Δοκιμή του Mede8er MED500X2
Απάντηση: Δοκιμή του Mede8er MED500X2
2.1.0 firmware final για τη σειρά x2.Οσοι έχετε περάσει την τελευταία open beta δεν χρειάζεται να το περάσετε μιας και δεν αλλάζει κάτι.
Mede8er x2 series V2.1.0 Jan8 MD5: A153A777991F43D9EBFA62E4530F8715
http://www.mede8er.org/beta/Firmware_Final/MED500X2/V2.1.0_Jan08.zip
http://www.mede8er.org/beta/Firmware_Final/MED500X2/V2.1.0_Jan08.rar
Pending starting a new X2 development cycle the decision has been taken to release this version formally. Some users have made it clear they will not try Public Beta's. It would be unfair on them to extend 2.1.0. development to add new features. Those will now be part of a new revision to follow.
Οι κάτοχοι της σειράς x2 καλό θα είναι να δοκιμάσουν τη νέα beta και να μας πουν εντυπώσεις.
Θα πρέπει να ομολογήσω ότι υπάρχει εξαιρετική υποστήριξη από την εταιρία,ακόμη και για τα παλαιότερα μοντέλα!
Περισσότερα:http://www.mede8erforum.com/index.php/topic,10980.0.html
Hi all Mede8er X2 owners
Thanks to the ongoing development on the X3D Series we are now able to port some of our enhancements across to the X2 Series.
Install V2.1.1_March29_2013_BETA
Install using the Emergency Procedure
http://www.mede8er.org/beta//Firmwares_Beta/MED500X2_BETA/V2.1.1_March29_2013_BETA.zip
Changelog V2.1.1 - 29March 2013
1. New Functionality Mede8er JukeBox Plus
JukeBox Plus is new functionality within the X2 Firmware that will allow you to Aggregate your Movie JukeBoxes across different sources such as internal Hard Drive, USB Drives and Network shares both Samba and NFS. There is no limitation to the amount of Movie JukeBox's that can be added to JukeBox Plus and just remember that the source shares must have the required Mede8er folder structure with the correct images and xml files. JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files.
2. Added - Compound Filtering in Movie JukeBox
3. Added - 3 Row Movie JukeBox - Select 'Hide Movie Info' in Movie JukeBox to enable 3 Row View
4. Added - Watched/Unwatched filter for Movie JukeBox searching
5. Added - Watched Indicator icon on Thumbnail.
6. Updated DLNA DMS / DLNS DMR
7. Updated images for DLNA music playback to match the rest of the GUI.
JukeBox Plus Instructions
1. Make sure your Internal Drive and USB drives have a Drive LABEL (Drive Name)
2. Make a folder on any source and name it what you like. (Note: The source needs to be write enabled)
3. We have added a facility in the GUI to add a folder so you do not require a PC to do this - Navigate to a Drive or Network Share in the Mede8er Media Library and press the 'Edit' button on the remote and you will see a new function named 'New Folder' - Use this this make your JukeBox Plus folder
4. Navigate to the new folder you just made ie JukeBox Plus or whatever you called it and press the 'Menu' button and select 'Add to Favourites'
5. Go to Favourites and you will see the new JukeBox Plus folder you have just made - Press the Menu Button and select option 'Aggregate Jukebox'
6. The folder will now be assigned as the Aggregated JukeBox and a new thumbnail will be displayed.
7. Now you are ready to add Mede8er structure shares to the JukeBox Plus folder
8. A standard jukebox with Favourite link can be added to JukeBox Plus - Press the 'Menu' button and select option ' Add to Jukebox'
Remember to turn on 'JukeBox View' in Setup Menu.
9. You can also add to JukeBox Plus directly from from the Media Library-- In the Media Library - Navigate to the folder you want to add and focus on it then press the 'Menu' button and select option 'Add to JukeBox' and the X2 will add this folder and Auto Rescan the JukeBox Plus folder. Repeat this process to add all the different folders you require to add to the Jukebox Plus.
11. Launch the JukeBox Plus icon and all your movies across the different drives and Network shares will be displayed in one consolidated Movie JukeBox.
12. If content changes on a drive or share then you need to re 'add to JukeBox+' and the new content will be added.
13. On large collections the first scan can take some time ie Samba to HDD +- 230 movies/min and NFS to HDD +-260 movies/min. Rescanning when adding content will be a quick as only the new content needs to be added.
14. If you update Firmware then the JukeBox+ folder will have to be removed from Favourites and re-added.
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV. Do not remove power during the Firmware Update procedure .
Με την νέα έκδοση έχασα το HD audio από τα μουσικά μου αρχεία.
