Δοκιμή των Dune HD Max & Smart B1-D1-H1,Duo
Απάντηση: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Youtube όχι προς το παρόν!Ισως αργότερα…θα δούμε!
Εδώ όλα τα συμβατά θεωρητικά wifi sticks για τα dune:
USB WiFi adapters based on RALink RT2770/RT2870 chipset (for all Dune player models):
WiFi driver: RALink RT2870 version 2.3.0.0.
USB IDs recognized by the WiFi driver and Dune firmware:
0411:00e8 Buffalo WLI-UC-G300N
0471:200f Philips
04e8:2018 samsung linkstick2
050d:8053 Belkin
050d:805c
050d:815c
050d:815c Belkin F5D8053
0586:3416 Zyxel
0789:0162 Logitec 2870
0789:0163 Logitec 2870
0789:0164 Logitec 2870
07aa:002f Corega
07aa:003c Corega
07aa:003f Corega
07b8:2770 AboCom
07b8:2870 AboCom
--- 07d1:3c09 D-Link DWA-140 B1 --- REPORTED TO WORK OK (THE MOST TESTED ONE)
07d1:3c11 D-Link DWA-160
083a:6618 Accton
083a:7512 Arcadyan 2770
083a:7522 Arcadyan
083a:8522 Arcadyan
083a:a618 SMC
083a:b522 SMC
--- 0b05:1731 Asus WL-160N --- REPORTED TO WORK OK
0b05:1732 Asus
0b05:1742 Asus
0cde:0022 ZCOM
0cde:0025 Zyxel
0db0:6899
0df6:0017 Sitecom
0df6:002b Sitecom
0df6:002c Sitecom
0df6:002d Sitecom
0df6:0039 Sitecom 2770
0df6:003f Sitecom 2770
0e66:0001 Hawking
0e66:0003 Hawking
100d:9031 Motorola 2770
1044:800b Gigabyte
129b:1828 Siemens
13d3:3247 AzureWave
1482:3c09 Abocom
--- 148f:2770 Ralink = Trendnet TEW-644UB --- REPORTED TO WORK OK
--- 148f:2870 Ralink = Trendnet TEW-624UB --- REPORTED TO WORK OK
14b2:3c06 Conceptronic
14b2:3c07 AL
14b2:3c09 Alpha
14b2:3c23 Airlink
14b2:3c25 Draytek
14b2:3c27 Airlink
14b2:3c28 Conceptronic
157e:300e U-Media
15a9:0006 Sparklan
15c5:0008 Amit
1690:0740 Askey
1737:0070 Linksys WUSB100
1737:0071 Linksys WUSB600N
1740:9701 EnGenius
1740:9702 EnGenius
177f:0302 lsusb
2019:ed06 Planex Communications, Inc.
5a57:0280 Zinwell
5a57:0282 Zinwell
7392:7717
7392:7718
USB WiFi adapters based on RALink RT3070/3071/3072 chipset (only for Dune player models based on Sigma Designs 864x/865x platforms):
WiFi driver: RALink RT3070 version 2.1.2.0.
04bb:0945 I-O DATA 3072
07b8:3070 AboCom 3070
07b8:3071 AboCom 3071
07b8:3072 Abocom 3072
--- 07d1:3c0a D-Link 3072 DWA-140 B2 --- REPORTED TO WORK OK
07d1:3c0d D-Link 3070
07d1:3c0e D-Link 3070
07d1:3c0f D-Link 3070
083a:7511 Arcadyan 3070
0db0:3820 Ralink 3070
0df6:003e Sitecom 3070
0df6:0042 Sitecom 3072
1044:800d Gigabyte GN-WB32L 3070
13d3:3273 AzureWave 3070
148f:3070 Ralink 3070
148f:3071 Ralink 3071
--- 148f:3072 Ralink 3072 = EDUP ED-300 --- REPORTED TO WORK OK
14b2:3c12 AL 3070
1740:9703 EnGenius 3070
1740:9705 EnGenius 3071
1740:9706 EnGenius 3072
18c5:0012 Corega 3070
1a32:0304 Quanta 3070
1d4d:000c Pegatron Corporation 3070
1d4d:000e Pegatron Corporation 3070
1eda:2310 AirTies 3070
2019:ab25 Planex Communications:Inc. RT3070
203d:1480 Encore 3070
5a57:0283 Zinwell 3072
5a57:5257 Zinwell 3070
7392:7711 Edimax 3070
Οι υπότιτλοι σε αυτή την περίπτωση πρέπει να είναι κάπως έτσι:
Movies.mkv
Movies (gr).srt
Movies (eng).srt
Και στον ίδιο φάκελλο με την ταινία βέβαια!
