Χειρότερος ήχος στην έκθεση Μονάχου
Απάντηση: Χειρότερος ήχος στην έκθεση Μονάχου
YG Anat Reference mid-high module
Κατι μου λεει οτι θα ειναι επομενη αναβαθμιση σου σε καμμια πενταετια (βαρια -βαρια)
Nα μην στο λέει, το Tidal είναι 5 κλάσεις πάνω, σε κάνα χρόνο θα το στείλω πάνω για να βάλω το diamond tweeter...;) και τέρμα.
Εκτός και αν κάποτε πάω σε χώρο πάνω από 40m2 που θα πάρω το Contriva.
Alex_Zapantis
Απάντηση: Re: Χειρότερος ήχος στην έκθεση Μονάχου
'Ελα ντε:105: κι αυτό με την 'ζάντα' ακούγεται καλύτερα;ποιο χαιεντάδικα;;;:116:
Αυτό τώρα είναι κάποιας μορφής κυματοδηγός ή απλά ντιζαϊνάτη σίτα;
http://www.voltloudspeakers.co.uk/Loudspeakers/Radial_Chassis/body_radial_chassis.html
The patented Volt Radial design overcomes the performance barrier that has affected high-power loudspeakers ever since they were developed: heat.
Power for power, Volt Radials run cooler and deliver stable sound that does not fall-off or degrade during a performance. Equally important, Volt Radials deliver the same high level output all the time-unlike other speakers, which lose power and definition as they get hotter.
Finally, Volt Radials are more reliable. There's simply less heat for them to handle, so they're under a lot less stress.
In conventional high power loudspeakers, 95 percent of the power input is converted into heat. In a 500 watt loudspeaker, that's 475 watts of heat, causing the voice coil to reach temperatures as high as 300 C. Apart from the obvious safety issues of this sort of heat, it badly affects loudspeaker performance through the 'power compression' effect and degraded bass performance. The potential for poor reliability is obvious.
Traditionally, cooling has been achieved by means of a vent in the rear of the magnet system, through which air is 'pulsed' as the cone vibrates. The degree of the vibration depends upon the level of bass and declines as the frequency increases. In some circumstances, the 'pulse' effect can be lost altogether, depriving the loudspeaker of an essential means of cooling. When this happens, only natural conduction from the outer surface of the magnet into the enclosure is left. And as the air in the enclosure begins to heat up, so even this system performs less well, and the loudspeaker losses even more efficiency.
In the Volt Radial, the chassis is fixed to the magnet centre pole and doubles as a giant heat sink. It is mounted on the surface of the enclosure and is thus always ventilated, an effect augmented by the movement of the cone. The magnet benefits from conduction cooling as well, and may also be rear vented to add to the overall benefit. This system typically runs at half temperature, power for power of conventional loudspeakers. Put another way, a conventional speaker starting a session at the same output as a Volt Radial may sound only half as loud at the end. And we have the figures to prove it!
Improved reliability
Lower coil temperatures mean less stress and fatigue. Coupled with Volt's use of 'space age' components and composites, the Volt Radial outlasts and outperforms standard speakers, power for power.
Sustained output
Because the Volt Radial voice coil runs cooler, it reduces the notorious 'power compression' effect. In a conventional loudspeaker, heat increases the resistance of the voice coil: the loudspeaker loses efficiency and delivers less output. But not the Volt Radial! It will draw up to 100 percent more usable power at maximum amplifier output, especially when hot, delivering almost 3dB more maximum sound than an ordinary speaker under the same conditions. That's nearly twice as loud and more cost effective!
Better bass
Hotter coils perform less efficiently, causing output quality to suffer. Bass sounds more 'boomy' and there's less depth, definition and punch. The conventional solution is to use more speakers.
Because the Volt Radial runs cooler, it avoids this effect, ensuring consistent, stable, top-quality output in all conditions.
Alex_Zapantis
http://www.quested.com/
http://www.quested.com/quested-users.html
http://www.quested.com/products-sm748.html
Digital loudspeaker management systems using high-performance 24-bit convertors running at 96kHz to give a bandwidth of over 30kHz and a dynamic range in excess of 116dB. A full complement of powerful equalisation and phase control to assist in expertly setting-up our custom systems.
