Κώστας Φ.
Έλα τα open-baffle....
"Bastanis Atlas are 100dB/W/m sensitivity open baffle loudspeakers for frequencies of 100Hz upwards, bass below 100Hz is provided by a pair of 150 watt solid-state amplifiers powering a pair of 15 inch bass units in sealed boxes
The 3-D kaleidoscope of sound that Atlas produce leaves me feeling I have attended a performance, leaving a sense of euphoria. There is a word that can be over-used, I'm going to use it but with my sense of British understatement - Awesome. Attack, decay and inner resolution are only very slightly off the mark, though I do not have any complaints about these areas. Small drivers with extremely lightweight moving parts possibly could do fractionally better but would they do as well overall - I doubt it! I reiterate, Atlas are the best I've heard. Are they keepers? You bet!"
Specifications
Type: Open baffle loudspeaker system with powered woofers
Tweeter: 1 inch compression, horn loaded, 16 Ohms
Wideband (midrange): Two 12 inch in open baffle, 100Hz to 11kHz, 16 Ohms
Sensitivity: 100dB/W/m
Weight: 42lbs with 25mm birch ply baffles
Woofer: 15 inch in sealed cabinet
Weight: 80lbs with 25mm birch ply cabinets
Power: 1 watt minimum to 150 watt maximum
Subwoofer amplifiers: 150W, 30Hz to 160Hz crossover, 24dB/octave, 3dB boost at 40Hz, subsonic filter at 25Hz, 24dB/octave
Auto switch-on, line and loudspeaker level inputs, 115V and 230V operation, phase adjustable 0 to 180 degrees
Price:
1,300€ for the Atlas wood kit
3,400€ / $4,590for the Atlas kit (excluding baffles & cabinets)
5,200€ for fully assembled loudspeakers
Full Review: enjoythemusic.com
