Δοκιμή των Dune HD Max & Smart B1-D1-H1,Duo
Η σειρα smart μπορει να παιξει εξωτερικους srt σε bd-iso αρχεια απο δικτυο?
Επισης τα bd-iso αρχεια απο ενσυρματο δικτυο πως τα διαβαζει, απροβληματιστα ή με κολληματα?
Αυτό έλειπε. :)
Νεο firmware
Base 3D,TV-303D,TV-102, HD Connect,HD Max,HD Duo,HD Smart D1,HD Smart H1,HD Smart B1,HD Prime 3.0,HD Base 3.0
Changes since 150721_0135_b9:
This is a huge firmware update for old/dicontinuted Dune HD media player
models based on old MIPS Sigma Designs chips.
- This new firmware is based on the same new codebase branch (r11) which
is used in the latest Dune HD media player models based on the new ARM
Sigma Design chips.
- This new firmware includes several thousands of various changes,
fixes, improvements and new changes, which were previously implemented
during the development of the firmware for the new models.
- In particular, this new firmware includes the following new big
features, previously available only on the new Dune HD models: My
Collection, Movies catalog, Music catalog.
The new firmware introduces the concept of "Dune Plus" subscription.
- To use some new functions of the new firmware (currently: My
Collection, Movies catalog, Music catalog), a paid subscription to
"Dune Plus" premium function is required.
- Initially, a promo period takes place and "Dune Plus" premium function
is available for all users for free. After the promo period ends, a
paid subscription will be required (with some limited trial period
still available for free). The current status of "Dune Plus"
subscription can be seen in the new menu "Setup / Premium Functions".
- In this firmware version, the subscription to "Dune Plus" premium
functions is required to use the following features: My Collection,
Movies catalog, Music catalog. The set of features covered by "Dune
Plus" subscription may be extended/changed in future (it is a subject
to change without notice).
- In other words: "Dune Plus" subscription allows the owners of
old/discontinued Dune HD media player models to upgrade their players
to get access to features originally available only on the newer
player models.
The new firmware is supported for all old/discontinued Dune HD media player
models which have 512MB+ RAM.
- This includes the following models:
- Dune HD Base 3D
- Dune HD Base 3D v2
- Dune HD TV-303D
- Dune HD TV-303D v2
- Dune HD TV-102
- Dune HD TV-102 v2
- Dune HD Connect
- Dune HD Max
- Dune HD Duo
- Dune HD Smart D1
- Dune HD Smart H1
- Dune HD Smart B1
- Dune HD Prime 3.0
- Dune HD Base 3.0
- The models with 256MB RAM (Lite 53D, TV-101, TV-301, TV-102p) are not
supported by the new firmware.
The new firmware may require System Storage to get access to some new
features.
- System Storage (e.g. 2GB+ USB flash drive attached to any USB port)
may be required to install additional software components when using
players which do not have enough internal flash memoty or which do not
have enough free space in the internal flash memory.
- When System Storage is needed, the player will automatically inform
about it and will suggest installing the System Storage.
Αποφάσισαν δλδ να μας αναβαθμίσουν μονο για να κονομήσουν απο συνδρομές...
Νέο firmware.
This firmware includes fixes for various regressions found in the new r11
firmware (170519_1350_r11) in comparison with the previous b9 firmware, and
fixes for some other issues.
- Bugfix: ZOOM function did not work in some cases.
- Bugfix: My Collection, Movies, Music did not work on some player models
(tv303d2 and base3d2).
- Bugfix: DVB-C did not work on models with DVB-C tuner.
- Bugfix: HDMI audio output did not work properly in some specific cases.
- Bugfix: Verimatrix IPTV DRM did not work in some cases on models with
Verimatrix IPTV DRM support.
- Bugfix: DVB icons loading/updating did not work in some cases.
- Bugfix: High bitrate HD IPTV channels were stuttering in some cases (when
lower_cpu_load media_url parameter was used).
- Bugfix: Zapping between IPTV channels could be slightly slower than
expected in some cases (ss_for_http_ts media_url parameter did not work
properly).
- Bugfix: Stopping playback of TV channel in Kartina.TV application could
be slightly slower than expected in some cases.
- Bugfix: Screen did not darken properly when EPG OSD was shown.
- Bugfix: When playing DVB radio streams, "average bitrate" line was
wrongly shown in INFO OSD.
- Some other minor internal fixes.
Νέα αναβάθμιση: Version "170519_1353_r11" (BETA version)
Code:
This firmware includes fixes for regressions found in the new r11 firmware
versions (170519_1350_r11 and 170519_1351_r11) in comparison with the
previous b9 firmware, and fixes for some other issues.
- Improvement: when starting DVD playback, if shell_ext plugin is required
  for DVD playback but is not installed, the system automatically proposes
  to install shell_ext plugin (and to initialize system storage, if
  needed).
- Improvement: added correct support for adding plugin entry point to
  "Favorites" even if plugin has multiple entry points, and even if entry
  point is on the main screen. So it is now possible to easily add for
  example "My Collection" or "Movies" to Favorites (and enable auto start
  for them, if needed).
- Improvement: TTF font setting is now "Regular" by default instead of
  "Light", to make text more readable on Movie screen and similiar screens.
  This change takes effect after settings reset or when installing r11
  firmware over b9 firmware.
- Bugfix: HDD formatting did not work in some cases on the following
  models: Dune HD Max, Dune HD Duo, Dune HD Smart D1/H1/B1, Dune HD Prime
  3.0, Dune HD Base 3.0
- Bugfix: in some cases Recent main menu item was not included into the
- Bugfix: wrong PIDs were saved for plugins.
- Some other minor improvements/fixes.
roberto_portale
