F1 season 2007
Περισσότερες πληροφορίες για την πίστα και την περιοχή:
Circuit de Catalunya
Real Automobil Club de Catalunya
AP de Correus 27
08160 Montmelo
Barcelona, Spain
Tel:(+34) 935719700
Fax:(+34) 935722772
Web: http://www.circuitcat.com
The Formula One teams are no strangers to Barcelona's Circuit de Catalunya; not only have they raced there every year since 1991, they also conduct extensive testing at the venue.
Familiarity does not, however, lessen the challenge for car or driver. Barcelona's mix of high and low-speed corners, plus its abrasive and rather bumpy track surface, makes for a physically and mechanically taxing race. Tyre wear is particularly high and the varying winds that cut across the circuit mean an optimum set-up can be hard to find.
For spectators Elf corner is among the best places to watch, as it is one of the track's few overtaking opportunities. For the drivers it is the final two turns, known collectively as New Holland, which provide one of the biggest challenges of the season. A fast exit is essential in order to maximise speed down the start-finish straight into Elf.
2003 marked the 13th time Barcelona has hosted the Spanish Grand Prix. Michael Schumacher has been the most successful driver at the circuit, with a total of five victories, while Jacques Villeneuve is the only other current driver to have won there, back in 1997.
The Circuit de Catalunya is located only 30km from Barcelona. It is easily accessible on major routes, either the N152 or the A7 motorway (exit 13) towards Gerona.
Alternatively, it is served by rail from Sants station (Line 2) to Montmelo Station with journey time lasting about 40 minutes, or from Gerona in around one hour. The circuit is a short walk from the station.
If you're flying, then the nearest international airport is El Prat de Llobragat in Barcelona, which is 47km from the circuit. There are regular connections to Barcelona from the airport via bus and train.
GTX
Και κάτι σημαντικό σήμερα ο Alpha μας κάνει την τιμή και δείχνει live το quali, οπότε για πρώτη φορά φέτος θα μπορούμε να βλέπουμε και live timing.
Κάποιοι βέβαια πάλι δε θα βλέπουν, όπως συνήθως....ακούς Πουρναράκη για σένα μιλάω :happy_5: :happy_5: :happy_5: :happy_5:
Η πίστα θα βολέψει περισσότερο τις McLaren.
Πιθανότατα αύριο να έχουμε νίκη του Hamilton.
Oι Ferrari δεν έχουν πάει ιδιαίτερα καλά.
Οπότε θα είμαι ευχαριστημένος για μια θέση στο Podium
Να το σηκώσει ο Massa φέτος κι όχι ο αχώνευτος Φινλανδός και τι στον κόσμο!:crazy_3:
Δείτε και τα χρονομετρημένα τώρα ;-)
  • 124,7 KB Προβολές: 13
GTX
Απίστευτα πράγματα στο GP σήμερα!!! wall_1wall_1wall_1
Den exei bouloni to bmw kardia mou!!!!! :happy_5::happy_5::happy_5:
Δεν πρέπει να ήταν το μπουλόνι αυτό που έφυγε ...
Πιθανότατα ήταν κάποιο κέλυφος γιατί αν δεις καλά ήταν στρογγυλό και διαμπερές ... ίσως ήταν και από το κομπρεσέρ... και έκανε ένα γύρο με την ρόδα μισοβιδωμένη... Δεν νομίζω να έβγαλε όλο το γύρο με την ρόδα αβίδωτη!
Πάντως πολύ show σήμερα ... όλα στραβά στους μηχανικούς!
Πριν σχολιάσω τον ΑΠΑΡΑΔΕΚΤΟ (και λίγα λέω :mad_3: :mad_3: :mad_3: :mad_3: ) ποντίκαρο της Ferrari (ναι...για τον ψάρακα τον Kimi μιλάω) ας δούμε πλέον τα χθεσινά αποτελέσματα των επίσημων δοκιμών για την Pole Position
Εδώ είναι τα αποτελέσματα του αγώνα......
Τα γνωστά
Ο Massa νικητής (μας έκλεισε το στόμα με άνεση :cool_4: ), ο Hamilton 2ος και ο Alonso 3ος.
O Kimi τερμάτισε στην πισίνα του ξενοδοχείου του. Φόρεσε την ρόμπα του, ξεκούμπωτη και κάθησε να πιει το τσαγάκι του. Ρε ουστ......:mad_3: :mad_3: :mad_3:
Οι ταχύτεροι γύροι του αγώνα, επιβεβαιώνουν την δυναμική τόσο του μονοθεσίου της Ferrari όσο και του....τραβήγματος του αυτιού στο Massa (από τον Todt και όλο τον Ιταλικό τύπο) :cool_4: :cool_4: :cool_4:
Τα σχόλιά μου για τον αγώνα αργότερα απόψε......
Ένα είναι σίγουρο
Τα έχω πάρει στο κρανίο με την απαράδεκτη συμπεριφορά του Raikkonen τόσο εντός όσο και εκτός πίστας.......:mad_3: :mad_3: :mad_3: :mad_3: :mad_3: :mad_3: :mad_3:
Ένας φίλος ήρθε απόψε από τα παλιά!!!!
Ό,τι και να πω είναι μάλλον λίγο.....
Μιχαλάκη...
Μας λείπεις
  • rose.athens
stavros.vatistas
