Kharma Matrix MP 150 Monoblocks
Κώστας Φ.
Monoblock τελικοί απο την Kharma, Class-D (δε φταίω εγώ, το 6moons :happy_5: ), με 100Watt στα 8Ω και 150Watt στα 4Ω. Έχουν ως βάση τα UcD modules (βλ. Hypex) και κοστίζουν $6800 το ζευγάρι.
Επίσης η Kharma διαθέτει και μεγαλύτερο μοντέλο, τον MP 350.
Αντιγράφω απο το review του 6moons:
"When Charles van Oosterum contemplated the various assets and liabilities of Class D topologies, he went to the well and hired Bruno Putzeys. Belgium-born Putzeys worked at Philips' Applied Technology laboratory on digital and analog-controlled Class D amplifiers. Here he designed the UcD circuit that he now exploits in his own company Hypex. The collaboration between Charles and Bruno led to the birth of Kharma's Matrix MP150 Class D monoblocks.
One of the design goals was to develop an amplifier that would offer the same characteristics as a SET tube amplifier but with the added distinction of being a Class D amp. Bruno Putzeys claims to be able to bend the sound of any Class of amplifier, be it A, A/B or D, to his will. Thus the MP150 was made to sound like a tube amp in the mid and high frequencies. Where many early Class D designs were found to sound very different from preexisting amplifiers, this was basically due to the new ways in which they distorted. Later designs fixed the problem and left early admirers and adopters in doubt.
Kharma's website has a couple of graphs for their monos, showing a very flat frequency response, essentially a straight line from 20Hz to just before 20KHz where is gently slopes down. With a 100-watt power output at 8 ohms and 150 at 4, these amplifiers have plenty of power to drive almost any decent loudspeaker. The documentation further states that the design only takes feedback from the speaker terminals for its pulse control and not from the switching outputs. This creates low output impedance to give the MP150 a damping factor of more than 400 up to 2000Hz, maintaining better than 100 at 20kHz. Combined with a rated frequency response of DC to 50kHz (0,-3dB) and a THD and IMD of less than 0.02% make for some rather impressive figures. Jitter problems in Class D topologies are here controlled by eliminating a separate oscillator altogether and using self oscillation based on the phase shift of the feedback network.
Conclusion
In conclusion, the cooperation between Bruno Putzeys' technical excellence and Charles van Oosterum's pushing the audio boundaries birthed a very competitive amplifier. Without any effort, the MP150 will challenge and defeat many far more expensive SET and solid-state power amplifiers. On top of that, the MP150 makes the choice between tube and a transistor amplifier easy. It's neither, really, since Class D in this special Kharma rendition combines the very best features of both into a couple of very musical bricks indeed."
Full Review
Κώστας Φ.
Απάντηση: Kharma Matrix MP 150 Monoblocks
Ορίστε και οι MP 350, με 300 watt στα 8Ω.
Δεν ξέρω πως παίζουν αλλά από εμφάνιση πάνε καλά!
τιμη για το ηχειακι -βλεπω μπορνες cardas
H εμφανιση δικαιολογει και την τιμη χαχαχαχα
Το περιεχόμενο δεν κοστίζει πάνω από 500-600 άντε 700 € ....το ζευγάρι!
Μάλλον τα υπόλοιπα οφείλονται σε κάποιο...εξωγήινο αλουμίνιο από το οποίο είναι κατασκευασμένα τα κουτιά. :happy_8: :crazy_1:
ρωτησουμε αν μας πουλανε τα κουτια μονα τους?? και να βαλουμε κανενα μουρανο μεσα
Gebreselassie
Μαύρος!
Δεν είναι τόσο απλά τα πράγματα ρε Νικ, μην λέμε πάλι τα ίδια...
Μπορεί τα ...όσα χιλιάρικα να μην φαίνονται ένα τίμιο τίμημα με βάση τα υλικά κατασκευής αλλά από την άλλη πως μπορεί να το κρίνει αυτό κάποιος?
Μήπως το κοστολόγιο μιας Murcielago είναι 350.000€?...
Ημίθεος
Μπορώ να σου πω, αλλά βαριέμαι. Εκτός αυτού, κρατάω και μια πισινή, για να χρεώνω όσο θέλω αυτά που θα κυκλοφορήσω όταν γίνω high end κατασκευαστής.
