Grimm Audio LS1
Κώστας Φ.
Για την Grimm Audio είχα βρει την ευκαιρία να σας μιλήσω εδώ.
Αλήθεια, πέρα από τα υπόλοιπα, το "ηχειάκι" τους το προσέξατε;
Νομίζω αξίζει να του ρίξουμε μία προσεκτικότερη ματιά.
Features
  • Two-way active loudspeaker with DSP crossover and correction
  • Extremely accurate frequency and time domain response
  • Minimum phase, zero pre-echo impulse response
  • Sealed enclosure: precisely controlled bass response
  • Wide baffle: controlled dispersion down to 250Hz
  • Digital and analogue inputs
  • MIDI I/O
  • Daisy-chainable
  • Easy subwoofer integration
  • User-settable low corner and baffle step correction
  • Compatible with 32kHz to 192kHz sampling rates
Specifications
  • Frequency response: 55Hz-22kHz +/-0.5dB. 45Hz-30kHz -3dB. (Low corner is user-settable between 35Hz and 100Hz, Q=0.7 or 0.5)
  • Deviation from minimum phase +/-2º
  • Amplifier power: 2x120W
  • Max SPL: 109dB/1m
  • SNR: 114dB (unweighted)
  • Crossover function: 1.2kHz LR4, sum corrected to minimum phase.
  • Latency: 2ms
  • Internal volume: 16 litres
  • Height: 1450mm, 1150mm available on demand.
  • Width, depth: 520mm x 160mm
Αξίζει να δείτε και το φυλλάδιο για περισσότερα: Leaflet
Σελίδα κατασκευαστή: Click
Όχι κι άσχημα, έτσι; :144:
Κώστας Φ.
Ενδεικτικά...
Electronics
Digital input signals are re-clocked by an ASRC circuit driven
by the same oscillator circuit as found in the award winning
Grimm CC1
AD/DA is 24 bits at 187kHz, an odd frequency
deliberately chosen to be clear of any multiple of common
audio rates.
The DSP is a 48-bit unit with a 76-bit accumulator.
The output signal from the D/A circuit is directly fed to a pair
of 120W “UcD”
high-efficiency amplifiers, wired to take
feedback directly off the voice coil
instead of the amplifier
output terminals.
Κώστας Φ.
Στο diyaudio βρήκα μία ενδιαφέρουσα αναφορά/σχόλιο του Linkwitz στη δουλειά του Bruno:
from interview with Siegfried Linkwitz
Audioxpress 7/2011
"JD: Looking at your Orions, I can’t
but wonder whether that purposedesigned
analog crossover cannot be
replaced by a DSP unit?
SL: In principle, I am convinced that
it can be done. But it’s not trivial. You
need to measure and adjust the whole
chain, analog in to sound out. Now
someone may come up with an FIR filter
that makes everything linear phase,
but you get pre-ringing from the filter
and the sound may combine correctly
at one point in space but what about
off-axis?
You could use IIR filters to mimic the
analog filters, and that would probably
be my approach. Then I would first
make the amplitude response correct
and then you can do an overall phase
response correction of the complete
system. That’s how Bruno Putzeys
does it in his Grimm Audio two-way.
And I would not buy a standard DSP
box off the market. The devil is in the
details. But it’s hard, and it’s not on my
to-do list!"
Τελικά κάτι ξέρει αυτός ο Bruno.
Με το κράξιμο που τρώει για την "υπερβολική" χρήση feedback και την ενασχόληση με "μάπα" Class D ενισχυτές, είχα αρχίσει να πιστεύω ότι είναι άσχετος...!
Κώστας Φ.
Και η Hypex πουλάει καλώδια καιρό τώρα!
Πώς θα ανεβάσουν το HiEnd προφίλ τους;! Αυτή η κουφάλα ο Tent τα κάνει όλα, είμαι σίγουρος!
Απάντηση: Re: Munich High End Show 2013
Θα παίζνε;
Αποκλείεται! Έχουν ψηφιακούς ενισχυτές - απ' αυτούς που κατακερματίζουν το σήμα, δεν έχουν λάμπες, δεν έχουν κόρνες, δεν είναι OTL, δεν έχουν ενισχυτή τάξης Α', δεν... Το μόνο τους προσόν: είναι ακριβά. Κάτι είναι κι αυτό...
