"Πλωτός" χώρος ακρόασης
dapost
Rehdeko & Harbeth lover
Σε περίπτωση που κάποιος ενδιαφέρεται να φτιάξει κάτι τέτοιο, μερικές χρήσιμες συμβουλές από έναν ειδικό:
"There aren't many ways you can properly "float" a Studio's main shell. You see a lot of things on the Internuts, often some very bizarre techniques that don't make any sense. Decoupling is a very simple task though, as long as you understand how to do it, what products to use (there are very few candidates) and how to calculate it all properly and precisely.
Some of the oddest things I see are:
1. floating the floor only, not the walls (the floor is poured inside the shell walls). That makes absolutely no sense as it bypasses most of the shell - congratulations you wasted a ton of money.
2. Floors and walls floating separately: it brings nothing to the table but complications, a high risk of structural instability (especially in seismic areas) uneven loading (you can't control the loading quite as well and as you build the inner shell, both will get connected anyway) which adds long term structural issues as compression of the decoupling interface will not be the same between the walls and the floor once under final load.
3. Lightweight floors (usually wooden). This can never work due to the physics involved in such systems. Don't be fooled by the acoustics scammers and self appointed designers selling you such design. In doubt, ask them for the detailed calculations sheet and be surprised if there are any. If you do the maths and work the structural aspects of it all, it's plain clear it can't work.
Rockwool, foam, rubber etc aren't designed for decoupling. Don't use them, it will fail.
So how do you do it efficiently and safely?
You create a floating structural concrete platform on which the specific room (control room, live room or booth) will rest as a whole. You use purpose designed products like Sylomer (as on photos) or springs, etc. and carefully estimate the load per area and vary the products surface so it is evenly loaded when the room is finished, with a natural frequency target under 8Hz, if possible under 5Hz. Estimating torsion (structural modes) in the concrete floor is very important."
Northward Acoustics
Northward Acoustics
Κοινώς σκηνικά του τύπου έκανα πλωτό πάτωμα κλπ τα ξεχνάμε
Northward Acoustics
Παλι λιγο(τερο) ασχετο (αλλα οχι και τοσο καθως εχει και τα αποτελεσματα δημοσιευμενα του freq. response του studio του αλλα και ειδικη αναφορα στο δαπεδο του, που αναφερει για το καλυτερο που μπορει να επιτευχθει) αλλα πολυ ενδιαφερον. . Πολυ σπανιο οπως αναφερεται να δεις δημοσιευμενα freq response απο studio. Γιατι αραγε αναρωτιεται ο ακουστολογος ,,, Επιαης και πολοι αλλοι προβληματισμοι στο αρθρο αξιο να διαβαστουν.
Τα πολλά τα "απόλυτα", ολίγον τι με συγχίζουν..
Ή πλωτό δάπεδο σε ελατήρια ή τίποτα, σα να λες ή διαχυτές ευρέως φάσματος στα 3,5μ απόσταση από τα ηχεία ή τίποτα.
Δεν είναι έτσι. Υπάρχουν και ενδιάμεσες λύσεις, δε χρειάζεται να είναι "απόλυτη" η κάθε λύση, δεν είναι τα στούντιο ερευνητικά κέντρα πόσο μάλλον οι οικιακοί χώροι ακρόασης, δε χρειάζεται να εξαφανίσεις το κάθε mode, μπορείς να μετριάσεις την παρουσία του, ώστε να πάψει να αποτελεί πρόβλημα.
Από την μια μεριά έχουμε τους γραφικούς covidiots του ήχου, με πλήρη άρνηση όλων των δεδομένων (όχι πολυκάναλο, όχι πολλαπλά σαμπ, όχι διάχυση, όχι ρουμ εκουαλαιζέισιον, όχι μικρόφωνο, ναι στις λάμπες ναι στα χαρμπεθ ναι στα ρεντεκο ζήτω τα μπιενταμπλεγιου και σατοπικαπδενεχει ιδίως με φανταζέ καβλώδια κι έλα να σε πω για το πρατ και τις χροιές, είμαι μουσικόφιλος εγώ ξέρω να ακούω) και από την άλλη μη τυχόν κάνεις απλό πλωτό δάπεδο θα αφήσει +-3 ντεσιμπέλ στο μόουντ του ταβανιού.
Αφήστε με ν'αγιάσω...
Να μην ξεχνάμε ότι υπάρχει και φθηνή δοκιμασμένη λύση για τον ακροατή. Ούτε modes ούτε ανεπιθύμητες πρώιμες ανακλάσεις :biggrin:
Το έχω προσωπικά δοκιμάσει...., βελτιώνει τον ηχο :biggrin::biggrin:
TMantΖ@13
