εισαι ενα ΚΤΗΝΟΣ και μισο............
LUXMAN
LUXMAN B-1000f
250 w/8 Ohm
500 w/4Ohm
1000 w/2Ohm
2000 w/1Ohm
64kgr εκαστος
48000 ευρω
Nick Arvanitakis
Audio Pro
Απάντηση: εισαι ενα ΚΤΗΝΟΣ και μισο............
Ρενο,ειναι μικρος και ελαφρυς!!χαχαχαχαχαχ!!
Nick Arvanitakis
Audio Pro
MARK LEVINSON no33 Monaural Power Amplifier
Frequency Response: Within 0.1dB from 20Hz to 20kHz
Input Connectors: one 3-pin XLR balanced input connector per channel
two RCA input connectors per channel
two 1/8" mini-jacks for remote turn-on
two Mark Levinson communications ports (RJ-11)
one captive high current AC mains cord
Input Impedence: 100 kohms (balanced), 50 kohms (single-ended)
Input Sensitivity - Full Output: 2.3V
Mains Voltage: Determined by the needs of country for which the unit was manufactured; cannot be reset by dealer or user
Output Connectors: four custom binding posts per channel
Output Impedance: Less than 0.05ohms from 20Hz - 20kHz
Output Impedence: Less than 0.05 ohms from 20?20,000 Hz
Power Consumption: Typically 840 W (±5%) at idle
Typically 210 W (±5%) in standby
Power Output: 300 w/ch continuous rms power at 8 ohms
600 w/ch continuous rms power at 4 ohms
1200 w/ch continuous rms power at 2 ohms
2400 w/ch continuous rms power at 1 ohms
All of the above power ratings measured from 20 Hz?20 kHz with no more than 0.3% THD
Signal to Noise Ratio: Better than ?80dB (ref. 1 w)
Voltage Gain: 26.8dB
Weight: 435lbs. (198kg) each
vlasis
Φωτογράφος!
Eιναι παντως και αυτο αλλο ενα πανακριβο κτηνος...........και οπως φαινεται ετσι με τα Ναυτιλια ...καπως μου ερχεται!!!!!!!!!!!!!!!!!!!!!!
vlasis
Φωτογράφος!
Μαρινο ο Νικος .....τον εχει πιο μεγαλο και πιο....βαρυ!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LUXMAN
Ακριβως ! Ομως ετσι δυσκολα θα τον βαλει καπου αλλου , μονο στο σπιτι του θα τον βαζει :crazy_3: και θα τον παιζει :cool_11: !
:happy_8: :happy_8:
Nick Arvanitakis
Audio Pro
Απάντηση: Re: εισαι ενα ΚΤΗΝΟΣ και μισο............
:happy_8: :happy_8:
To σπιτι ειναι ......ευρυχωρο:happy_8::happy_8:
argiristheo