Αποκλείεται! Έχουν ψηφιακούς ενσιχυτές - απ' αυτούς που κατακερματίζουν το σήμα, δεν έχουν λάμπες, δεν έχουν κόρνες, δεν είναι OTL, δεν έχουν ενισχυτή τάξης Α', δεν... Το μόνο τους προσόν: είναι ακριβά. Κάτι είναι κι αυτό...
Ξέχασα το κυριώτερο! Δεν αρέσουν στον Τσαντουλή, ούτε βέβαια στο υπόλοιπο ACA...
VLASSIS-S
Sιγμοειδής Νέμεσις
Re: Απάντηση: Munich High End Show 2013
... και μια παρασκηνιακή είδηση από την έκθεση. Τα Grimm Audio έρχονται και στην Ελλάδα.
Μην ξαναπει κανεις οτι δεν ειναι ωραια τα Χαρμπεθ ...
vlasis
Φωτογράφος!
Απάντηση: Re: Απάντηση: Munich High End Show 2013
Where the f@cken tomatoes?????????????????????????????????:biggrin:
VLASSIS-S
Sιγμοειδής Νέμεσις
Γιατι μαρη, θα τα εβανες στο σαλονακι σ' ???
Μάλιστα... συνομιλίες μεταξύ Χάλι-εντάδων... :rolleyes: :laugh:
vlasis
Φωτογράφος!
θα σε καλεσω παντως να τα ακουσουμε παρειτσα........καποια στιγμη.....
Βλακείες λες !!!
1) Μου αρέσουν ιδιαιτέρως και αν ήταν φτηνά θα αποτελούσαν διακαή στόχο μου.
Το όλο "πακέτο" είναι εξαιρετικά ενδιαφέρον απο κάθε άποψη.
Γουστάρω και μάλιστα με χίλια αυτού του είδους τις σχεδιάσεις- υλοποίησεις.
2) Άσε τις αναφορές στο aca. Απλά είναι άστοχες. Αλλωστε είναι γνωστό ότι διατηρώ καλώς ή
κακώς καλύτερες σχέσεις με το avsite από ότι με το aca. Και μην εντοπίζεις την προσοχή σου σε
σέ κάποιες γραφικότητες που αναπόφευκτα υπάρχουν παντού. Στο aca για παράδειγμα
υπάρχουν επιστήμονες ηλεκτρακουστικής που έχουν αδελφική σχέση με τον Μουρτζόπουλο.
Ώρες ώρες απο έλλειψη επαρκών δεδομένων- στοιχείων γίνεσαι εμπαθής και άδικος....
Κώστας Φ.
Re: Απάντηση: Re: Munich High End Show 2013
E, και;
"Ε,και";;;;;;;;;
CC, ακόμα δεν έχεις καταλάβει ότι τα ετερόφωτα σώματα δε γίνονται αντιληπτά αν δεν πέσει επάνω τους φως από γειτονικά αυτόφωτα;
Φαντάζομαι θα πέσεις από τα σύννεφα αν σου πώ ότι τα πρώτα αποτελούν τη συντριπτική πλειοψηφία στον κόσμο μας και - ακόμα χειρότερα - η ίδια τους η ύπαρξή εξαρτάται άμεσα από τα αυτόφωτα (άπειρα τα παραδείγματα από τον μικρόκοσμο εώς τον μακρόκοσμο).
Πέρα από τη... δεδομένη έλλειψη δεδομένων (pun intended), διακρίνω και έλλειψη γνώσεων! :biggrin:
Άντε μετά ο Βασίλης να βγάλει άκρη μαζί σου!!
Πάνε και τα Grimm.... Θα τα μαγαρίσούν κι αυτά με "ακροάσεις"...
vlasis
Φωτογράφος!
Απάντηση: Re: Απάντηση: Re: Munich High End Show 2013
"Ε,και";;;;;;;;;
Ναι ναι....θα τα μαγαρισουμε!!!!!!!
vlasis
Φωτογράφος!
:biggrin: Οεοοοοοοο.....και συ θα σκασεις Κρητικιε!!!!!!!
Katerinanota