Το πρόβλημα είναι ότι το MF M1Dac δεν αναγνωρίζει τα αρχεία υψηλής ανάλυσης αλλά τα παίζει σαν 48khz. Η σύνδεση είναι με coax.
Να φταίει το dac? σε εσάς παζουν ΟΚ με την νέα έκδοση?
Οταν ξαναγυρισα στην έκδοση 2.1.0 του Ιαν.13 όλα ήταν καλά
Ερχεται σύντομα νέο firmware για τη σειρά Med X2 .Movie & tv scrapper,Wake on Lan,πολλές βελτιώσεις στους υπότιτλους και bug fixes.Δεν ξέρω ακόμη, αν μπορούν να βρουν κάποια λύση για το YouTube που σταμάτησε στα x2.
Θα ήθελα μια μικρή βοήθεια από τους πιο ειδικούς. Στο 400Χ2 που έχω βάζοντας του το τελευταίο firmware V3 - 29 Oct 2013, έχασε την επαφή με όλους τους δικτυακούς σκληρούς (3 WD Live) μέσω του network (δηλ. με samba). Πηγαίνοντας στο ΜENU/NETWORK βγαίνει μόνο το shortcuts (μέσα δεν εμφανίζει τίποτα) και τίποτε άλλο. Τους σκληρούς τους βλέπω κανονικά με nfs αλλά δυστυχώς μέσω nfs έχω πολλά κολλήματα στην μέση της ταινίας και πρέπει να το βγάζω από το ρεύμα για να επανέρχεται. Δοκίμασα να το επαναφέρω με τα παλαιά firmware V2.1.0 - 8Jan , αλλά πάλι δεν βλέπω τίποτα. Καμιά βοήθεια ; ή να υποθέσω ότι χαιρέτησε!!!
Κάνε επαναφορά εργοστασιακών ρυθμίσεων και δοκίμασε πάλι μήπως δει τους δίσκους με smb.
Λεωνίδα ευχαριστώ για την άμεση απάντηση. Το δοκίμασα τώρα αλλά τζίφος δεν δείχνει τίποτα μέσω samba.
Κανε restart το router και τους δικτυακούς δίσκους και ξαναδοκίμασε.
Δυστυχώς ούτε με αυτό έγινε κάτι. Τους δίσκους τους βλέπει όλους μέσω nfs, αλλά ίσως επειδή μπορεί να έχει χαλάσει (γι αυτό και δεν βλέπει smb) μετά από 5 λεπτά σε ταινία παγώνει η οθόνη και μόνο με βγάλσιμο από το ρεύμα επανέρχεται. Μόλις τώρα το άφησα να παίζει με nfs και το ξανά έπαθε. Κάτι άλλο μήπως;;;
Το firmware το πέρασες μέσα από το menu του player ή με emergency reboot?
Νομίζω δεν έχει εγκατασταθεί σωστά το firmware γι αυτό σου παρουσιάζει αυτά τα προβλήματα.
Μέσω emergency reboot 3 φορές. Και αφού πρώτα είχα κάνει φορμάτ στο στικάκι.
Τότε τι να πω,πιθανόν να υπάρχει κάποιο πρόβλημα στον player.Για νάσαι σίγουρος,σύνδεσε κάποιο usb δίσκο,βάλτου 2-3 ταινίες και δες τις αναπαράγει σωστά το med ή και έτσι έχει παγώματα?
Λεωνίδα ευχαριστώ για τις απαντήσεις σου, Τώρα κάνω άλλη μία δοκιμή σε bdmv μέσω nfs να δω αν θα ξαναπαγώσει, και αργότερα θα βάλω και το ίδιο bdmv με δίσκο μέσω usb, για να δω αν μπορώ τουλάχιστον να το έχω να δουλεύει μόνο μέσω usb. Σε ευχαριστώ και πάλι.
Για πες μου τη συνδεσμολογία σου,οι δίσκοι υποθέτω με ethernet στο router,το med συνδέεται ασύρματα ή ενσύρματα με το router?
Router 1000άρι , switch 1000άρι , Δίσκοι με ethernet στο switch , med με ethernet στο switch. Μέχρι τώρα παίζει ήδη 20 λεπτά μέσω nfs και δεν έχει κολλήσει.
Μήπως το switch δημιουργεί το πρόβλημα?Για δες κι αυτό!
Τότε πώς παίζουν μέσω nfs; Αλλά και πάλι έχω 2 med600X3 στο ίδιο δίκτυο τα οποία βλέπουν τους δίσκους κανονικότατα και μέσω smb. Δεν έχει πρόβλημα το δίκτυο, μάλλον χαιρέτησε από παράπονο, γιατί το παραμέλησα επειδή παίζω συνέχεια με τα med600Χ3 και όταν το χρειάστηκα με άφησε ...
hatzopou