Quested SM748
http://www.quested.com/pdfs/Quested-Custom-Systems.pdf
Quested HM415 - Single
The Quested HM415 is the largest Quested system and is capable of delivering 130dB and filling rooms UP TO 50 square meters (530 square feet). It uses the same compliment of low mid, high mid, and HF drivers as the HM412, and has the same electronics package. The bass drivers are four 380mm (15") units with an external radial chassis that offers improved cooling of the magnet and coil resulting in lower power compression and higher maximum output.
Νομίζω πως ο Roger Quested σχεδίαζε και studio, ενώ παλιότερα χρησιμοποιούσε μονάδες της Precision Devices.
http://www.precision-devices.com/
PD2150
6” copper voice coil assembly !!!
220 oz. ceramic magnet
Power compression 2dB at rated power *1
Distortion *2 2nd Harmonic <1%
3rd Harmonic <1%
*1 Power compression is the reduction of sensitivity at the specified power. Higher power ratings do not necessarily give a proportionate increase in SPL, therefore the maximum SPL of the PD.2150 may significantly exceed that of other manufacturers with high published power ratings.
*2 Distortion is measured at 10% of the rated power (AES Standard ).
http://www.thomann.de/gr/search_GK_palplk21_BF_precision+devices.html
http://www.thomann.de/gr/precision_devices_pd2150.htm
http://www.wilmslow-audio.co.uk/volt-61-c.asp
Δηλαδή αν κατάλαβα καλά είναι κυρίως ψύκτρα;Nice...
Αυτά τα Quested ομορφούλια είναι αλλά λίγο τσιμπημένα... Για το πορτοφόλι μου that is.
Alex_Zapantis
ΠΑΣΧΑΛΗΣ ΤΕΡΖΗΣ...
Ο "Κινδυνος" των τεχνικών προδιαγραφών. - Σελίδα 9:
http://www.avsite.gr/vb/showthread....9%E1%E3%F1%E1%F6%FE%ED.&p=1323829#post1323829
:116:
DISCLAIMER:
1. Τα όσα έγραψα παραπάνω ισχύουν για ΟΛΑ τα ηχεία στον κόσμο ΕΚΤΟΣ από τα TIDAL, μια και αυτά (σύμφωνα με όσα γράφουν τα τα fan boys) δε δεσμεύονται από τους νόμους της Φύσης.:135::143:
2. Σε κάθε περίπτωση, παρακαλώ να διαβάζετε τα όσα γράφω με μεγάλη δυσπιστία, μια και σπίτι μου έχω Adam, ενώ, προφανώς, η γνώμη κάποιου αξίζει τόσο όσο τα ηχεία (ή τα καλώδια) που έχει στο σαλόνι του.
Δε πειραζει ακου με Adam και γραφε στα forum παιζοντας το expert...
στο σπίτι σου έχεις άνταμ? και μιλάς? βρε άι χάσου!!!!!!!!
Alex_Zapantis
ΔΙΑΓΡΑΜΜΑ ΔΥΝΑΜΙΚΗΣ ΣΥΜΠΙΕΣΗΣ ΚΑΙ ΠΑΡΑΜΟΡΦΩΣΗ ΣΤΙΣ ΧΑΜΗΛΕΣ ΣΥΧΝΟΤΗΤΕΣ
http://profesional.beyma.com/ingles/productos.php
http://profesional.beyma.com/ingles/xls.php?xls=01_LOWMIDFREQUENCYDRIVERS
Δύο τελευταία διαγράμματα στη δεύτερη σελίδα:
http://profesional.beyma.com/ingles/pdf/21SW1600Nd.pdf
Αν μετρήσουμε τη δυναμική συμπίεση ως παραμόρφωση, τι νουμεράκια θα προκύψουν άραγες;:116:
Υπόψιν ότι μιλάμε για γούφερ 21 ιντσών, με μαγνήτη Νεοδυμίου, πηνίο φωνής διαμέτρου 5 ιντσών με διπλά τυλίγματα, και ικανότητα διαχείρισης ισχύος 1600 Watt κατά AES.
ΚΑΜΙΑ ΣΧΕΣΗ δηλαδή με τα καραγκιοζάκια που έχουμε σπίτι μας...