Δάσκαλε δεν μου λειτουργεί….:120:
Το πηρα και γω!
Για το MAX λεω.
Καλορίζικο!!!
“Και μην ξεχνάς όμως έχεις δυο παιδιά να μεγαλώσεις” και πρέπει μα βρεις αρκετές παιδικές ταινίες.
Αυτό δεν εννοεί η σύζυγος? :118:
Με πρόλαβες !!!! ότι το κατέβαζα ! :141:
Φίλε μου Νίκο επειδή πήρες το Smart δεν μπορείς να διαλύσεις το Prime,:105:
Λεγε με Λεωνίδα:126:
Εννοείς δε σου λειτουργεί η εναλλαγή ή δε βλέπεις καθόλου υπότιτλους?
Re: Απάντηση: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Δεν φαντάζομαι να συμπεριέλαβες στην ονομασία των υπότιτλων τα (gr), (eng)?
Οι ονομασίες πρέπει να είναι:
movie.mkv
movie.srt
Ίδιες ΑΚΡΙΒΩΣ!!
Δεν γίνεται να μην παίξουν!!
Απάντηση: Re: Απάντηση: Δοκιμή των Dune HD Max & Smart B1-D1-H1
Οι υπότιτλοι παίζουν όταν είναι μέσα στο φάκελο, αλλά ένας.
Πως θα βάλουμε και δεύτερο υπότιτλο μέσα στον ίδιο φάκελο και μετά να επιλέγω αυτόν που θέλω?
Στο WD Live η διαδικασία ήταν:
Movies.mkv
Movies.Gr.srt
Movies.En.srt
Στα Dune?
Δημήτρης
Εγώ δε στάπα καλά φίλε μου και σε μπέρδεψα.
Οχι αν είναι και οι 2 εξωτερικοί δεν μπορεί να γίνει εναλλαγή των υποτίτλων.
Πρέπει ο ένας να είναι εσωτερικός στη ματρόσκα και απαραίτητα σε utf-8 (ο εσωτερικός υπότιτλος).
Μπερδεύτηκα με το Mede8er που γίνεται εναλλαγή των εξωτερικών υποτίτλων και ταλαιπώρησα και σένα!
Sorry!:203:
L
LLLEFTERIS
Γιατι δεν ενωνεις τους υποτιτλους πανω στην ταινια με το mkvtoolnix?
Λευτέρη το πέρασες το firmware του katrina.tv?
L
LLLEFTERIS
Ναι μια χαρα ποιο ωραιο απο το δικο του και λιγο ποιο γρηγορο.
L
LLLEFTERIS
Το μονο ασχημο ειναι που ο δισκος μου ειναι κομμενος σε πολλα partition γιατι ετσι τον εκανε format το ryan που ειχα και δεν εχω αλλον σκληρο 2TB για περασω μεσα τα αρχεια μου συν οτι κατι μου ζηταει το Dune να γραψει στον σκληρο και οπως καταλαβα πρεπει να τον κανω format μεσα στο μηχανημα.
Sorry!:203:
Κανένα πρόβλημα Λεωνίδα. Σε ευχαριστώ.
Σου ζητάει να φτιάξει system storage μάλλον.Είναι απαραίτητο για το bd live στα blu ray αλλά και για άλλα πράγματα.Βέβαια για το system storage μπορείς να του βάλεις και ένα usb stick ή και μια sd card ακόμη!
L
LLLEFTERIS
Ναι αυτο ηθελε αλλα εκανα format το ενα partition και μου το εκανε και πλεον δεν μου το ζηταει απλα μου την δινει να διχνει οτι εχει 5 σκληρους και μονο ο πρωτος ουσιαστικα να ειναι ο δισκος μου.
Σύνδεσε ένα netbook επάνω μέσω USB Host και όταν τον δουν τα windows πήγαινε στα εργαλεία δίσκου από την διαχείρηση να σβήσεις τα υπόλοιπα partition...
L
LLLEFTERIS
Θα παρω την Δευτερα εναν green 2TB να τον εχω και σαν backup και θα τα περασω εκει και μετα θα κανω format τον black μεσα στο dune.
Συν οτι αν σβησεις πχ το πρωτευον partition μπορει να κρεμασουν τα υπολοιπα και εμενα το partition που εχω τα πραγματα ειναι το τριτο.
Τεχνικος υπολογιστων ειμαι ασχετα αν βαρεθηκα τα Windows και το εριξα στα Lion :116:
Εγώ θα σου πρότεινα τον green να βάλεις εσωτερικό στο dune και όχι τον black.
Για το δικό μου πάντως θα σφάξω αύριο έναν εξωτερικό Seagate 2TB να του βάλω μέσα μόλις έρθει...
intergrale
