Δοκιμή του Apple TV2
Απάντηση: Δοκιμή του Apple TV2
Υπάρχει νέα διορθωτική έκδοση του XBMC η 11.0 Eden RC2
Νέο firmware version 5.0 (9B179b) για το Apple TV2.Μέχρι να βγει jailbreak γι αυτή την έκδοση δεν αναβαθμίζουμε!
aTV Flash Black 1.4
Full Changelog
NEW: Center channel audio boost (+6dB and +12dB) for 5.0 and 5.1 audio tracks
NEW: Finnish, German, Japanese, Norwegian, Polish, Russian, and Swedish translations
NEW: '4:3 Crop' and '4:3 Stretch' zoom options
NEW: Support for M3U and PLS playlists
NEW: EyeTV folder detection
NEW: TrueHD audio (downmixed)
NEW: 24-bit and 32-bit audio (downmixed)
NEW: Enhanced downmixing for 5.1 AC3 audio (Dolby Pro Logic II)
NEW: Support for embedded MP3 covers
NEW: Automatic EXIF-based image rotation
NEW: MP4s embedded subtitles
NEW: Clock added to main menu
IMPROVED: Poster art quality in list and grid view
IMPROVED: Buffering logic for DVD files
IMPROVED: Cover art fetching from Last.fm
IMPROVED: DVD menu highlighting
IMPROVED: Photo viewer & slideshow
IMPROVED: Adjusted slideshow to match native Flickr style
IMPROVED: Danish, Dutch, French, Greek, Italian, Brazilian Portuguese, and Spanish translations
IMPROVED: Minor UI improvements
FIXED: Downmixing issues for specific audio tracks
FIXED: Playback issues for single ISO files in a folder
FXIED: Increased AFP login timeout to 30 sec
FIXED: Metadata issues for files that contain '/' in folder or file name
FIXED: Operation of the photo slideshow on iOS 4.x
FXIED: Issue with favorites removal when share password is changed
FIXED: Incorrect navigation in grid view on iOS 4.*
FIXED: Issue with DVD marked as watched after viewing menu
FIXED: Rare issue with incorrect pre-playback screen layout
FIXED: Rare crash in libdvdnav when playing DVD files
FIXED: Rare DVD playback error
FIXED: Rare 'Bad URL' error
FIXED: Other miscellaneous bug fixes
Καλησπερα Λεωνιδα!
Τι γινετε? Διαβαζω σε ενα post στο site της firecore οτι οσοι δοκιμασαν το 5.1 iOS στο ATV2 δεν μπορουν να κανουν re-jailbreak στο 4.4.4 ακομα και αν εχουν σωσμενα τα blobs τους! Ισχυει αυτο? Για πες εχυ που εχεις πιο πολλα κονε με αλλα sites! :)
Απ'ότι φαίνεται ισχύει.Υπάρχουν πολλά δημοσιεύματα γι αυτό το θέμα.Γι αυτό σε καμμία περίπτωση δεν δοκιμάζουμε την 5.1 μέχρι να βγει αναβάθμιση για το Seas0nPass!
Το jailbreak για το firmware 5.0 του Apple TV (iOS 5.1) είναι σχεδόν έτοιμο και πιθανόν να βγει την Παρασκευή 16/3,ώστε να συμπέσει με την επίσημη κυκλοφορία του Apple TV3!
Γεια σας, είμαι νέος εδώ στο φόρουμ σας.
Αντιμετωπίζω τα εξής προβλήματα με το ATV2
Το ένα είναι ότι όταν κάνω sharing π.χ. τον δίσκο D , όταν πάω να τον βρω μέσα από το xbmc μου ζητάει username και pass! Ενώ στο pc μου δε μπαίνω με κανένα κωδικό admin. Τι ακριβώς βάζω εκεί ώστε να μου δώσει πρόσβαση? (στο sharing δινω full access)
Να πω επίσης ότι έναν εξωτερικό δίσκο που έχω τον βλέπει κανονικά και δε μου ζήτησε κάποιο user/pass.. Μόνο στο C και D μου το κάνει. Καμιά βοήθεια?
Και δεύτερο, όταν βλέπω κάποιες ταινίες που είναι π.χ. mkv 720p και πάνω από 2 ώρες ταινία μου κάνει συχνά bufferings. Ενώ σε ταινίες μικρότερης διάρκειας και αρχείου, δεν συμβαίνει κάτι. Πως μπορώ να το δω αυτό? Να το διορθώσω?
