ISOL-8 SubStation H.C. Mains Conditioner
Audio Harmony
Τhe SubStation HC (High current) complements the LC, providing 16 Amps continuously across its two outlets for high peak current loads such as amplification.
A high capacity DC blocking Axis circuit is complemented by a massively constructed Transmodal filter.
Using proprietary custom wound components, kilos of OFC copper foil and premium capacitors to keep series resistance low, the SubStation HC effortlessly tackles the very thorny problem of effectively cleaning a high current power supply without compromising dynamic performance.
Perfect match to Ultra Reference Dual-Mono or MonoBlock amps!
Τιμη προσφορας (silver, new): 2.550 € απο 3.650 €
"Listening without the Isol-8s, things definitely become slightly lethargic and less well-separated, with noticeably poorer delineation of detail and dynamics. As a result, we felt inclined to turn up the volume a notch to try and make the music project more. In simple terms, the sound suddenly seems less special. With the Isol-8 SubStations back in circuit, things perked up again. Individual voices and instruments sound cleaner, with greater individuality – both tonally and dynamically. Bass seems firmer and cleaner, with less smearing and overhang, while the treble is airier."
HiFi Choice Recommended April 2011
"That enhanced detail, clarity, better separation and space round the instruments and that almost spooky quiet they bring to backgrounds, is like doubling the cost of every component in the system. I understand that not all systems benefit from such enhancements (the Naim UnitiQute, for example, lost a lot of its character in the process), but those that do benefit, really shine with the SubStations in place. As it’s also a power conditioning system that can grow with your system, it’s an obvious choice."
Hi-Fi+ June 2011
NikolasLegend7
