Dune HD SOLO 4K
Νεο player επιτελους. ! Το SOLO μας προδιαθετει και για...DUO μοντελο? Ειδωμεν.;)
Dune HD SOLO 4K
is a new compact and powerful media player, affordable solution supporting 4K Ultra HD video playback and innovative HEVC (H.265) video codec. The model can play virtually any content from local and Internet sources with the best quality. Built-in DVB-T/T2 tuner provides possibility to watch digital terrestrial free-to-air TV channels.
SOLO 4K is based on the newest SMP8758 processor - the first and the only Hi-End processor by Sigma Designs with real 4K Ultra HD video support. The new ARM-based media processor is 4(!) times more powerful than processors used in previous DUNE HD media player models.
The new model can both play 4K content and upscale any content to Full HD and 4K. Professional-grade “VXP” video processor ensures the best picture quality.
The newest video encoding standard with 10 bits per color component (rather than the typically used 8 bits) is supported for HEVC video playback. It gives possibility to reproduce more than 1 billion colors, which is 64 times more than before.
The new model features a new possibility to play Blu-ray images not only with simple “BD Lite” mechanism, but also with full Blu-ray menu support, which is a unique possibility for devices of this class. Both 2D and 3D Blu-ray content is supported.
SOLO 4K has dual band Wi-Fi 802.11b/g/n/ac (2.4 GHz + 5.0 GHz) with 2T2R mode and two antennas. 1Gb Ethernet port is available for fast wired data transfer. These powerful network interfaces give possibility to playback heavy high bitrate content both via wires and by air.
The media player has two USB ports for external storage devices and a 2.5” SATA HDD rack with hot-swap support.
Solo 4K preserves all the traditional Dune HD functionality of high quality video and audio playback. Proper support of true “Hollywood” frame rate (23.976 fps) ensures perfect smooth playback without any stuttering or lost frames. The new model supports all modern Hi-End audio formats as well.
Additionally, SOLO 4K implements a unique “dual boot” mechanism, which allows to use Linux-based fully featured and further developed functionality of Dune HD media players, or to boot to Android OS for working with vast range of Android applications.
For more details and full specification please visit: Dune HD SOLO 4K page
http://dune-hd.com/eng/products/full_hd_media_players/48
  • Key Features
    • Newest media processor: The latest Sigma Designs SMP8758 chip from the famous vendor of high-end media processors, with the new Dual Core ARM CPU (4x more power than before); the first and the only chip from Sigma Designs with real 4K support
    • 4K video playback: Decode 4K video content in all popular formats (including H.265 10-bit)
    • 4K video output: Output 4K content with pixel-to-pixel precision to 4K TV
    • SD/HD to 4K conversion: Automatically increase resolution of SD/HD content to 4K
    • VXP: Professional-grade video processing engine for best possible picture quality of any content
    • HEVC: Play video encoded using the latest H.265 codec (2x picture quality increase over H.264)
    • 10-bit color encoding: Enjoy 1 billion colors (64x more than before) with the newest H.265 Hi10P video encoding standard
    • Blu-ray playback: Play Blu-ray images from any source (USB, HDD, network)
    • Blu-ray menu: Enjoy full Blu-ray menu navigation or use simple BDLite menu at your discretion
    • True 24p output: Ensure perfectly smooth playback of Hollywood movies due to full support for 24p (23.976) framerate
    • Advanced media player: Play video in MKV and other modern video file formats, including top quality 4K and HD with very high bitrates (100Mbit/s+)
    • HD audio: Output studio-quality high definition audio tracks (Dolby True HD, DTS HD MA) to your A/V receiver
    • Dolby Atmos 3D audio: Enjoy the newest 3D audio format from Dolby using Dolby Atmos pass-through capability
    • Hi-End music: Play very high-quality (up to 192 KHz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, etc)
    • Network player: Connect to local network and play content directly from PC or NAS via UPnP, SMB, or NFS
    • HDD player: Play content from any HDD (internal, USB, NAS) of any size (including newest 6TB+ HDD models)
