περάσει την 1.02.14.
Re: Απάντηση: Western Digital TV HD2
Εγώ, προσωπικά, θα την βάλω το απογευμα μια και, ότι και να γίνει μπορώ να γυρίσω στην προηγούμενη....
Ποιά είναι η τελευταία & κανονική αναβάθμιση; παραλαμβάνω σήμερα και θα ελέγξω.
Αυτή που λέμε 1.02.14 τελευταία επισιμη έκδοση αλλά όχι τελική(Κοινώς επίσημη beta).
Αν εννοείς την τελική τότε είναι η 1.01.24.
Λογικά με την νέα έκδοση λογισμικού 1.02.14 σε εμένα βλέπω να κλείνει εντελώς ο usb δίσκος που εχω ενώ πριν δεν έκλεινε εντελώς.
Δοκιμάστε το κι εσείς και πείτε μας αν κλείνει εντελώς ο δίσκος όταν κλείσετε το μηχάνημα ή όχι.
Ο δισκος εκλεινε σε ολες τις εκδοσεις νομιζω,μονο στις τελευταιες εκδοσεις του b-rad δεν εκλεινe o δισκος.
Χτες το βράδυ είπα να δοκιμάσω κι εγώ ένα mkv 1080 να δω. Το βάζω λοιπόν ξεκινάει μια χαρά και, περιπου, στα 10 λεπτά σταματάει ο ήχος και αρχίζει τα κοψίματα.. μέχρι που σταμάτησε τελείως. Το μηχάνημα δεν κόλλησε. Πάτησα stop και μετά play και συνέχισα απο εκεί που είχα σταματήσει αλλά σχεδόν άμεσα άρχισε τα ίδια. Από τα ινφο του mkv δεν φαίνεται να είναι κάτι βαρύ και θα έπρεπε να το παίξει. Καμμιά ιδέα?
Firmware: 1.01.24
Video Info:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 42mn 24s
Bit rate : 10.2 Mbps
Nominal bit rate : 10.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.205
Stream size : 3.02 GiB (92%)
Writing library : x264 core 83 r1391 3d0f110
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=10424 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio : AC3
Dzogas Γιατί δεν δοκιμάζεις την νεότερη έκδοση λογισμικού 1.02.14?
Αν και εγώ προσωπικά ούτε με την 1.01.24 ούτε με την νεότερη 1.02.14 δεν μου έχει κολλήσει ποτέ σε mkv αρχεία.
Αυτό είναι το επόμενο μου βήμα.... αλλά μάλλον Σ/Κ να έχω και λίγο χρόνο να ασχοληθώ...
Να έχω και Internet μια και εδω και εναμιση μηνα περιμενω αυτη τη καταραμένη γραμμή (αλλα αυτο είναι άλλο θέμα....)
Υ.Γ. Κάπου διάβασα ότι μέσω Live δεν έχει κανεις πρόσβαση σε HD περιεχόμενο. Δεν ξέρω αν μιλάνε για όλα τα HD αλλα κάτι για protected videos διαβασα..... Ξέρει κανείς αν ισχύει?
Μετά από λίγο ψάξιμο βρήκα τι παίζει...
Μπορείτε να το διαβάσετε εδώ
(Επίσημη ανακοίνωση της WD) We have reached the maximum number of downloads available for this prerelease. Installation steps and the roll back firmware download will continue to be available on this page.
Επειδή σε όλα τ'άλλα μέχρι στιγμής τα πάει καλά το μηχάνημα αλλά στην αναπαραγωγή από δίκτυο (ενσύρματα)...δεν τα κατάφερε , μήπως ξέρετε εάν αυτό είναι bug του νέου prerelease ? Δηλαδή εννοώ στην προηγούμενη έκδοση δεν υπήρχε αυτό το θέμα? (Σημειώνω ότι το ξεκίνησα κατευθείαν με την 1.02.14)
Andrewk
