Origin Live Calypso
Κώστας Φ.
  • Price at Launch 1470 GBP
  • Turntable Type Direct Drive
  • Colour Black
  • Dimensions 480 x 120 x 360 mm (w x h x d)
  • Weight (kg) 11 kg
  • Additional Features Motor pod provides electronic speed change / Two plastic and one steel foot allow easy levelling / Comes with simple VTA adjuster for Rega and Origin Live tonearms
  • Tonearm No
  • Additional Information Also available in white or clear acrylic for an extra £150
"We have to say we've never before come across a turntable-and-arm combination that's been this pernickety about its set-up. At some point we'd be keen to put the Calypso through its paces with another tonearm to see if it's the Encounter that's responsible for this super-sensitivity. In the meantime, this turntable gets the thumbs up it thoroughly deserves for the fine performance it provided in the end."
For
  • When properly set-up, the Calypso offers a delightful musical performance
  • Rather attractive if you're a fan of post-modernist looks
Against
  • The Calypso-Encounter partnership seems unduly fussy about its set-up, which is perhaps fine for enthusiasts but might be off-putting for turntable 'civilians'.
Verdict
If you're a patient and methodical sort, happy with turntable tinkering, the Calypso will reward. Whilst perhaps not an ideal deck for a first-time buyer, when correctly set up, the deck will delight with its looks, musicality and perky performance
Full Review: Tech.co.uk (Hi-Fi Choice)
Πρέπει να τους έβγαλε την πίστη μέχρι να το σετάρουν... :cool_11:
Ημίθεος
Πριν μάθει ο αγγλάκος πώς σετάρουν ένα πικάπ, πρέπει να μάθει τί εστί direct drive. :cool_11: :cool_11:
Αλήθεια γιατί σχεδόν κανένα Hi-Endάδικο πικάπ δεν είναι Direct Drive? Νομίζω μια καλή υλοποίηση Direct Drive σαν το SL-1200MKII θα πρόσφερε πολύ μικρά επίπεδα Rumble και μεγάλη ακρίβεια στροφών. Τελικά τι ισχύει; Κάποιοι θεωρούν το SL-1200MKII ένα από τα καλύτερα πικάπ και κάποιοι το θάβουν. Πάντως ψάχνοντας στο Internet είδα ότι αυτοί που το θεωρούν καλό έχουν σοβαρά επιχειρήματα για την αποψή τους αυτή και κυρίως αναφέρονται στο πολύ καλό σύστημα DD που διαθέτει και τις εξαιρετικά χαμηλές τριβές του βραχιονά του (ο οποίος όμως εχει αυξημένο βάρος σε σχέση με νέες υλοποιήσεις). Βασικά ρωτάω γιατί ενδιαφέρομαι για ένα καλό πικάπ που θα αντικαταστήσει το ταπεινό SL-BD22 που έχω τώρα.
argiristheo
