MDT AUDIO από Ρωσία με αγάπη
ψάχνοντας για διάφορα περί κατασκευών...έπεσα σε κάνα δυο σελίδες φίλων πρώην σοβιετικών
και βρήκα κάτι καλούδια κόπιες των γνωστών μας JBL
ξερ κανένας τίποτες γι αυτά τα μαραφέτια?
τιμές όσο τα αντίστοιχα ''εμφανισιακά'' τζιμπιελ /2+ :party:
και όμοια σπεκς :thumbsup:
http://www.md-tech.ru/catalog/cinema/sound/system/filter/clear/apply/
MDT Audio SCR-2810
Frequency range: 40-16 kHz.
Rated power of LF / HF: 800 W. / 100 watts.
LF / HF sensitivity: 102 dB. / 108 dB.
Resistance of LF / HF: 4 Ohm. / 8 Ohm.
angle of coverage: Horizontal 90 ° x Vertical 40 ° degrees, angle adjustment of the speaker
Crossover LF / HF: 800 Hz
LF / HF drivers: 2x15 "/ 1x3"
Maximum sound pressure LF / HF: 131.0 dB. / 128.0 dB
Distortion <2%
Dimensions: 760 x 400 x 1220 mm
Weight: 61.5 kg.
τιμή : 1100 ευρώ :smg:
MDT Audio SCR-2300P
Specifications:
Frequency range: 45-20 kHz.
Rated power: 300W.
Sensitivity: 99 dB.
Resistance: 8 Ohm.
Crossover LF / HF: 1500 Hz
LF / HF drivers: 1х15 "/ 1х1.75"
Maximum sound pressure: 124.0 dB.
Distortion <2%
Dimensions: 650 x 300 x 1125 mm
Weight: 32.0 kg.
τιμή : 635 ευρώ :showingbiceps:
MDT Audio SUR-120
Technical characteristics:
Frequency range: 50-18 000 Hz.
Rated power: 120W.
Sensitivity: 93 dB.
Resistance: 8 Ohm.
The maximum sound pressure is 122.8 dB.
Angle of coverage: Horizontal 100 ° x Vertical 80 ° (asymmetric horn).
Recommended amplifier power: 240 Watts per 8 ohms.
The crossover section frequency is 2.5 kHz.
Distortion <2%
Angle of the acoustic axis: 15 °.
Dimensions: 330 x 227 x 430 mm.
Weight: 7,0 kg.
τιμή : 150,00 ευρώ :o:party:
MDT Audio SUR-200
Frequency range: 50-20 000 Hz.
Rated power: 200W.
Sensitivity: 96 dB.
Resistance: 8 Ohm.
The maximum sound pressure is 125.0 dB.
Recommended amplifier power: 400 Watts per 8 Ohms.
The crossover section frequency: 2.2 kHz.
Distortion <2%
Dimensions: 420 x 245 x 500 mm.
Weight: 8,0 kg.
τιμή : 205 ευρώ:smoke::party:
MDT Audio SUR-300
Rated power: 300W.
Sensitivity: 98 dB.
Resistance: 8 Ohm.
The maximum sound pressure is 128.8 dB.
Recommended amplifier power: 600 W per 8 Ohm.
Distortion <2%
Dimensions: 450 x 273 x 540 mm.
Weight: 11.0 kg.
τιμή : 285 ευρώ :party::party:
Για πες στον Χάρη, μπας και μας κάνουν καλύτερη τιμή...:D
:roflmao::roflmao::roflmao:
μπα μωρέ...Δύση πλέον εκεί...πάνε τα κονέ που ήξερες...:p:roflmao:
  • Like
Reactions: PPG
τι ντραιβερς φορανε αραγε
έλα μου ντέ...πως θα μάθουμε;
και εγώ αυτό ρωτούσα τη ρωσιδουλα ψες το βράδυ...αλλά δεν καταλάβαινε το πτανακι...:p:roflmao::roflmao:
MDT Audio SUR-120
Rated power: 120W.
