Skybox F5 Review !!!
Skybox F5
Specifications :
1.Support GPRS, and it is external
2.Full HD 1080p
BASIC FEATURES:
1) Dual-Core CPU, 396 MHz MIPS Processor
2) Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level
4.1;
3) Fully compliant MPEG-2 MP@HL & MP@ML;
4) Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3);
5) SCPC & MCPC receivable from C/Ku band satellites;
"6)Multiple LNB-Switching control
(supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)"
7) NIT search supported;
8)support biss
9) Support HDMI 1.3;
10) Support PVR(store in USB disk);
11) Multimedia files playback(by USB);
12) Support Electronic Program Guide(EPG) for 7 days;
13) Teletext and subtitle out through OSD;
14) Support multi-lingual DVB subtitle and teletext;
15) Automatic and manual channel scan options;
16) Automatic service scan
17) channel-change time < 1 second
18) OSD in many languages and skin-support
19) Multilingual support on screen menu (OSD): English, French, Deutsch,
Italian, Spanish,
Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech,
selectable; "
20) Multiple display mode:1080P/ 1080i/720p/570p/576i/480p;
21) MPEG-4 / H.264 Hardware decoding
22) Videotext Decoder
23) Analog audio output: stereo(L+R);
24) Digital audio output: S/PDIF by coaxial and optical(optional);
25) S/PDIF Interface for digital bit stream out (AC-3)(optional);
26)support dongle
27)1x Scart & AV
28) Screen format: auto, 4:3, and 16:9;
29) Upgrade software through USB2.0 port;
30) Powerful program management function, parent lock
Package
1x F5 HD Box
1x Remote control
1x Power Supply Cable
1x HDMI Cable
1x User Manual
Απάντηση: Skybox F5 Review !!!
Το review ειναι ανεξαρτητο, δεν μου εχει δωσει καποιος τον δεκτη , οπως επισης δεν γνωριζω αν εχει γινει καποιο review του σε καποιο-α απο τα περιοδικα και τι ακριβως εχει γραφτει.
Προερχεται απο την Κινα ,που γινεται και η κατασκευη του, και βασικα επελεξα αυτον τον δεκτη καθως παρουσιαζεται να ειναι ο πιο φθηνος της αγορας.
Περα απο αυτα που εχω σκεφτει να τεσταρω , αν καποιος επιθυμει κατι ,ας το γραψει, και θα τεσταριστει.
Λογω ομως αρκετων ασχολιων ,πιθανοτατα το τεστ θα κινηθει με ρυθμους χελωνας .
Παντως θα περασει απο πριονοκορδελα, οπως και ολοι οι δεκτες με τους οποιους εχω ασχοληθει.
Εχω σκοπο να τεσταρω :
1)To hardware (θα αναφερθω σε πολυ μικρο βαθμο)
2)Το software
α)Ποιοτητα εικονας σε SD & HD καναλια .
β)'Φιλικο' Μενου κτλ.
γ)Cardreader
δ)Γλωσσα κ' epg
ε)Κολληματα,επανεκκινησεις κτλ.
ζ)usb PVR
η)emu - κλ*ειδια - Δικτυο
θ)Diseqc 1.2
ι)wifi
κ)media player δυνατοτητες
και αλλα που πιθανως τωρα μου διαφευγουν ........
Ο δεκτης μοιαζει πολυ με τα Netgear router ,τουλαχιστον αυτο μου ερχεται εμενα στο μυαλο οταν τον βλεπω .
Εχει εξωτερικο μετασχηματιστη με οτι αυτο συνεπαγεται και φυσικα ξεχωριζει με τους μεχρι τωρα δεκτες οι οποιοι ειτε ειχαν εσωτερικα την πλακετα τροφοδοσιας κ' την κυρια πλακετα η' οπως οι περισσοτεροι linux, εξωτερικο τροφοδοτικο και εντος μονο η κυρια πλακετα.
Φυσικα σε αυτο τον δεκτη εχει επιλεχτει η πιο φτηνοτερη λυση.
Στην προσοψη απεικονιζεται ο αριθμος του καναλιου και σε καποιες περιπτωσεις καποια γραμματα.