    • HDD rack with hot-swap function: Easily and quickly insert and exchange internal 2.5’’ SATA HDDs for nearly unlimited storage capacity expansion
    • Built-in storage: 4GB flash memory for applications and system needs
    • USB ports: Conveniently connect USB HDDs, USB flash drives, USB card readers, USB hubs and other USB devices
    • 1Gbit Ethernet port: Ensure the best performance when connecting to your local network via cable
    • 802.11ac Wi-Fi with both 2.4 and 5.0 GHz support and 2T2R (two antennas): Ensure the best performance when connecting to your local network via air
    • IR extender: Easily organize hidden installation of the media player when needed via included external IR eye
    • Control4: Integrate seamlessly into Smart Home installations based on Control4 technology via ready-to-use Control4 driver
    • Z-Wave (option): Use built-in Z-Wave controller to build your Smart Home based on Z-Wave technology
    • Dual boot Linux + Android: Enjoy both Linux OS with full classic Dune HD media player functionality and newest Android OS and Android applications
ΤΕΧΝΙΚΑ ΧΑΡΑΚΤΗΡΙΣΤΙΚΑ
  • Media processor: Sigma Designs SMP8758
  • RAM: 1GB
  • Flash memory: 4GB
  • Connectors: 2x USB 2.0 (1x rear, 1x front), HDMI 1.4b, composite video and analog stereo audio (via 3.5mm A/V connector with 3xRCA adapter included), coaxial S/PDIF (on A/V connector via software switch), IR extender port with IR eye cable included, Ethernet 10/100/1000 Mbit/s, two external Wi-Fi antennas, DVB-T/T2 RF IN, 12V DC IN power connector with on/off switch
  • Internal storage: Internal HDD rack with hot swap function for SATA HDD 2.5"
  • Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources
  • Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264, H.265, H.265 Hi10p; support for very high bitrate video (up to 100 Mbit/s and higher)
  • Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, BDMV, DVD-ISO, VIDEO_TS
  • 3D video formats: MVC, Side-by-side, Top/Bottom
  • Video output modes: wide range of supported output resolutions (up to 1080p60 and 4Kp30) and framerates (including 23.976, 25, 29.97, 50, 59.94)
  • Video output framerate: automatic (according to the played content) and manual
  • Video output resolution: automatic (according to the played content) and manual
  • Audio codecs: MPEG-1/2 layer I/II/III, AAC, LPCM, WMA, WMAPro, FLAC, multichannel FLAC, Vorbis, WavPack, APE (Monkey's Audio), ALAC (Apple lossless), AC3 (Dolby Digital), DTS; support for very high quality audio (up to 192 kHz / 24-bit)
  • Audio file formats: MP3, MPA, M4A, AAC, WAV, WMA, FLAC, Ogg/Vorbis, WavPack, APE (Monkey’s Audio), ALAC (Apple lossless), AC3, DTS, DTS-WAV
  • Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (Blu-ray, TS, MKV)
  • Hardware 3D Graphics Acceleration: OpenGL support
  • Picture file formats: JPEG, PNG, BMP, GIF
  • Playlist file formats: M3U, PLS, CUE
  • Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle
  • Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention
  • Media streaming protocols: DASH, HLS, FTP, MPEG-TS over multicast-UDP, MPEG-TS over multicast-RTP, MPEG-TS over RTSP, MPEG-TS over HTTP, MP4 over HTTP, raw-MP3 over HTTP, raw-AAC over HTTP
  • Network file browsing: SMB client and browser, NFS client, UPnP/DLNA client and browser
  • Built-in NAS function: SMB server, FTP server, UPnP/DLNA media server
  • Network protocols for remote control and integration: Dune HD IP control protocol (HTTP), UPnP/DLNA media renderer
  • UPnP/DLNA: DLNA client, DLNA media server, DLNA media renderer
  • Web browser: WebKit
  • Ethernet: 10/100/1000 Mbit/s
  • Wi-Fi: Internal Wi-Fi module with 802.11b/g/n/ac support, Dual Band 2.4/5GHz, 2T2R, two antennas
  • Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3/EXT4 (read-write), NTFS (read-write)
The new model is planned to come to shelves in February of 2016 and to have MSRP of EUR 299.
παρακαλω μηπως γνωριζεται ποτε θα ερθει Ελλαδα ρωτησα την εταιρεια εισαγωγης αλλα δεν πηρα απαντηση
loggeo
τι παραπανω προσφερει το HDMI 2.0a σε σχεση με το HDMI 1.4b που θα εχει το dune;
Κοίταξε, με δεδομένο ότι την ίδια περίοδο κυκλοφορεί το πρώτο uhd blu ray player σε αντίστοιχη τιμή και τα πρώτα uhd δισκάκια περιμένεις ανάλογες δυνατότητες.
