Δοκιμάζουμε το DUNE HD Center
Απάντηση: Δοκιμάζουμε το DUNE HD Center
Νέο firmware και για το Dune HD Center:
Version "110127_2105_beta" (BETA version)
Download: http://files.dune-hd.com/firmware/hdcenter_sony/dune_firmware_hdcenter_sony_110127_2105_beta.dff (Zip)
Changes since 101201_1626:
* Various playback improvements.
- Bugfix: Specific MP3 files were playing with distortions when played
during photo viewing.
- Bugfix: Specific AVI files with AC3 audio were playing without sound,
and no file with audio could be played afterwards.
- Bugfix: Specific AVI files with H.264 video were not playing, and no
other video file could be played afterwards.
- Improvement: unsupported non-LC AAC audio tracks in MKV are not shown
in the list of audiotracks to avoid confusing the user.
* Volume control improvements.
- Added a new setting "Audio / Volume control" with the following
possible values:
- "Off". Volume control is completely disabled. The volume level is
fixed at 100% (0dB) and the player does not perform any
modifications of the digital audio signal.
- "Best quality". The default setting. The user is allowed to control
the volume in the safe range till 0dB (ensuring no audio
distortions on all audio content). When needed for specific files,
it is also possible to temporarily overcome the 0dB limit by
pressing and holding "V+" RC button for several seconds (the
increase volume level takes effect only for the current playback
session and is automatically reset to 0dB when the playback session
finishes).
- "Allow overload". The setting corresponding to the behavior taking
place in previous firmware versions. The user is allowed to set the
volume to values greater than 0dB. Depending on played content,
this may lead to severe audio distortions and thus is not
recommended.
- Added a new setting "Audio / Volume indication" with the following
possible values:
- "Percents". The default setting. The volume level is shown as
[0..100%] (corresponding to [-48..0dB] range). When the volume
level is set to 100%, the player does not perform any modifications
of the digital audio signal. Overloaded volume level is shown as
(100..150%] (corresponding to (0..+24dB] range).
- "Decibels". The setting corresponding to the behavior taking place
in previous firmware versions. The volume level is shown in
decibels.
- Volume control for background audio during photo viewing is
implemented in the same way as for regular file playback.
- NOTE: As in previous firmware versions, the player can apply volume
control only to PCM audio signal (i.e. when playing PCM audio tracks
or audio tracks which are decoded by the player itself); when using
"bitstream" audio output mode and playing audio tracks supporting
bitstream output, the volume control does not take any affect. When
A/V receiver is used, it is recommended to control the volume using
the A/V receiver.
* Other OSD improvements.
- When performing time navigation using LEFT/RIGHT/UP/DOWN/P+/P- RC
buttons (in file/DVD playback mode), the OSD does not only show the
selected playback position, but also shows the offset from the current
playback position.
- Certain notification OSD elements, such as volume control and certain
information messages can now be quickly hidden by pressing any
non-relevant RC buttons (no need to wait for autohide timeout).
* Added new UI customization possibilities (for "dune_folder.txt"
applications).
- Added a possibility to load icons shown in the right panel of the
"extended list view" asynchronously. When this feature is enabled,
navigation in such folders becomes much faster.
- Syntax:
- async_icon_loading = yes
- Added "icon_archive" feature, allowing to download a collection of
icons/images from an HTTP server once when entering certain folder,
and cache it in the player (in System Storage), that allows to
significantly improve the performance.
- Syntax:
- icon_archive.{n}.name = {name}
- icon_archive.{n}.url = {HTTP-URL-to-TGZ-archive}
- icon_path = icon_archive://{name}/{file-path-in-archive}
- When a new version of the icon archive is deployed on the HTTP
server, a modified URL should be used for it, then the player will
automatically reload the icon archive next time when the user opens
the folder.
* Setup usability improvements.
- When the user tries to exit "Video" or "Network" setup screen with
unsaved changes, a warning dialog is shown. The user is asked to
either apply the changes, discard the chances, of cancel the action.
- When selecting WiFi network connection type, the WiFI settings dialog
is shown automatically.
* Added built-in functions for management of System Storage.
- New Setup page "Miscellaneous / System Storage" provides the following
functions:
- "Initialize System Storage": allows to initialize the system
storage if it is not configured yet. Two possibilities are
provided: create the system storage on an empty storage device (USB
flash drive, SD card, an already existing HDD partition), or
partition an empty HDD into system storage and user data
partitions. Usage instructions:
- The system lists all found empty 1GB+ storages.
- Select the desired storage.
- If the selected storage's capacity is less than 100GB, the
entire storage is initialized as the system storage.