Στο πισω μερος υπαρχει υποδοχη scart, AV κ' ΗDMI .
Επισης η υποδοχη του lnb και loopthrough .
Μειονεκτημα θεωρω τη μονο μια υποδοχη usb ,που σε περιπτωση που καταληφθει απο τη wireless κεραια η' απο ενα usb stick η' σκληρο δισκο, καποιο απο αυτα που θεωρειται σχετικα απαραιτητο, μενει απ' εξω.
Ισως αυτο λυνεται με ενα usb hub ???
Η ποιοτητα εικονας ειναι αρκετα καλη στα HD κ' καλη στα SD καναλια .
Βασικα δεν εχω συγκρινει με αλλους δεκτες χωριζοντας την οθονη μιση μιση ,αλλα σε καμμια περιπτωση δεν μπορεις να πεις οτι καποια SD καναλια δεν βλεπονται, απο αυτα φυσικα που εχουν μια σχετικα καλη ποιοτητα εικονας .
Βασικα ενα θεμα υπαρχει με τις CRT TV και λογω κυριως τον χρωματων του δεκτη που εχουν επιλεχτει (Μαυρο-πορτοκαλι) που σε δυσκολευει καπως να διακρινεις.
Θα επανελθω με καποιες εικονες απο τα μενου και καποια ακομα στοιχεια .
Το τελευταιο patch για τον δεκτη ειναι αυτο :
http://www.sendspace.com/file/yvc2xo
Να συνεχισω με μερικες φωτο .
Βιαστικα εβγαλα καποιες με κινητο .
  • 45,1 KB Προβολές: 39
  • 44,1 KB Προβολές: 48
  • 35,7 KB Προβολές: 44
  • 39,9 KB Προβολές: 42
Να πω μερικα πραγματα ακομη.
Το τ/χ ειναι απλο οχι κατι το ιδιαιτερο αλλα ουτε και κακο .
Χρειαζεται να στοχευσεις σε συγκεκριμενη επιφανεια για να πιανει .
Η αποκριση δεν ειναι τοσο καλη ,υπαρχει μια μικρη καθυστερηση του χρονου πατηματος του κουμπιου μεχρι να εκτελεστει η εντολη.
Το μενου δεν ειναι τοσο ευχρηστο καθως π.χ. μπερδευεσαι με την επεξεργασια των καναλιων .
Το ιδιο συμβαινει και με τον δορυφορο,αλφαβητικα κτλ.
Ελληνικο μενου υπαρχει αλλα οχι Ελληνικο epg.
Yποστηριζει στην πραξη Diseqc 1.2 και το καλο ειναι οτι μπορεις να βαλεις χειροκινητα θεση αποθηκευσης δορυφορου.
Το βημα κινησης του μοτερ ειναι 2 ,και ειναι πολυ μικρο .
Το μηνυμα 'moving dish' βγαινει παρα πολυ συχνα και πολλες φορες δεν φευγει παρα μονο με το exit .
Στην ανιχνευση υπαρχουν 3 επιλογες : accurate ,preset & blind scan .
Δεν μπορω να καταλαβω τι προσφερει η μια παραπανω απο την αλλη .Aπλως η μια απο την αλλη κανει παραπανω χρονο και η preset σου δινει και την επιλογη του Network .
Καποιοι κυριοι δορυφοροι δεν υπαρχουν στην βαση δεδομενων και πρεπει να προστεθουν χειροκινητα.
Εμφανιζεται να εχει 32 λιστες για αγαπημενα .
Προγραμματισμενες εγγραφες : 8
Στον αναγνωστη καρτας υπαρχουν και επιλογες για emm, boxkey κτλ.
Το wifi δεν μπορει να λειτουργησει με αλλη κεραια πλην της δικιας του απ' οτι φαινεται.
Να επανελθω με μερικες πληροφοριες ακομα .
-Η εγγραφη γινεται σε .ts και η αναπαραγωγη του αρχειου γινεται ευκολα στο PC .
Καλυτερα να επιλεγετε να κανετε εγγραφες σε σκληρο δισκο και οχι σε usb stick .
