Σύντομα η ανακοίνωση του Samsung Galaxy S5
xfader
Και οι διαφορές σε σχέση με το S4:
A swipe-type fingerprint sensor. This feature is notably the biggest change from the S4. For consumers who had been anticipating an iris-scanner, they will be disappointed. It might also be tough to fight off the perception that Samsung is following rivals’ footsteps since Apple’s iPhone 5S came with fingerprint authentication last year.
A bigger screen but not better resolution. The organic light-emitting diode display, which is found in most Samsung smartphones has a 5.1-inch screen measured diagonally. This is a slight increase from the Galaxy S4’s 4.99-inch screen but it comes with the same resolution of 1920 x 1080 pixels, also known as full HD (high definition).
A 16-megapixel camera with ultra-high definition 4K video capability. This is a boost from its previous 13-megapixel camera which was already capable of taking high-resolution pictures. Most smartphones today support full-HD level video recording, although LG and Sony also announced new phones with 4K video capability.
A faster processor. The new smarphone sports a 2.5-gigahertz processor that is faster than its previous 1.6-GHz (Samsung chip) or 1.9 GHz (Qualcomm chip) processors in the S4. But the company declined to clarify whether it has a 64-bit processor that can better handle graphic-heavy data downloads. Apple’s surprise adoption of a 64-bit processor had stoked rumors that Samsung may opt for a similar upgrade, although expectations cooled over time.
Waterproof and Dust-resistant. Samsung claims the S5 is both water-proof and more dust-resistant. The company hasn’t changed its plastic-casing. While Samsung has what it calls the Galaxy “Active” line-up of smartphones that are supposed to be much more rugged and sturdy compared to its other models, the company has expanded the adoption of such a feature to its new flagship phone.
Heavier and thicker. This is one aspect that may appear to put Samsung backwards as it has been competing to churn out slimmer models in general. But going for bigger screens and longer battery life has its limitations. The new phone is 8.1 millimeters thick and weighs 145 grams. The S4 is 7.9 millimeters thick and weighs about 130 grams. The iPhone 5S is undoubtedly more competitive in this regard as it is 7.6 millimeters thick and weighs 112 grams.
Samsung says the smartphone will be rolled out in April and comes in four colors: white, blue, black and gold.
Πηγή κειμένου.
xfader
Εμένα με ενοχλεί που το τετραγώνισαν σε σχέση με το S4. Συνολικά είναι εξίσου άσχημο και αδιάφορο. Η μέχρι τώρα "υποδοχή" από τους πωρωμένους είναι άκρως αποθαρρυντική. Βέβαια, οι πωρωμένοι (αχώνευτοι) δεν διαμορφώνουν την αγορά...
Αυτό που με έχει εντυπωσιάσει θετικά, είναι η έντονη στροφή της Samsung προς το fitness. Το S5 έχει αυτόνομο αισθητήρα καρδιακών παλμών, είναι αδιάβροχο και αντέχει στη σκόνη/άμμο. Έχει αισθητήρες Bluetooth Smart και ANT+.
H Samsung χθες παρουσίασε το Gear Fit μπαίνοντας δυναμικά στα activity trackers. Όπως επίσης και το Gear2 Smart Watch.
Ημίθεος
Όου γιες. Έβγαλαν κινητά που τρέχουν android τροποποιημένο, ώστε το interface να μοιάζει με Windows Phone, και δεν έχουν google play, ενώ επίκειται η ολοκλήρωση εξαγοράς της Nokia από τη Microsoft. Και αντί για Google drive κλπ., εξακολουθούν να δίνουν MS Onedrive (και λοιπά).
Συμπέρασμα εύλογον: Το interface του Android έχει κερδίσει κατά κράτος αυτό των Windows phone.
gkontoletas
trouble in my brain
αν και ήμαστε εκτός θέματος...
Καμία σχέση, το UI των Windows Phone έχει κερδίσει κατά κράτος, τα Nokia X έχουν Android core, Windows Phone UI και Microsoft services, χρησιμοποιούν Android για να σπρώξουν κόσμο στα Lumia, εξάλλου βασικός στόχος είναι το φθηνό κομμάτι της αγοράς και οι φτωχές χώρες
Όποιο κινητό με Windows Phone πάρεις στα χέρια σου θα έχεις ακριβώς την ίδια εμπειρία χρήσης, θα γνωρίζεις που είναι το κάθε τι, με το Android γίνεται χαμός, το μόνο σταθερό είναι τα services της Google που είναι υποχρεωμένοι όλοι οι κατασκευαστές να τα έχουν σε συγκεκριμένα σημεία σύμφωνα με το συμβόλαιο που έχουν υπογράψει, π.χ. αυτό το Google search θα το τρως στη μάπα στην βασική οθόνη θες δεν θες.... και την εικονίτσα στο background δεν την λες και σοβαρή παραμετροποίηση, δεν πάω στο θέμα της ασφάλειας για ευνόητους λόγους.
Επιμένω στο ότι δεν είναι χρειάζεται να έχεις επεξεργαστή με 8 πυρήνες για να είναι γρήγορο το κινητό.
αυτά, τα έγραψα και ξεθύμανα....:D
xfader
H Samsung φημίζεται για το μέγεθος του αποθηκευτικού χώρου που καταλαμβάνουν το λειτουργικό και οι προεγκατεστημένες εφαρμογές της. Το S5 δεν θα μπορούσε να είναι εξαίρεση.
Με το που θα ανοίξουμε για πρώτη φορά τη νέα συσκευή θα παρατηρήσουμε ότι ο διαθέσιμος αποθηκευτικός χώρος στο μοντέλο των 16GB είναι ...7,86GB, λιγότερος από το μισό! Υπάρχει η λύση της SD card, αλλά η ταχύτητα και οι πιθανές ασυμβατότητες δεν την ευνοούν στην κόντρα με την εσωτερική μνήμη.
Μόλις κυκλοφορήσει Ελλάδα θα το μάθουμε από Άλεξ. Μπορεί να κάνει και καλά "μπα όχι δεν νομίζω" και τέτοια, αλλά πρώτος-πρώτος θα το πάρει. Μη σας πω ότι θα ξενυχτήσει σε sleeping bag στο πεζοδρόμιο για να μπει πρώτος με το άνοιγμα. :taunt:
xfader
Πάντως, από τότε που οι φανατικοί του Android έχουν αρχίσει να αποφεύγουν τη Samsung γιατί τους θυμίζει την Apple, εγώ την εκτιμώ όλο και περισσότερο. :D
gkondos