- Otherwise, if the selected storage is 100GB+ storage device, it
is partitioned into two partitions, the first partition is
initialized as the system storage, and the second partition is
kept unformatted (to format it, select it in the file browser
and press ENTER).
- "Deinitialize System Storage": allows to deinitialize the system
storage if it is already configured.
- "Clear System Storage": deletes all data stored on the system
storage. This, in particular, includes Blu-ray cache, main screen
shortcuts, content of Internet Radio and IPTV folders.
- "Clear Blu-ray Cache": clears Blu-ray cache (also known as "Blu-ray
local storage").
* Improved "Reset Settings" function.
- The confirmation dialog includes the information that player reboot
will be performed.
- Added clearing of all user-related data stored by the player in System
Storage (including main screen shortcuts and cached icon archive
data). NOTE: the content of Internet Radio and IPTV folders is not
cleared automatically (since these folders may contain files important
for the user); if needed, these folders can be cleared manually.
* Various other improvements.
- The function of quick video mode choosing now provides feedback using
the LED on the front panel of the player:
- When the function is activated: the LED blinks once.
- When the user cancels the function: the LED blinks once.
- When a new video mode is chosen: the LED blinks 2 times.
- When the user confirms the new video mode: the LED blinks 3 times.
- Some interface languages added/updated.
- Some other improvements/fixes.
* Includes also all changes from 101201_1626.
Νέο firmware και για το Center:
HDI Dune has released a new "stable" firmware update. The firmware update has
version number 110225_1222. This update provides a lot of new functions and
improvements implemented in previous beta versions to all users of Dune HD
media players.
The new stable firmware version is basically equivalent to latest beta
version 110127_2105_beta, and includes all the new functions and improvements
implemented in this beta version. Additionally, it includes also several
other fixes.
HDI Dune also expects to release soon the next beta firmware version, which
will include further new functions and improvements (such as: a new graphical
interface, built-in SHOUTCast and RadioTime Internet radio services, support
for CUE sheets, support for chapters in MKV files, an improved version of DVD
playback engine, additional settings, etc).
As always, this firmware update is provided for all generations of Dune HD
media players, including both all new models and all outdated/discontinued
models:
- Dune HD Ultra
- Dune HD Mini
- Dune BD Prime
- Dune HD Center
- Dune HD Base
- Dune HD Base 2.0
- Dune BD Prime 3.0
- Dune HD Base 3.0
- Dune HD Max
- Dune HD Smart H1
- Dune HD Smart D1
- Dune HD Smart B1
- Dune HD Duo
- Dune HD Lite 53D
The firmware update can be downloaded and installed via either the built-in
online firmware upgrade function of Dune HD media players, or using the
official Dune HD firmware web site: http://dune-hd.com/firmware/
The list of changes in the firmware version 110225_1222 since the version
110127_2105_beta:
- Bugfix: Specific M2TS files could not be played.
- Bugfix: Specific MP4 files (such as files from specific video cameras)
could be played without sound on HDMI output.
- Bugfix: DVB-T channels scan failed in specific cases in some
countries/locations.
- Bugfix: icons loading could fail in some cases for some applications
(such as KartinaTV).
- Bugfix: some Blu-ray discs could not be played in specific cases
("Securiry Violation" error was produced).
- Bugfix: Restarting optical disc playback (after stopping the playback of
the same disc) could not work in some cases.
New Firmware update:
Firmware Version "110606_1315" (the latest stable version)
Changes since 110511_2007_beta:
* Bugfix: Weather application settings did not work in some cases.
* Bugfix: Specific DVD-Video discs could not be played correctly.
* Bugfix: NTSC/PAL detection could be handled wrongly during DVD-Video
playback.
* Bugfix: Wrong audio channel could be chosen when switching channels
during MPEG2-TS/IPTV playback.
* Bugfix: Playback of video streams from network could hang in specific
rare cases.
* Some interface languages updated.
* Some other improvements/fixes.
Απ'ότι φαίνεται η Hdi μάλλον εγκατέλειψε την υποστήριξη στα παλιότερα μοντέλα (Center κλπ),αφού το νέο firmware που βγήκε σήμερα δεν τα αφορά!:203:
Σε αυτό εδώ το νήμα ξεκίνησε ουσιαστικά για μένα,η πανέμορφη περιπέτεια και ενασχόληση μου με το avsite.Με τις καλές και τις κακές μου στιγμές.
Θα ήθελα να ευχαριστήσω τον Ανδρέα και όλα τα παιδιά για την εμπιστοσύνη που μου έδειξαν!:hi:
10.000 μηνύματα και συνεχίζουμε!:)
roberto_portale