Α, και πού πέφτει άραγε η ευαισθησία του μεγαφωνακίου :)116:) αυτού στα 20 Hz;
Πόση ισχύς απαιτείται λοιπόν για να είμαστε σε θέση να αρχίσουμε να ακούμε τα 20 Hz με σαφήνεια;
Με το 21άρι υπόψιν...
Τι θα γινόταν άραγε αν αντί για ένα 21άρι είχαμε ένα 12άρι (με πολύ "μικρότερα" προσόντα μάλιστα);
γιατί θες να τρομάξεις τον κόσμο?
Alex_Zapantis
Επειδή είμαι κακός!
μπουααααααααααααααααααααααααααααααααααααααααααααααααα
χαχαχαχαχαχαχαχαχαχαχαχαχαχαχα
(κούρλι χέρς! ξεκίνα τα άμπαφλα για να κατουρηθούν όλοι απάνω τους!)
Alex_Zapantis
All in good time my friend.
Για την ώρα, τι μπορούμε να σας προσφέρουμε;
Κάτι σε κεραμικό;
PD2450
Ή κάτι σε νεοδύμιο;
PDN2450
Δε θα "πιάσω" κανα τζόκερ ρε μπαγάσα να σου κουβαλήσω καμια ντουζίνα στη Σαλόνικα;:135:
Θα τον "φάμε" τον άτιμο τον back...:116:
Απάντηση: ΠΑΣΧΑΛΗΣ ΤΕΡΖΗΣ...
:116:
DISCLAIMER:
ειλικρινα σου μιλαω μπηκα 3 φορες στο δωματιο της Klein & Hummel τις δυο μερες που πηγα στην εκθεση... (στα Adam δε μπορεσα να ξαναμπω)....
μιλαμε οτι ο ηχος ηταν σε επιπεδο καφετεριας και πολυ λεω... δε ξερω εαν εφταιγαν τα super ηχεια η η πηγη που ηταν ταυτοχρονα transport/DAC/digital equalizer/preamp αλλα μιλαμε για ηχο ανεκδοτο και λιγα λεω.... μονο το σετ της devialet με τα Magico ακουγονταν αξισου αισχρα.... (ξαναλεω τα Adam ηταν ακομα μια φορα εκτος συναγωνισμου για γελια )
πραγματικα σκεφτομουν ποιος κακομοιρης θα παει να αγορασει καποιο ηχειο απο αυτα που προτεινουν καποιοι εδω μεσα και πως θα αντιδρασει οταν θα τα στησει να τα ακουσεi. Μιλαμε πρεπει να εισαι μεγαλο πειραματοζωο....
οσο για τα μικρα Tidal που κοροιδευει ο guru απλα για πλακα ειχαν τον καλυτερο ηχο στην εκθεση και ξεφτιλισαν οτιδηποτε υπηρχε εκει μεσα ανεξαρτητως κοστους.... δε μιλαμε για καλυτερο ηχο απλα, μιλαμε για τσοντα.... (ενω τα μεγαλα Tidal T1 επαιζαν κυριολεκτικα απαραδεκτα για τα λεφτα τους αλλα επειδη τα εχω ακουσει πολλες φορες μαλλον τα συνοδα ειναι λιγο φουσκα)
καληνυχτα και περαστικα...
Η καθε ενημερωση δεκτη κι ευχαριστη, γιατι ομως τοσο επιθετικος?
Να ρωτησω κατι, κατα την γνωμη σου αυτα που ενδεχομενως περιμενες να παιξουν καλλυτερα και σε διεψευσαν, αποκλειεις να τα επηρεασε σε μικρο η μεγαλο βαθμο ο χωρος? Δεν σου κρυβω οτι για τα Κ+Η λογω των πολλων δυνατοτητων (τουλαχιστον στα χαρτια) θα περιμενα να τα επηρεαζε ο χωρος λιγοτερο απο οποιαδηποτε αλλα.
Αλεξη, τελευταια πολυ κεραμικο παιζει, μια η XTZ μια τα Tidal, λεω να βαλω και τα δικα μου να στηριζονται σε κατι κεραμιδια που με περισεψαν, λες να υπαρξει βελτιωση? Δεν μπορει κατι θα ξερουν οι ανθρωποι!!
Evasound