(Δε με λες; Ο παραλληλισμός αυτουνού εδωνά του ενισχυτόκουτου με τη Murciélago σου ξέφυγε, ε);
Κώστας Φ.
Yποτίθεται πάντως ότι δεν είναι τα ίδια modules που πουλάει η Hypex στο site της - σε πολύ ελκυστικές τιμές είναι η αλήθεια.
Πήγαν και βρήκαν τον Bruno Putzeys (δε θέλω σχόλια για το όνομα), που είναι ο σχεδιαστής των UcD modules, και συνεργάστηκαν για να φέρει τα modules του στα μέτρα της Kharma.
Τώρα, "τι" και "πως" και αν ισχύουν όλα αυτά, θα σας γελάσω.
Η αλήθεια είναι πως το εσωτερικό τους δε μου θυμίζει τα diy modules της hypex και μπορώ να διακρίνω στο εσωτερικό τη μεταλλική πλάκα με το λογότυπο της Kharma που κρύβει κάποια πράγματα. Τώρα, τι κρύβει και γιατί, πάλι θα σας γελάσω.
Βy the way, UcD modules χρησιμοποιεί και η Meridian.
Επίσης, για όσους έχουν DIY (ή μάλλον "DIY" γιατί έρχονται σχεδόν έτοιμα) ανησυχίες, τα module αυτά είναι καλή περίπτωση: http://www.hypex.nl/
Μιας και το πήγες στα αυτοκίνητα....να το προσγειώσω λίγο.
Ή να το ισοπεδώσω μήπως; :happy_8:
Όταν ένα αυτοκίνητο φορά τον κινητήρα του Smart, τα ζαντολάστιχα του Smart, τα αμορτισέρ του Smart,
τα φρένα του Smart, το σασί του Smart, το σαλόνι του Smart, τα ηλεκτρικά του Smart, τα υδραυλικά του Smart,
τα κοστούμια του Smart...και έχει το σήμα της Ferrari...εεε το κέρατό μου πρέπει να πωλείται ως ένα Smart που κάποιος του ξήλωσε το σηματάκι και του έβαλε ένα της Ferrari. :happy_8: :happy_5:
Gebreselassie
Μαύρος!
Αυτό που περιγράφεις είναι ο κανόνας στην αυτοκινητοβιομηχανία.
Άστο...
Εγώ είμαι ο πρώτος κατά του "δαγκώματος" αλλά μην μας πιάνει μόνον με τα ηχητικά η καταναλωτική μας συνείδηση, λες και δεν υπάρχουν αλλού υπερβολές. Κάθε μέρα πληρώνεις ένα κάρο μπούρδες που δεν αξίζουν τα χρήματά τους. Με την ίδια λογική (της σύγκρισης με το κόστος κατασκευής), κανένα ηχείο και κανένα σύστημα δεν είναι τίμιο. Τι να κάνουμε, να πάμε να πάρουμε όλοι ένα ipod (που επίσης υπερτιμολογείται...)?
p.s. Το ίδιο το smart είναι ένα υπερτιμημένο αυτοκίνητο. Είναι το hi end των mini. :happy_9:
Ναι, αλλά τα σήματα της Φερράρι είναι συλλεκτικά (που θα 'λεγε και ένας γερο-παράφρων)!
Κώστας Φ.
Το ipod κι αν υπερτιμολογείται....Άσε, τόσο ακριβά δε χρεώνουν το hype ούτε οι High-End κατασκευαστές.
Δεν είναι ο κανόνας, είναι η εξαίρεση:
http://www.mobilemag.com/content/100/354/C11441
"...[FONT=arial,verdana,helvetica]Porsche earns an average profit of $28,000 per vehicle sold. ... That $28,000 figure "dwarfs the per-car earnings of virtually any other automaker." By comparison, BMW makes about $3,200 per car, whereas Audi gets about $1,580. When you start looking at higher volume vehicles, the figure drops even further, with Chrysler only making $900 and VW netting $400."[/FONT]
Κώστας Φ.
Eγώ είμαι της άποψης πως, αν όντως είναι η καλύτερη υλοποίηση των UcD μέχρι τώρα και μπορεί να σταθεί δίπλα σε άλλες συσκευές αυτής της κατηγορίας τιμής, ας τους δίνουν 6 χιλιάρικα το ζευγάρι.
