Focal Alpha
m1ts0s
News poster
Alpha studio monitors are specifically designed for music creation.
Take your compositions to a whole new level!
Thanks to Focal’s exclusive technologies, its expertise in terms of speaker drivers and to the mechanical design of Alpha studio monitors, optimum integration is guaranteed. The environments for music production are very diverse, they are not optimised acoustically, or have only been done so insufficiently, and the listening distances vary greatly. Whether for confined spaces, rooms with poor acoustic qualities or for styles of music, which require neutrality, dynamics and high SPL, Alpha studio monitors are the solution for you.
Right from the first stages of R&D, the Alpha line was designed as a solution to these problems whilst focusing on one objective in particular: improving the quality of music production by giving the user better control over the audio spectrum.
Technology at the service of music creation
This is reflected in the choice of technologies used, such as the inverted dome tweeter, that provide a very linear treble, reveal the slightest imperfections of equalisation even from a short distance away and also prevent auditory fatigue ; the Polyglass cone woofer, which gives excellent damping qualities, ensuring flawless neutrality over the entire bass/high‑midrange frequency spectrum, and a remarkable transparency to the midrange frequencies ; and the unique bass‑reflex design with large double front ports, which improves acoustical integration even in confined spaces nor installed near a front wall.
Finally each Alpha studio monitor is equipped with two class AB amplifiers. The high‑current amplifiers enable complete control of the dynamics of the audio signal. This also allows for listening at high volumes without distortion.
Available in May 2014
http://www.focal.com/en/239-alpha
PPG
Πίπιτζι
Πλάκα κάνεις ?
Ελπίζω να μην ανέβουν τρέλα στο Ελλάδα οι τιμές
Ενδιαφέρον πολυ ενδιαφέρον
Ίδιες είναι.
Ιδιαίτερο ενδιαφέρον θα παρουσιάσει μια κόντρα με τα της σειράς 700 για να διαπιστώσει κάποιος πόσο διαφορετικό μπορεί να είναι ένα ηχείο active vs συστήματος passive (με ίδια μεγάφωνα..).
Με πρόλαβες στο τσακ, το ίδιο link ήθελα να ποστάρω:hi:
Αυτό που με ανησυχεί είναι οι μικρής ισχύος ενισχυτες που έχουν.
Βλέπω πχ το άλφα 65 με συνολικά 60 watt όταν το cms 65 εχει 165. Να μην πω για το solo be που ξεφεύγει.
Δεν έχει 60 watts το 65.
Έτσι γράφουν στο site της athens pro audio.
Θα το ψάξω και αλλού.
Το 80 πάντως έχει συνολικά 140 watt. Πάντα από athens pro audio τα στοιχεία.
Λογικό.Μιλάμε για near field monitor,δηλαδή ακρόαση από το πολύ 2 μέτρα για το μεγάλο,που θέλει να πιάσει μια πιο οικονομική αγορά ή κάποιες φορητές εφαρμογές recording/mixing.
Γιατί δεν έβαλαν κάποιου είδους ''ψηφιακού'' ενισχυτή;
1)Κατά 99% τα ενισχυτικά στάδια που επέλεξαν έχουν χαμηλότερο κόστος
2)Πολύ πιθανόν να είναι της Naim,όπου δεν έχει ψηφιακούς αυτού του βαταζ
Alpha 65
This model is composed of a 6.5” (16.5cm) woofer/ midrange speaker with a Polyglass cone loaded in a large laminar port associated to a 70W amplifier and of a 1" (25mm) aluminum inverted dome tweeter (35W amplifier).
3 alpha 80 πιστεύετε θα μπορούσαν να καλύψουν ως προς εντάσεις και δυναμικά τα 3 μπροστινά κανάλια ενός HC σε 30 τμ?
Alpha 65
Thanks, έπρεπε να το διασταυρώσω και από αλλού πριν το ποστάρω.
Για φυσιολογική χρήση ναι.
Κάτσε όμως να τ ακούσουμε πρώτα.
Τα 65 για presence; :D
Κοίτα αν ήταν κάποιος άλλος,που δεν ακούει στις εντάσεις σου,μια χαρά θα ήταν τα 65άρια και height και για precence και ότι άλλο σκεφτείς.
Απλά φοβάμαι ότι τα solo και twin θα τα καταπιούν..
ειναι φανερο ποια κατηγοριας μονιτορς του ανταγωνισμου παει να χτυπησει μιας και δεν ειχε προιοντα σε αυτη την τιμη ,θεωρω οτι δεν τιθεται θεμα εσωτερικου ανταγωνισμου..
DimAster