(σε αυτό το σημείο να πω ότι έκανα αλλαγή στις ρυθμίσεις audio μέσα στο xbmc αλλά δεν έγινε τίποτα. συνεχίζει το buffering)
Σας ευχαριστώ
Δεν τα ξέρω τα windows αλλά νομίζω πρέπει να κάνεις δεξί κλικ στο φάκελλο του δίσκου με τις ταινίες και να επιλέξεις allow guest ή κάπως έτσι.
μα εχω δωσει οπως ειπα full access για everyone!
Το αλλο με το buffering? τι εχεις να πεις?
Μαλλον πρόβλημα του xbmc είναι.Δοκίμασες και με το Plex να δεις αν έχεις buffering?
δε το εχω δουλεψει αυτο καθολου! πως λειτουργει?
Θα κατεβάσεις το Plex Media Server στον υπολογιστή σου,θα ορίσεις ποια αρχεία από το pc ή το δίκτυο (αν έχεις δικτυακό δίσκο) θα σου σκανάρει για εξώφυλλα,περίληψη κλπ
Από το μενού του nito tv θα εγκαταστήσεις τον Plex Client στο Apple tv.
Είναι σαν το xbmc με τη διαφορά ότι πρέπει να είναι ανοικτός και ο Plex media server στον υπολογιστή για δει τις ταινίες ο plex client στο apple tv
θα το δω αυριο και θα σου πω...για να δουμε... χιλια ευχαριστω
Και για το xbmc,πιστεύω να έχεις την τελευταία έκδοση 11.0 Eden για το apple tv.Παλιότερες εκδόσεις είχαν προβλήματα!
ναι εχω το ATV Flash (Black) version 1.4.1 οποτε εχει το τελευταιο. για το πλεξ δε καταφερα τπτ. δε μπορεσα να το σεταρω. δε ξερω τον τροπο δηλαδη με τους σερβερς κτλ.
Σε jailbreak atv2 ΤΩΡΑ με άψογη ροή η συνέντευξη του προέδρου του ΠΑΣΟΚ Ευάγγελου Βενιζέλου,στον Νίκο Χατζηνικολάου!
Δεν το κάνω για προπαγάνδα υπέρ του Πασόκ,υπέρ του Apple tv είναι!:116:
Θα υπάρξουν συνεντεύξεις με όλους τους αρχηγούς των πολιτικών κομμάτων στο enikos.gr που μπορούμε να τις παρακολουθούμε στο Apple tv!:126:
aTV Flash (black) 1.5
Full Changelog
Revamped player with improved performance (AppleTV 4.4 and later)
Added NFS streaming
Added Catalan, Czech, Korean and Traditional Chinese translations
Added support for localized TV show pattern: TV Show/Season #/S##E##.extension
Added manual subtitle time correction (-10.0s to +10.0s)
Added support for embedded .FLAC cover art
Added support for .AC3, .DTS and .MOD files
Improved .EYETV file handling
Improved audio synchronization in slow and unstable networks
Improved slideshow operation with small images
Improved movie folders detection logic to ignore hidden files
Improved metadata fetching to support movies split into multiple files (dvd#, cd#, disk#)
Improved zoom mode operation for non-square pixels
Improved DVD menu handling
Improved .OGG file handling (now correctly treated as audio)
Improved error handling for connection issues
Improved buffering logic
Improved installation routine
Other minor UI improvements
Resolved format detection that was causing rare playback issues
Resolved issue with volume level resetting during rw/fw
Resolved floating crashes usually observed when using SMB with Windows 7 shares
Resolved conflicts with XBMC related to SMB
Resolved issues with metadata fetching for 'Show.Name.###.extension' pattern
Resolved crashes observed in folders with significant number of files
Resolved playback error on DVD and ISO files observed when file path contains '?' character
Resolved crashes when working with long file paths
Resolved rare issue with incorrect pre-playback screen layout
What about the ATV3 and the untethered version for ATV2?
Work is still underway on both fronts, and we've had some encouraging reports come in over the past few days. However, it's still too early to give any kind of ETA but we hope to have more news soon. For the latest updates be sure to follow us on Twitter.
Andrewk
