εισαι ενα ΚΤΗΝΟΣ και μισο............
vlasis
Φωτογράφος!
BRYSTON 1000 WATT 28B-SST MONO AMPLIFIER
bryston-1000-watt-28b-sst.pngBryston has recently introduced the 28B-SST mono amplifier. This is a 1000 watt power amplifier that does not compromise presentation even at 1/10th its rated power output. The most significant part of the design criterion for the 28B-SST Mono Amplifier was to build up a very influential amplifier which would oblige any speaker on the planet but preserve a perfect power curve at 1 watt as well as at 1000 watts and every power level in between. Now what would be the end result?
A big, great amplifier that sounds extremely detailed and musical on other hand maintaining the same sonic complexity and drive capacity with even the most challenging, incompetent speakers. The smart new Bryston 28B-SST amplifier is a completely objective output amplifier, which has condensed THD and IMD to unparalleled low values, (typically 0.001% or less).
The device gives out a new degree of lucidity, musicality and relieve of listening. With terrifically low noise floor generally below 115dB, give way complete silence between notes for persuasively pragmatic reproduction. The 28B-SST from Bryston is backed with a 20 year warranty and reaches the user at an MSRP of $7500.
Τι είναι οι παραπάνω ενισχυτές.Μινιατούρες??:crazy_3::crazy_3:Για δείτε 2 πραγματικά ΚΤΗΝΟΙ.....:bravo:Ο krell o 700 ίσα που φαίνται στο κέντρο.....Δείτε την διαφορά..
Gryphon Antileon Mono
Fully balanced circuit
175 Watts Class A
40 High current bipolar output transistors
440,000 µF power capacitor bank
Flat frequency response to beyond 350kHz
Gryphon Guideline Reference gold-embedded silver internal wiring
Zero global feedback
Custom-built dual toroidal transformers
Custom-built power capacitors
Shielded, epoxy-damped transformer casings
Separate power supply for display and control circuits
DC servo coupling
No output relays
Frequency-independent damping factor
Custom-built binding posts
Automatic Green Class A bias setting or manual Low/High bias
AC power status display
Rigid mechanical structure
Microprocessor-controlled non-invasive "smart" protection system
Double sealed, mil spec PCB with 105 µm copper traces
Upgradeable microprocessor software with integrated service log
Nick Arvanitakis
Audio Pro
Απάντηση: Re: Απάντηση: εισαι ενα ΚΤΗΝΟΣ και μισο............
Αδερφε με τριφασικο δουλευη αυτο το θηριο???
:happy_9: οχι βρε φιλε ,αλλα θελει να την προσεξεις τη τροφοδοσια!
vlasis
Φωτογράφος!
Μ αρεσουν οι BRYSTON,καποτε ειχα εναν 2B.
Αλλα οταν μιλαμε για κτηνος....
Ναι-Ναι-Ναι-Ναι-Ναι και ξανα μανα ΝΑΙ Νικολακη ΜΑΖΙ ΣΟΥ.....Ποτε θα μου τα στειλεις?????????????????
και ομως στην ουσια τριφασικο θελη.
5kw για καθε καναλη που θα τα βρης αλλιως;
1 φαση για καθε καναλη και μια για το υπολοιπο σπιτι.
Nick Arvanitakis
Audio Pro
30.000 εκαστος .τωρα αλλαξε μοντελο και δεν ξερω τιμη.
ουουουουουουουουουουου
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Πολλα λεφτα ρε παιδια χαρα στο κουραγιο που τα δινεται.
Nick Arvanitakis
Audio Pro
Απάντηση: Re: εισαι ενα ΚΤΗΝΟΣ και μισο............
o krell MRA που έβαλα εγώ κάνει 180.000 ευρώ το κομμάτι.....:cool_1:
Τζαμπα πραμα!!!:crazy_3:
Τους M L no 33 τους εχω δει απο πολυ κοντα ,τους εχω πιασει, εχω δει τον εσωτερικο τους κοσμο και :respect::respect::respect:τους εχω ακουσει!
argiristheo
