Αυτό λέει στο παραπάνω βίντεο συμπέρασμα;ξεχασα να γραψω .πως οτι πληρωνεις παιρνεις στην jvc![]()
Δεν είμαι σίγουρος ότι κατάλαβα την ερώτηση.Τις hdmi cpu τις ελέγχουν στα καινούρια μηχανάκια ?
Οι jvc γενικά έχουν πολυ ευαίσθητες hdmi port και βγάζανε πολλά θέματα στις CPU hdmi port. Μια αναζήτησή στο Google θα δείτε παρά πολλά με handshaking issues και hdmi board problems.Δεν είμαι σίγουρος ότι κατάλαβα την ερώτηση.
Αν είχα τα φράγκα και διάβαζα αυτό, θα το σκεφτόμουν αν το χρειάζομαιαντε λιγο ακομα και παμε σε native!![]()
I have often said that there’s no such thing as a perfect display. And I want so badly to find some reason to keep saying that, but the JVC DLA-RS640 has no flaws that I can see. Yes, a native 4K chipset would be nice but honestly, I’ve seen projectors with that and they don’t look as good as this one. With e-shift now in its fifth generation, JVC has most definitely gotten it right.
As much as HDR seems to be in nearly everything now, there are still only a very few displays that can properly do it justice. And after countless demos and many long hours of testing, I can confidently say that if a TV or projector doesn’t have high native contrast, it won’t do HDR very well. OLED panels? Slam dunk. Zone-dimming LCDs? Some can do it, like the Vizio P-series flat panel I just reviewed. Edge-lit LCDs? Forget about it.
Projectors are no different in this regard. You can apply all the software algorithms you want, if a projector has 3000:1 native contrast, it won’t do a good job with HDR; not enough to really impress anyway. JVC has led the market in native contrast for over a decade. Even its earliest D-ILA designs delivered 20,000:1. The RS640 blew me away with its 44,085:1 figure, and that’s at a bright 30fL. I’ve seen many impressive DLP and LCD projectors but none can compete with that.
As great as it looks with 1080p material, the real reason to buy the RS640 is for Ultra HD Blu-ray. I have been watching the same three movies for quite a while now and never have I been so immersed in the image. There’s not much more to say other than, how can it get better? While I have no doubt that quality will continue to improve, I believe I have found a new reference display, it truly is the best projector I’ve ever reviewed.
Δέχεται 4Κ υλικό;Εχει δοκιμάσει κανείς να παίξει 4Κ υλικό στον Χ55 με το e-shift 2ης γενιάς που έχει; Τι ψάρια πιάνει; Αξίζει να βάλει κανείς 4Κ player και υλικό και να παίξει με αυτό το διαθέσιμο mode και ας μην έχει τις HDR δυνατότητες των πιο σύγχρονων υλοποιήσεων;
