Eλα να τσακωθούμε ντάρλινγκ....
vlasis
Φωτογράφος!
:fuckyou:Τελικα υπαρχουν και καποιοι τυχερακιδες που εχουν ενσωματωμενα καλωδια ρευματος.....οι κωλοφαρδοι.......
Τα καλύτερα καλώδια είναι τα HDMI....άσχετοι........χωρίς πλάκα.
Ορίστε και τα αποτελέσματα μιας έρευνας (που ούτε στον ύπνο μας δεν μπορούμε να κάνουμε) την οποία διάβασα τυχαία λόγω κάποιας επαγγελματικής ενασχόλησης.
2012 IEEE Nuclear Science Symposium and Medical Imaging Conference Record (NSS/MIC)
Application of HDMI® Cables as an MRI Compatible Single Cable Solution for Readout
and Power Supply of SiPM Based PETDetectors.
(Το MRI είναι μαγνητικός τομογράφος και ένας καλός κοστίζει 1-2.000.000)
Αποτελέσματα:
The performance of the PET detector was unaffected when operated inside a 7T MRI system.
The MR images showed degradation in signal to noise ratio (SNR) of between 7 and 23%, which is believe to be due to coupling between the RF coil and the PET detector shielding (για να μη λέτε δηλαδή). The results of this work suggest that HDMI® cables with the Type C connector are a viable, cost effective and robust single cable solution for both analog signal and power/bias transmission for an MRI compatible PET insert system.
Επί της μεθοδολογίας του τεστ:
To test using HDMI® cables for application in PET, a silicon photomultiplier (SiPM) PET detector module with a single HDMI®
Type C (‘mini) receptacle was built using a SensL
SPMArray4 coupled to a dual-layer offset LYSO crystal
array 1.67 mm crystal pitch. The 16 detector outputs were
multiplexed to four signals using a simple resistor charge
division network and driven using Analog Devices AD8132
op-amps. Detector bias of 30.2V and +/- 5V power for the
op-amps was supplied through a 25’ length HDMI® cable
connected through a custom receiver card. The signals
were processed using NIM electronics and digitized with a
PC based analog to digital converter (ADC) card. The PET
detector had an average energy resolution of 14.3% full-
width at half-maximum (FWHM) and an average timing
resolution of 2.50 ns. The performance of the PET detector
BEAT THIS!!!!!!
Α και για τη μεταφορά σήματος RF από ενισχυτή (RFPA) των $100,000 βάζουν και καλώδιο Coaxial των $50 γιατί δεν έχουν βρει ακόμα τα high-end του ήχου.....
Πρέπει να μας διαφωτίσει ο Κωσταυτιάς που είναι ειδικός επί του θέματος!
εισαι εκτος θεματος και κλιματος!!!
deleted user 10898
Ανεμελε τα τεστ εχουν γινει...
Κανεις δεν ακουσε το Valhalla...
http://www.hometheaterhifi.com/volume_11_4/feature-article-blind-test-power-cords-12-2004.html
Conclusions
To many in the engineering community, blind ABX is an accepted experimental design. Using the blind ABX protocol, we failed to hear any differences between an assortment of generic power cords and Nordost Valhalla. Therefore, we cannot conclude that different power cords produce a difference using the blind ABX protocol. However, we also cannot conclude that there are no differences. We simply failed to prove that differences can be detected to a statistically significant degree using a blind ABX protocol.
vlasis
Φωτογράφος!
Εμενα παντως το Tunami μου τα σπαει.....μπασιες ξεγυρισμενες με 2 κιλα λουτσα μεσαιες.......τα σιριστικα δε μαγεια....ακουνε τα πουλια στο μπαλκονι και τραβανε κατι ξεγυρισμενες κορωνες που τυφλα να εχουν οι αδερφοι Κατσαμπα!!!!!!
Και ναι.....ακουμε διαφορες κυριοι.....ακουμε και αναρωτιομαστε γιατι....μα 1/5 μετρο καλωδιο που ουσιαστικα ειναι για να τροφοδοτειται μια μηχανη και να παιρνει μπροστα και να μας αλλαζουν τον ηχο?
Ψηνομαι να παρω κρυφα και να δοκιμασω αυτα που θα παραγγειλλει ο Μπουρας ......ειναι κρυφοκουφαλα αυτος και ας μας το παιζει παρθενα στεγνη!!!!
ηρθαν επισκεπτες . παω να τους τραταρω!! κοιταχτε μη χαλασετε το νημα μεχρι να γυρισω!! Μανο σε αφηνω υπευθηνο!!:D
vlasis
Φωτογράφος!
vlasis
Φωτογράφος!
Ενώ οι τσέχοι......................:gamer: (δεν έχει και το άλλο να βάλω....)
Κάτσε να βρω paper με HDMI για ρεύματος.....
Αν εχεις κατι καλο στο μυαλο σου...ξερεις πιεμι για να μην τα δουνε οι αλλοι.......εχω και καλτσα βαρβατη Πουρναρα να τα ντυσω ,λαστιχο 6f για το ματι και θα παρουμε σωβρακα Σωτο μου!!!!!
Alebut