-Σαν media player ,διαβαζει ολα τα format που δοκιμασα : .mkv, .avi , .divx , .mp4 (απο 800mb. - 4 gb. αρχεια ειχα) .
Οι υποτιτλοι για να αναγνωριστουν, πρεπει να ειναι σε κωδικωποιηση utf-8 και μονο .
Βεβαια καποιες σειρες υποτιτλων βγαινουν σε μια εξτρα γραμμη η' λιγο πιο δεξια .
Δηλαδη δεν ειναι τοσο ομαλη η εμφανιση τους .
θελω να ρωτησω αν αξιζει να αλλαξω εναν Spiderbox 7000 που εχω με τον παραπανω δεκτη. Βασικα στον Spiderbox 7000 ειμαι ικανοποιημενος απλα με κουραζουν οι λιγες λιστες αγαπημενων.
John 75, ως ειδικος και στους Spiderbox, θεωρεις οτι ο δεκτης Skybox F5, ειναι καλυτερος απο τον Spiderbox στα:
1)Ποιοτητα εικονας
2)Λιστες αγαπημενων
3)Ταχυτητητα εναλλαγης καναλιων
Απο που αγορασες τον δεκτη και ποσες ημερες κανανε να στον στειλουνε.
Μηπως τελικα αξιζει να αγορασω τον Cloudbox HD ?
Απάντηση: Re: Skybox F5 Review !!!
1)Ποιοτητα εικονας
2)Λιστες αγαπημενων
Καμμια σχεση δεν εχει με Spiderbox .
Κανενας δεκτης δεν ειναι καλυτερος του ,ουτε και αυτοι που υποθετικα εχουν 2 επιλογες software ,Spark-E2
1)Οχι .
2)Εχει μεχρι 32 .Και στον Spiderbox αλλα και σε αλλους δεκτες μπορει με 'τρικ' να υπαρξουν πολλες λιστες.Χρησιμοποιησε τη λιστα καναλιων του billybits να δεις πως γινεται.
3)Οχι.Καποιες φορες υπαρχει στιγμιαια καθυστερηση.
Περιμενε να διαβασεις και την παρουσιαση του Spiderbox 2 και αποφασιζεις .
Γι' αυτο αλλωστε κανω καποιες παρουσιασεις.Νομιζω βγαινουν αρκετα συμπερασματα για να μπορει καποιος να καταληξει στο τι θελει.
Σε ευχαριστω για την απαντηση σου.
Ποτε θα βγει ο Spiderbox 2 και ποσο θα κοστιζει ?
Μαλλον απο Δευτερα.
Γυρω στα 110-120Ε με τα μεταφορικα.
Re: Απάντηση: Re: Skybox F5 Review !!!
Μαλλον απο Δευτερα.
Σε ευχαριστω πολυ για τις πληροφοριες σου και αναμενουμε απο εσενα ενα review.
Να ρωτησω, το usals δουλευει?
Βημα κινησης τι ακριβως ειναι?
Το μηνυμα moving dish βγαινει χωρις λόγο?
Τι ειδος και μεγεθος πιατου κινησες?
Usals οχι γιατι στο ενα κατοπτρο εχω προβλημα απο τα ανατολικα και στο αλλο απο τα δυτικα.
Δεν το ρισκαρω να εχω προβλημα.
Δουλευει με diseqc1.2 , και το βημα κινησης ειναι το βημα που δινεις αντολικα η' δυτικα για να βρεις εναν δορυφορο χειροκινητα.
Κινησα κατοπτρο 1,00μ. και 1,25μ. μεσω positioner .
Το μηνυμα moving dish βγαινει πολυ συχνα και ειναι πολυ σπαστικο.Με το exit φευγει .
πριν μερικες μερες αγορασα κ εγω τον SKYBOX F5 και του περασα το cccam.cfg με 6 clines. εβαλα επισης το cccam.prio αλλα η εναλλαγη καναλιων ειναι απελπιστικα αργη.
εβαλα τα ιδια αρχεια σ ενα dm 500s που εχω και η εναλλαγη ηταν αρκετα πιο γρηγορη.
μηπως μπορειτε να με βοηθησετε?
George Markop