Να εξηγήσω τι εννοώ. Η αναπαραγωγή uhd υλικού με hdr (high dynamic range) απαιτεί υποχρεωτικά hdmi 2.0a με υποστήριξη hdcp 2.2.
Το media player το αγοράζουμε για να παίξουμε τα back up μας:D.
Το να λέγεται 4k και να μην παίζει uhd iso ή αρχεία ή να τα παίζει κουτσουρεμένα, δώρο άδωρο δεν είναι;
Τη στιγμή μάλιστα που ουσιαστικά βγήκαμε απ' το μεταβατικό στάδιο.
Δε λέω, σαν hd player ακούγεται πολύ καλό για να είναι αληθινό, αλλά σαν 4k...
To 1.4b υποστηριζει 4κ απλα οχι στα 60z.
Αν παιζει τα uhd .iso δεν θα με ενοχλήσει καθόλου (σε πρώτη φάση)
Ειναι στα υπόψιν ...
Μόλις γίνει κανένα σοβαρό τεστ απο τον φίλτατο :D loggeo , λέω εγω τώρα , βλέπουμε .
Να βγει και κανένα έργο , γυρω στα 20 εννοω , να έχουμε να βλέπουμε ...
loggeo
Ναι ισχύει αυτό και νομίζω κάποιες συσκευές υποστηρίζουν και hdcp 2.2. Δεν ξέρω αν ανήκει σ' αυτές.
Σίγουρα όμως δεν υποστηρίζει hdr.
Απ' την άλλη τα uhd δισκάκια θα παίζουν μόνο σε players με hdmi 2.0a αν λέει κάτι αυτό.
Εδώ δεν έχουμε μέσο hdr, στη πηγή θα τα χαλάσουμε; :p
Αν παίζει τα uhd remux, θα το πάρω απευθείας.
Σε ξένο γνωστό φόρουμ γράφουν πως έχει Full Blue ray menus και παρακάμπτει το Cinavia !
Update:
After spending 3 hours (February 2, 2016) on the phone with Mike from Duneplayer.com testing various MKV files with forced titles, we could not successfully get the flags to be honored. It was mutually decided to hold the player in Jersey until a new firmware is loaded to specifically address the MKV forced flag issue. Once that new firmware is loaded, tested and confirmed working I will get the player to confirm proper operation on my system. Below is an excerpt directly from the firmware developer in Russia that I rec’d via cc mail. I was asked to directly quote from the email that was sent to keep you guys up to date.
“ > - For MKV files, we are currently implementing support for "forced subtitles" (subtitle track marked as "forced", if any, will be automatically activated when starting MKV playback); we should be able to provide a firmware update with this in a few days.
> - When playing ISO or BDMV in full-menu mode, all "forced subtitles" logic in the disc should be preserved and work like in the regular BD player.
> - When playing ISO or BDMV in BDLite mode, there is no special support for "forced subtitles". “
End Quote.
I can say that BD menus do work, forced titles do work and Cinavia is ignored. We tested several Cinavia infected titles and all played over 30 minutes without tripping the mute message.
Auto frame rate does work. Forced Subs do work in 2D full ISOs but not in 3D. Not sure why.
I wish I had more info, but these thing take time and are difficult to address in a timely manner. I can assure you that [email protected] is listening to us, as are the firmware developers.
Πηγή: http://www.avsforum.com/forum/39-ne...e-hd-solo-4k-media-player-3.html#post41211969
Λίγο φτωχό το βλέπω σε συνδέσεις... Εγώ επειδή το Dune HD το χρησιμοποιώ 50-50 για μουσική και ταινίες θέλω οπωσδήποτε να έχει optical και coaxial για να οδηγεί το DAC μου, πέραν από τον AV ενισχυτή.
Θέλω να πιστεύω πως θα βγάλουν και DUO μοντέλο με περισσότερες συνδέσεις και Blueray disk.
MAD
Σιαρτάκιας
Νομίζω με μια ακόμα HDMI, μια ομοαξονική και μια toslink, θα ήταν υπερπλήρες!!!
για την τιμή του, θα έπρεπε να τα έχει αυτά!
thanos117