Sensitivity: 93 dB.
Resistance: 8 Ohm.
Distortion <2%
Weight: 7,0 kg.
αυτα ρε συ ειναι σαν τα 8320 στα μισα λ7
Έτσι ακριβώς Κωστή + το έχουν και σε 12άρι:party:
αυτά τους ρώτησα...τι παίζει..τι μονάδες χρησιμοποιούν κλπ...να μας κάνουν μία παρουσίαση...
όπως και αν έχουν μετρήσεις από setup που τυχόν έχουν στήσει και αν στέλνουν Ελλάδα
από σπεκς σκίζουν πάντως:party:
Ti τους ρώτησες; αν θα πάρει ο Ερντογάν τα SU-57;:p
κουτσομπόλη...
για το νέο...γκομενάκι του Πούτιν ρώτησα:p:roflmao::roflmao:
Σε ποια γλώσσα; :p
Μου αρέσει στο σάιτ τους, που μόλις πατήσεις "English" εξαφανίζεται ο κατάλογος προϊόντων. :roflmao::roflmao:
Ναι άσε...και εγώ κουφάθηκα χθες με αυτό!:roflmao::lol:
τελικά δούλεψα...δεξί κλικ- μετάφραση σελίδας..και όλα οκ...:D
ε ας κάνουν και αυτοί το ίδιο από Αγγλικά:roflmao:
Περιμένοντας τον Βλαδίμηρο..:)
Hello!
I am currently on a business trip. I'll be back at the office on Monday. And I will try to answer all your questions and send a price list. We also produce 3D systems(MDT Cinema), 3D glasses and cable (MD Cable).
Best regards,
Vladimir Makarov
Commercial director, Co-owner
+7(499)132-6022, 132-6288
www.md-tech.u
TERMATOGAZI
Bass!
πολυ πιθανο να ειναι κινεζικες αντιγραφες των jbl.
τωρα τι μοναδες φορανε οτι και αν σου πουν μην τους πιστεψεις.
αν ειναι να παρεις αυτα καλυτερα ψαξε το εργοστασιο στην κινα και παρτα απο εκει πολυ φθηνοτερα.
Μιχάλη αν είχα σκοπό να πάρω τέτοια ζωάκια...θα χτυπούσα τα 3677 του φίλου που τα δίνει εδώ:)
δεν υπήρχε περίπτωση να ρισκάρω ούτε στο 1000000 κάτι χωρίς δοκιμή,ριβιού κλπ κλπ
ίσως και λέω ίσως λόγω κόστους... να δοκίμαζα ένα ζευγάρι στυλ 8320 που έχουν...;)
και πάλι θα τα έστελνα κάτω σε κανέναν rose ή Στάθη για δοκιμαστικό με τα ορίτζιναλ αλλά και για να τους κάνουν το μέρος πτάνα οι γνωστοί άγνωστοι:D
για να ξέρουμε τι παίρνουμε στο κόστος αυτό..
εξάλλου να μη μας διαφεύγει ότι η τιμή σε αυτή την κατηγορία ''κλώνων '' είναι εφάμιλλη με τα jbl που πουλάνε στο Αμέρικα
ένα 4722 στις ΗΠΑ έχει κανένα χιλιάρικο περίπου ενώ εδώ 2200+
οπότε θεώρησα ότι μπορεί να είναι και κάτι αξιόλογο με δεδομένο την κανονική τιμή των jbl
ΑΝ και εφόσον φυσικά έχουν κάποιες άκρες για σωστό σχεδιασμό..;)
Best regards,
Vladimir Makarov
δεν διαβάζεται εκεί που είναι ωρέ...γυαλίζει ο πίνακας:p
λίγο πιο κάτω βάλτο και αριστερά...έχει χώρο να βγει σε ταττού :roflmao::roflmao:
Πάρ' τα και στείλ' τα. :wink: Ή, ακόμα καλύτερα, φέρ' τα. Έχουμε να γελάσουμε...:laugh:
Nikos67