Αν όμως πρόκειται για τα ίδια module με αυτά των 200 ευρώ που δίνει η hypex στο site της, τότε μιλάμε για απατεώνες. Δε φαίνεται να ισχύει κάτι τέτοιο απο μία πρώτη ματιά, αλλά δε θα είναι και η πρώτη φορά που το βλέπουμε.
Δε χρειάζεται να θυμήσω τους Murano και τους Jeff Rowland 501, φαντάζομαι.
Το ίδιο καρμπόν εσωτερικό, έτοιμο απο την ICEpower, και ο πρώτος ζητάει 1200 ευρώ το ζεύγος και ο δεύτερος 6000 ευρώ.
Αυτά τα 4800 ευρώ διαφορά πώς δικαιολογούνται? 4800 ευρώ είναι 1,5 εκατομμύριο δραχμές και βάλε, ρε φίλε. Και μη μου πείτε R&D, είπαμε, τα παίρνουν έτοιμα όλα απο την ICE και οι δύο.
Γι'αυτό λέμε ότι καλό είναι να το ψάχνουμε λίγο παραπάνω... Εγώ το θεωρώ και υποχρέωση του σωστού χομπίστα σε κάποιο βαθμό.
Και σίγουρα δεν δείχνει τσιγκουνιά όπως θέλουν να το παρουσιάσουν ορισμένοι..... Εκτός αν τσιγκούνης είναι αυτός που γουστάρει να ξέρει τι αγοράζει και δεν του αρέσει να τον πιάνουν κορόιδο.
Και να σας πω το άλλο το τραγικό που είδα σε forum του εξωτερικού, όταν έψαχνα για τους Murano?
Ρωτάει κάποιος για τους Jeff Rowland (των $6k+) γιατί του γυαλίσανε και ήθελε να αλλάξει τελικούς. Του λένε διάφορα καλά λόγια απο κάτω για την τεχνολογία της ΙCE και τα γνωστά.
Μέχρι εδώ καλά.
Πετάγεται τύπος όμως και λέει "παλικάρια, υπάρχει ο Murano που είναι ο ίδιος ακριβώς και κοστίζει λίγο πάνω απο $1000 το ζευγάρι!" και βάζει τα σχετικά link όπου φαίνεται ότι μιλάμε για τον ίδιο ενισχυτή. Γράφει και απο κάτω ένας άλλος ότι, ναι, όντως άκουσε Murano και Jeff Rowland δίπλα-δίπλα, δεν άκουσε καμία διαφορά, και έδωσε αμέσως παραγγελία για τους πρώτους.
Η λογική λέει πως το thread θα εκτροχιαστεί και θα πάει η κουβέντα στους Murano. Aμ δε!
Συνεχίζουν ακάθεκτοι οι σύντροφοι hi-endάδες απο κάτω και λένε για τους Jeff Rowland!! "Ναι, να τους πάρεις, καλή περίπτωση"... μπλα...μπλα...
Τι να πω..Ίσως δεν τους έκανε ding το όνομα Murano (δεν ήταν στη λίστα με τις "ψαγμένες" εταιρείες που είχαν στο μυαλό τους?) και προσπέρασαν τις καταχωρήσεις χωρίς να τις διαβάσουν.
Κρίμα που δεν καταλαβαίνουν να τους έγραφα ένα "Μπεεεεεεεε......." απο κάτω.
Δεν έχω ipod..ούτε προκειται ποτέ να πάρω.
Άμα σου πω το κόστος χρήσης του Smart....θα κλάψεις. :happy_8: :happy_9:
Πρέπει να είναι το πιο φθηνό από όσα αυτοκίνητα είχα.
(Μικρά - μεγάλα)
Re: Απάντηση: Kharma Matrix MP 150 Monoblocks
Εχω παραδεχθεί οτι είμαι μέγας ...κάβουρας...τι να κάνουμε. :happy_5:
Gebreselassie
Μαύρος!
Δεν είναι ο κανόνας, είναι η εξαίρεση...
Ρε συ, μιλάμε για τα κλωνοποιημένα αυτοκίνητα τύπου VW, SEAT, AUDI, ευρωπαϊκά, κινέζικα, αμερικάνικα κ.ο.κ....
Το ίδιο πράμα με διαφορετικό τιμολόγιο.
Klipschlascala_pro1988
