ψάχνοντας για διάφορα περί κατασκευών...έπεσα σε κάνα δυο σελίδες φίλων πρώην σοβιετικών
και βρήκα κάτι καλούδια κόπιες των γνωστών μας JBL
ξερ κανένας τίποτες γι αυτά τα μαραφέτια?
τιμές όσο τα αντίστοιχα ''εμφανισιακά'' τζιμπιελ /2+
και όμοια σπεκς
http://www.md-tech.ru/catalog/cinema/sound/system/filter/clear/apply/
MDT Audio SCR-2810
Frequency range: 40-16 kHz.
Rated power of LF / HF: 800 W. / 100 watts.
LF / HF sensitivity: 102 dB. / 108 dB.
Resistance of LF / HF: 4 Ohm. / 8 Ohm.
angle of coverage: Horizontal 90 ° x Vertical 40 ° degrees, angle adjustment of the speaker
Crossover LF / HF: 800 Hz
LF / HF drivers: 2x15 "/ 1x3"
Maximum sound pressure LF / HF: 131.0 dB. / 128.0 dB
Distortion <2%
Dimensions: 760 x 400 x 1220 mm
Weight: 61.5 kg.
τιμή : 1100 ευρώ
MDT Audio SCR-2300P
Specifications:
Frequency range: 45-20 kHz.
Rated power: 300W.
Sensitivity: 99 dB.
Resistance: 8 Ohm.
Crossover LF / HF: 1500 Hz
LF / HF drivers: 1х15 "/ 1х1.75"
Maximum sound pressure: 124.0 dB.
Distortion <2%
Dimensions: 650 x 300 x 1125 mm
Weight: 32.0 kg.
τιμή : 635 ευρώ
MDT Audio SUR-120
Technical characteristics:
Frequency range: 50-18 000 Hz.
Rated power: 120W.
Sensitivity: 93 dB.
Resistance: 8 Ohm.
The maximum sound pressure is 122.8 dB.
Angle of coverage: Horizontal 100 ° x Vertical 80 ° (asymmetric horn).
Recommended amplifier power: 240 Watts per 8 ohms.
The crossover section frequency is 2.5 kHz.
Distortion <2%
Angle of the acoustic axis: 15 °.
Dimensions: 330 x 227 x 430 mm.
Weight: 7,0 kg.
τιμή : 150,00 ευρώ
MDT Audio SUR-200
Frequency range: 50-20 000 Hz.
Rated power: 200W.
Sensitivity: 96 dB.
Resistance: 8 Ohm.
The maximum sound pressure is 125.0 dB.
Recommended amplifier power: 400 Watts per 8 Ohms.
The crossover section frequency: 2.2 kHz.
Distortion <2%
Dimensions: 420 x 245 x 500 mm.
Weight: 8,0 kg.
τιμή : 205 ευρώ
MDT Audio SUR-300
Rated power: 300W.
Sensitivity: 98 dB.
Resistance: 8 Ohm.
The maximum sound pressure is 128.8 dB.
Recommended amplifier power: 600 W per 8 Ohm.
Distortion <2%
Dimensions: 450 x 273 x 540 mm.
Weight: 11.0 kg.
τιμή : 285 ευρώ
και όμοια σπεκς
MDT Audio SCR-2810
Distortion <2%
Weight: 61.5 kg.
τιμή : 1100 ευρώ
MDT Audio SCR-2300P
Specifications:
Rated power: 300W.
Sensitivity: 99 dB.
Resistance: 8 Ohm.
Distortion <2%
Weight: 32.0 kg.
τιμή : 635 ευρώ
MDT Audio SUR-120
Rated power: 120W.
Sensitivity: 93 dB.
Resistance: 8 Ohm.
Distortion <2%
Weight: 7,0 kg.
τιμή : 150,00 ευρώ
MDT Audio SUR-200
Rated power: 200W.
Sensitivity: 96 dB.
Resistance: 8 Ohm.
Distortion <2%
Weight: 8,0 kg.
τιμή : 205 ευρώ
MDT Audio SUR-300
Rated power: 300W.
Sensitivity: 98 dB.
Resistance: 8 Ohm.
Distortion <2%
Weight: 11.0 kg.
τιμή : 285 ευρώ
