Δερμάτινο πικάπ
Mr Spock
demokratischer - sektor
VPI Designer Prime: Ντυμένο Prime
Η VPI συνεργάστηκε με την Master Dynamic για να ντύσει το πικάπ της Prime και το ονόμασε Designer Prime.
Τo πικάπ θα κυκλοφορήσει σε περιορισμένο αριθμό σε καφέ και μαύρο Ιταλικό δέρμα.
Θα έχει βραχίονα JMW 10 επίσης με επένδυση δέρματος, το επάνω μέρος του κινητήρα θα έχει δέρμα, ενώ τα άλλα υλικά θα είναι special φινιρισμένα.
http://www.hxoseikona.gr/nea/6610-vpi-designer-prime.html
VPI leather wrapped turntable by Master Dynamic
Designer Prime
https://www.vpiindustries.com/prime-bespoke?lightbox=dataItem-jgse7br4
2 years ago, we started creating leather wrapped turntables for Master Dynamic. This opened the door for possibilities for craftsmanship leather working. While we don’t want to fully embrace this as a company and want to stick to the core and CONSISTENT product line, we had a customer request a leather Prime. Last year we made 1 sample and received very positive feedback. We commissioned our leather worker to make 15 more of these products. 5 in Brown and 10 in black leather. The “Designer Prime” is a limited run and are handcrafted by a Master Leather worker. This is not a standard table and there is no say that we will ever make this table again.
Table Specs:
  • 2 Prime chassis bonded together
  • Fully Italian leather wrapped chassis hand stitched together
  • Special finished center weight, motor, and armbase
  • Metal JMW 10 arm special finished and leather wrapped
  • The 300 RPM, 24 pole, AC synchronous motor is capable of high torque and quiet operation. The motor is installed in a separate aluminum and steel machined assembly with leather top
  • The Inverted bearing features a hardened stainless steel shaft, 60 Rockwell chrome hardened ball, spinning in a phosphor bronze bushing and sits on a PEEK thrust disc. The belt side load is placed at the center of the spinning bearing for zero teeter-totter effects
  • The 20 pound 6061 aluminum platter has an accuracy of +/- .001” in a 39” circumference
  • The motor pulley has an accuracy of +/- .0005” when leaving factory
Specs
  • Wow and flutter: .03%
  • Speed Accuracy: .04%
  • Rumble: 82db down
  • Overall Dimensions 21 ⅜" x 15 ¾"
  • Footprint is 19 ½" x 13 ¾"
  • 60 lbs weight
- δεν αποκλείεται να έχει ευνοϊκές για τον ήχο ιδιότητες το δέρμα
...........ενα παλικαρι στην κρητη...εχει ντυσει ολα του τα καλωδια με κατσικοδερμα.....ντοπιο
και πιστευει οτι ακουει καλυτερα..........
(σε εδωκα στεγνα κουζελε)
Γιατί όχι;;; εμείς στη Κρήτη την "ακούμε" γενικά καλύτερα από τους υπόλοιπους Έλληνες:smoke::smoke::smoke::D:D:D
gid
H έμφαση στο "ντόπιο", φυσικά.
Επίσης είμαι βέβαιος πως η βελτίωση αυτή εμφανίζεται μόνο εφόσον το σύστημα λειτουργεί στην Κρήτη.
Mr Spock
- με εξαίρεση : Καλαμάτα , Πύργος , Αγρίνιο , Σέρρες , κεντρική & δυτική Αθήνα , Bangkok ( εκκρεμεί , δεν την έχουμε πάρει ακόμα ) , κλπ . . . :focus:
ika
News
Ξέρουμε από τι ζώο είναι το δέρμα και από ποιό μέρος?
Για το δέρμα του βραχίονα κάτι περνάει από το μυαλό μου.
Έλαααα!! βραχίονας μεταβλητού μήκους;;;;; επενδυμένος με ζωντανό τραγόδερμα.
Mr Spock
- συνθετικό για να μην μας την πέσουν οι φιλοζωικές εταιρείες . . . by the way . . .
Παγκόσμια Ημέρα των Ζώων η 4η Οκτωβρίου - Philenews
[DOUBLEPOST=1538642981][/DOUBLEPOST]
...θα γινω βετζετεριαν... :/
- είσαι να ντύσουμε τα pro-ject με αμπελόφυλλα ; . . . vinyl - dolmah
ειναι πεοδερμα
το παιρνεις μπουστακι .....το τριβεις και γινεται παλτο.............
αν παιζει δισκους απλα φορμαρεται στο σειπ του πηγαδιου...............
Ν
Νίκος Τεγόπουλος
Designer Prime
Table Specs:
Specs
  • Rumble: 82db down
  • 60 lbs weight
Κακόγουστο. Εντελώς!
Ν
Νίκος Τεγόπουλος
Παρ'το σε μαυρο τότε...:D
Ακόμα χειρότερα! Δηλαδή: Χαλια μαύρα!! Μα πως τους ηρθε; Τίνος ιδέα ήταν; Ευτυχώς που θα βγει σε περιορισμένο αριθμό...
Mr Spock
- ούτε και εγώ το βρίσκω ωραίο , πάντως το σχόλιο περί κακόγουστου καλό θα ήταν να μην έχει μπεί μέσα στην παρουσίασή μου διότι τώρα φαίνεται πως το έγραψα εγώ
DAMBO
