Πόσο ρεύμα αντέχουν τα ηχεία μας ?
Y
Yiannis_B
Απάντηση: Πόσο ρεύμα αντέχουν τα ηχεία μας ?
Και όμως...η αλήθεια είναι κάπου στην μέση.
http://www.avsite.gr/vb/showthread....an-average-of-1-Watt-with-fully-dynamic-music!
"A 100 Watt amplifier can only be used at an average of 1 Watt with fully dynamic music.
For this reason amplifiers less than 60 Watts should not be considered as audiophile status, but unfortunately many are.
Music is capable of a 60dB (1,000,000:1) dynamic range.
The transients in music are very small in energy but are approx 20dB above the RMS music level.
The average RMS power of fully dynamic music can not go above -20dB of the amplifiers full power capacity without the transients clipping the rail supplies.
20dB is 100:1 so therefore a 100 Watt amplifier should not be driven above 1 Watt of RMS music level (over approx 1 minute of time) to avoid transients being driven into rail clipping.
The modern digital recording trend is to dynamically compress music in an attempt to remove all the dynamic range which includes transients.
Dynamic compression allows music to be played at higher power without transient clipping.
However excessive dynamic compression imposes extreme inter-modulation distortion.
Voices and instruments are squashed and mangled together, rendering articulation of voices and instruments so removed from sounding natural that it is often difficult to recognise.
The largest problem of this irresponsible recording behaviour in pop recordings, TV programs and films is that it makes it difficult to understand the words being sung or dialogue spoken.
The inter-modulation distortion including the removal of articulation caused by dynamically compressing music is so great (approx 30% distortion), that audiophiles and professional sound installers pretending to be concerned about inaudible time alignment differences of speaker driver components on a baffle board is delusion to say the least.
Also dynamic compressed music is already so distorted by the dynamic compression in the recording process that it can be driven into supply rail clipping without being audibly noticed in comparison to the distortion created by dynamic compression.
The maximum level an amplifier can be driven with dynamically compressed music before the added distortion caused by clipping into the rail supplies becomes objectionable, is 1/3 of the equivalent energy of a sine wave at full power.
Worse still, in most live concerts the music is further compressed so the average RMS power can be taken close to 1/2 full power of the amplifiers capacity.
In this condition many professional high power amplifiers will shut down from overheating."
http://www.lenardaudio.com/education/12_amps_5.html
με αυτη τη λογικη δεν θα επρεπε να υπαρχουν τελικοι κατω απο 400 βατακια.......
υπαρχει κοσμος που ζει με 20-25 βατ , και δεν τα αλλαζει με τιποτα......
αυτο δε σημαινη οτι ακουη και σωστα μονο οτι του αρεση και ως γνωστον ο πελατης εχει παντα δικιο.
pop ? tv progr?
εδω μιλαμε για μπρουταλ καταστασεις
ο μαρκου παλευει ποσα χρονια να σπασει την τζαμαρια (μπας και δει χαρα)
και δεν του βγαινει........:136::143:
το δικιο του πελατη , ειναι το σωστο
δικα του ειναι τα λεφτα αυτος τα ζμπρωχνει οπως θελει
αλλος τα κανει ηχεια γομαρια και ενισχυτικα ετοιμα να εκτιναξουν καθε κωνο απο το ηχειο,
και αλλος παιζει με λαμπιτσα , κορνακι , και δεν θελει να βλεπει μοναδα ανω των 7 ιντσων
και ρευμα μεγαλυτερο των 20 βατ
αβυσσος η ψυχη του ανθρωπου.................
Y
Yiannis_B
....ας ήταν φτηνοί και στο μέγεθος μια 300Β λαμπάτοι των 500W, και να δούμε ποιοι θα προτιμούσαν τους μικρούς.....:116:
ας ηταν φτηνα και τα
καλωδια που παιζουν
ηχεια που σε τρεμουν
χωροι χωρις προβληματα
και θα ειμασταν ολοι ευτυχεις
αλλα αν ηταν ετσι
(οπως εχω ξαναπει)
θα μας ελεγαν (καθε μερα)
περαστε να παρετε τον δωρεαν ενισχυτη σας, για πλεον δεν πουλαμε -(τα μικρα) χαριζουμε.
Αλλα ακομα το αφεντικο δεν τρελλαθηκε, και ο τζαμπαμαν πεθανε.........πανω απο 200 χρονια.........χαλαρα
Y
Yiannis_B
....αποπροσανατολίζεις την συζήτηση. :105:
Εννοώ ότι αυτοί που ακούν από τρίοδες, το κάνουν για το ηχόχρωμα. Αν τους το έδινες μαζί με την ισχύ, κανένας δεν θα έλεγε όχι. Και η JBL μαζί με την ATC θα κάναν πάρτυ....
αν το πατινι ειχε μαλλα θα το λεγανε γιαγια
κατα τα αλλα καθεις πρατει κατα το δοκουν
μιλαμε οτι κατουρηθηκα στο γελιο...
Βάρος 100 κιλά. Σκέψου πώς θα παίζει... :114:
1 βατ στο κιλό? μα πάνε καλά?
νασαι καλα ρε Σταθη........μεφτιαξες.:615:
Katerinanota
